sub_dont_touch Posted February 22, 2009 Share Posted February 22, 2009 Every time my 1994 EJ18 Impreza is on empty and just about to run out. I seem to get quite a bit of power that I don't see normally even when I have under a 1/4 of a tank. So that means that it can't be a weight issue. Could this mean a bad fuel pump or something? Quote Link to comment Share on other sites More sharing options...
nipper Posted February 22, 2009 Share Posted February 22, 2009 Gasoline is about 6 lbs per gallon. It can be just your imagination. Can be the fact your car is thirsty and in a rush to get to its "water fountain" . Don't you always run faster after a workout when you know the bevergae of your choice is there waitng for you, tempting and taunting you? Or it can be that your running rich and you dont know it (tired fuel pressure regulator ? ). nipper Quote Link to comment Share on other sites More sharing options...
edrach Posted February 23, 2009 Share Posted February 23, 2009 What size tires do you run? My '94 EJ18 sedan ran fastest on 14" rims; like a stone on 16" rims. I never noticed a difference with different amounts of gas in the tank. Maybe the slight forward shift of weight to the front makes a difference. Quote Link to comment Share on other sites More sharing options...
nipper Posted February 23, 2009 Share Posted February 23, 2009 Just for giggles put a fuel pump pressure testor on the car. one enver knows, odder things have happened nipper Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted February 23, 2009 Share Posted February 23, 2009 it is possible the engine is running LEAN-er also happens with lawnmowers and chainsaws Quote Link to comment Share on other sites More sharing options...
abog Posted February 23, 2009 Share Posted February 23, 2009 If it were leaning out from fuel starvation, or if it were running rich and just clearing out, wouldn't there be some other symptoms? hesitation, bucking, possible CEL, O2 codes? Anyone? Quote Link to comment Share on other sites More sharing options...
sub_dont_touch Posted February 23, 2009 Author Share Posted February 23, 2009 What size tires do you run? My '94 EJ18 sedan ran fastest on 14" rims; like a stone on 16" rims. I never noticed a difference with different amounts of gas in the tank. Maybe the slight forward shift of weight to the front makes a difference. I have 15" rims. Thats interesting to know. cheers. Is there anything that I can remove to make it lighter. Things that are important? Quote Link to comment Share on other sites More sharing options...
kirbykirb Posted February 24, 2009 Share Posted February 24, 2009 My legacy does this too hehe. So I'm not th eonly one! Quote Link to comment Share on other sites More sharing options...
