Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Rusted Exhaust Bolts
#1
Posted 30 January 2011 - 06:20 PM
#2
Posted 30 January 2011 - 06:23 PM
Clean those threads out with a wire brush. No sense it trying to pull more crap through that nut than necessary.
You can try some juice.
Remember either the nut will come off or the stud will come out of the head (hopefully).
If it breaks in the head it's not a pleasant day.
#3
Posted 30 January 2011 - 07:13 PM
Hopefully it will not be a pita.
Wish you good fortune.
O.
#4
Posted 30 January 2011 - 07:25 PM
#5
Posted 30 January 2011 - 07:39 PM
sprayed them with pb'laster and they backed out. i think that on 4, the nuts came off, while on 2, the studs backed out. no matter, i put em back on that way.
#6
Posted 30 January 2011 - 07:49 PM
But I do that with a lot. Like eng to trans bolts, engine mount bolts, heck even the radiator bolts. Just about everywhere. Yea it gets everywhere but should you ever need to take anything apart - especially in the rust belt - you'll be glad you did.
I just never do TC or Pressure Plate bolts. Other than that most bolts get it. Like AC bracket bolts, PB bolts, certainly the tensioners, etc.
#7
Posted 31 January 2011 - 12:44 AM
Running the engine to temp before hand will heat them up nicely too.
X2. Get it up to operating temp and they should come out with little trouble. Some will probably pull the studs out of the heads which is fine. If you really want to, you can get new ones, but usually it's not necessary.
#8
Posted 31 January 2011 - 12:45 AM
#9
Posted 31 January 2011 - 01:03 AM
#10
Posted 31 January 2011 - 07:59 AM
If You get to the poing of galling the heads, You might want to try a Nut Breaker. It's a small tool that will split the nut, available at most tool vendors.
#11
Posted 31 January 2011 - 11:32 AM
IIRC you just tighten them hand tight and snug them with a pair of pliers. Maybe someone can chime in to confirm?
#12
Posted 31 January 2011 - 11:40 AM
they will most likely come out with the studs. Take the stud/nut combo>put in vice and heat the nut until red hot ( oxy/acy torch) then spin the nut off. If you dont have a torch then you can cut the nut on one side with a sawsall then spin it off with the help of a chisel. clean up threads, add anti seize, reinstall, smile
Chances are the nut comes off with the stud. If so, just replace them. There is a slight chance a rusted stud can take the aluminum thread with it. You can get away with just new hardware if that happens, if you are careful with torque.
Thread is m10x1.25 Install the short end of the studs to the head. Thread in the stud first, install pipe, then nuts.
You can shop in the HELP brand aisle and either find a pair of 'import exhaust studs', or 3 studs and 2 bolts in the 'GM/Toyota exhaust manifold' kit (get 2 if you need 6 studs)
