Why do I have more power when on empty in my Subaru Impreza?
Every time my 1994 EJ18 Impreza is on empty and just about to run out. I seem to get quite a bit of power that I don't see normally even when I have under a 1/4 of a tank.
So that means that it can't be a weight issue.
Could this mean a bad fuel pump or something?
Gasoline is about 6 lbs per gallon.
It can be just your imagination. Can be the fact your car is thirsty and in a rush to get to its "water fountain" . Don't you always run faster after a workout when you know the bevergae of your choice is there waitng for you, tempting and taunting you?
:grin:
Or it can be that your running rich and you dont know it (tired fuel pressure regulator ? ).
nipper
What size tires do you run? My '94 EJ18 sedan ran fastest on 14" rims; like a stone on 16" rims.
I never noticed a difference with different amounts of gas in the tank. Maybe the slight forward shift of weight to the front makes a difference.
Just for giggles put a fuel pump pressure testor on the car.
one enver knows, odder things have happened
nipper
it is possible the engine is running LEAN-er
also happens with lawnmowers and chainsaws :)
If it were leaning out from fuel starvation, or if it were running rich and just clearing out, wouldn't there be some other symptoms? hesitation, bucking, possible CEL, O2 codes? Anyone?
I have 15" rims. Thats interesting to know. cheers.
Is there anything that I can remove to make it lighter. Things that are important?
