January 19, 200917 yr You guys think it would be possible to tint the rear lights with krylon fusion flat black?
January 19, 200917 yr Author Seems like a pain, plus the rough contour would deform the tint I think.
January 19, 200917 yr I'd probably go with gloss black. I've used the fusion paint a lot, and the first coat does mimick tint quite well when sprayed on light colored surfaces, but the paint would act differently than tint, I think, worst case scenario you sand it off and buff the lens, or a quick scrub with lacquer thinner and a rag. A thin coat of paint might not be all that durable though, maybe clear coat on top?
January 20, 200917 yr years and years ago, i found a spray can tint. i don't remember who made it , but it may be an option if they still make it. good luck, Bill
January 20, 200917 yr There is a spray tint on the market..I am not sure what its called ..but hatchsub did his tail lights on his sedan with really nice results. I have toyed with doing it to my 08 Imp..but now I am used to the clear tails .
January 20, 200917 yr Regular window tint will not work in this application. 2 reasons for that. 1) the tight radii of the lens covers means that the film will have to be heat shrunk a LOT and that risks scorching. 2) the adhesive used on standard window tint does not adhere well at all to plastic surfaces. This WILL eventually lead to bubbling, discoloration and peeling. There IS a film made specifically for light covers. You might try tintedtails.com. they can pre-cut a piece of appropriate tint for you.
January 20, 200917 yr Years ago I tried various methods of tinting tail lights and the best results I had were with Rustoleium Gloss black. Apply a couple of coats and then use some rubbing compound and rub the s#it out of it until you get the right thickness and shine you want. Just make they are bright enough for day time use as they wont look good in a million pieces on the road.
January 20, 200917 yr What is the Reason to Tinting the Tail Lights? ... I Have seen Some Cars with Obscure Tail Lights or with a Dark Plastic Cover, and I Believe it could make `em more Unsafe to Drive, if your Car Doesn`t have a Third Light for Brakes... Here I see the Opposite Too Often: People Swap Clear Lenses` Tail Lights and use Coloured Bulbs (sometimes even Led Bulbs in RED / Yellow \ White colour) like This:
January 20, 200917 yr Author Talk about mixed messages lol. I do have some lights from another car around here somewhere maybe give it a try. I know the lights will shine through just not sure about the colors The spray tint works great, many people with 350z do it but it isnt available in Puerto Rico. Also, I do have a third brake light
January 20, 200917 yr I seen a car onetime that had black pantie hose stretched over the lenses. It looked tinted and its cheap. lol
January 20, 200917 yr Author The price is right but im overseas and they wont ship The panty is ghetto at best, there is actually a guide on how to do it on several car sites.
January 21, 200917 yr well you might be able to talk to the autozone there in bayamon (love the store locator ) and see if they could special order some of that nite shades in for you.
January 21, 200917 yr There is a spray tint on the market..I am not sure what its called ..but hatchsub did his tail lights on his sedan with really nice results. I have toyed with doing it to my 08 Imp..but now I am used to the clear tails . I would be very interested in what the end result looks like.. hatchsub, got any pics?
