Top mount pics. 89 RX
Hello all,
Here is my top mount. Im pretty happy with the install so far, I need to finish the intake and make a shroud for the scoop.
Eh, maybe a few more than a few things, strut bar needs to be done too.. list goes on and on really...
[ATTACH]6232[/ATTACH]
Sam
Wow, looks good man. What TMIC is that and where did you you get your pipes from?
That looks pretty sweet. Can I ask a question? I noticed that there is no MAF in the pics. Are you running MS?
Patrick
iluvdrt, the ic is from ebay, CXRacing (for the 02-06 wrx/sti?)and the pipes are my own construction. The bov is installed over the stock hole.
4WDFrenzy, MSnS extra is up and running, I have about a 1k miles on this setup.
Alu. radiator, bigger turbo, e85 tune... on and on..
Sam
Edited by bluto5
this looks proper rood, well done
got any more pics of it, general pics, and engine and a spec list? looks proper interesting, i like to see peoples ideas! :headbang:
very nice. i personally would like to see more about the megasquirt set up on there.
i am still looking to possibly go with that in my brat when i get it done.
backinbrat, Ill get some more pics up soon, I need to pull it all apart to paint the brackets and chasis. As for specs, its a pretty stock 89 rx with some gauges and some lights.
subyrally, Ill get more more pics on that also. I have a 36-1 wheel welded to the crank pulley, edis module and coilpack, 280zxt injectors and an innovative wide band.
Thanks to everyone for the kind words, I can see mostly a messy half finished engine bay at this point. The idea of whats to come is still there also.
Relocate the battery, rewire and remove the stock wiring harness, take out the dash to rewire and make foot room.... on and on..
Sam
got pics?
of lights, gauges, body?
where's the subspeed strut bar and filter adapter, and when are you sending them my way?????????
Do you have pics of your mounting setup? I'm trying to figure something out for my IC, but would like to see what others have cooked up before I dive in.
