93 subaru loyal problem "bogging" out plz help
33 replies to this topic
#1 stonedmonster
stonedmonster
    Member
  • PipPip
  • 12 posts
  • eugene OR
Posted 25 October 2013 - 12:48 AM
Hello I am new here I just bought a 93 loyal fwd 1.8l 5 speed and it is my first Subaru. It has a bogging out issue when speeding up it idles fine but if you push the gas pedal down more than about an inch it bogs out, it does it in all gears. I am clueless it runs fine just got to accelerate slowly, anyone know why??? anything helps thanks.
#2 MR_Loyale
MR_Loyale
    22 Years of Ownership. 94-16
  • 1,527 posts
  • Seattle
Posted 25 October 2013 - 01:19 AM
Check for vacuum leaks. Also could be a fuel delivery issue.
#3 stonedmonster
stonedmonster
    Member
  • PipPip
  • 12 posts
  • eugene OR
Posted 25 October 2013 - 03:01 PM
okay, I did not think it would be fuel unless its getting to much. It runs great it idles smooth and I can drive it but got to take off slow if I push the pedal to hard it just bogs down really bad or if you rev it, but I can rev it up if I just push lightly. it looks to have a new fuel filter in it and the pump don't seem to be making much noise, Someone had suggested the throttle positing sensor would that cause this??
#4 Lou Baroo
Lou Baroo
    Member
  • PipPip
  • 10 posts
  • PNW
Posted 25 October 2013 - 03:17 PM
I had a similar problem.
We found several issues:
1) wrong fuel filter.  No kidding
     The correct fuel filter is very large and sits in a bracket that is mounted near the driver's side strut tower
2) TPS "issues" (of which there were several)
     First it was not mounted securely and was off placement
     Then a mechanic I had working on it properly "calibrated" it - a procedure I am not familiar with
#5 ruparts
ruparts
    Subaru Nut
  • 565 posts
  • hooper, co
Posted 25 October 2013 - 05:40 PM
hi,
 if the car has been sitting for a while , old gas is notorious for this condition, putting a couple hundred miles with new gas is the cure for that.  second check the ignition timing,  you must have the diagnostic connectors connected  !  and  set it with a timing light,  then disconnect them for daily driving after the adjustment,,, they might be connected now , if so , that could be your problem since that will cause the timing to not have advance.  next check the coolent sensor and the connectors to it, they usually have the green corrosion and this is the temp sensor that controls the FI system.   if these few things don't get you going then maybe 1 or both your timing belts have jumped a notch , easy to check , remove the outer end covers from the belts and line up the 3 timing belt marks on the flywheel with the bell housing pointer and see if the cam pully marks are exactly , 1 straight up and the other straight down,, if so the belts are right.   the throttle position sensor may cause problems but if it's not been messed with don't do that till after these other checks first.
#6 naru
naru
    1000+ Super USER!
  • 2,301 posts
  • under the bridge
Posted 26 October 2013 - 10:18 AM
Classic ignition miss.
Start simple.
Plugs, wires, rotor and cap.
#7 Gloyale
Gloyale
    It's a sickness
  • 10,928 posts
  • Corvallis, OR PNW
Posted 26 October 2013 - 11:14 AM
Start simple.
+1  espescially plugs and wires.
#8 BoxerRebellion
BoxerRebellion
    Advanced Member
  • PipPipPip
  • 114 posts
  • Portland, OR
Posted 26 October 2013 - 12:50 PM
Never rule out the simple or obvious. I remember I had a '94 Legacy. Had the same symptoms as you're describing. (Freaked me out by the way) Turned out - It had a bad plug wire. Electricity was arching up the side of the boot. Replaced 'em and there-yeh-had-it. Start with what's easiest to access/diagnose. Work your way up that chain. Your check engine light isn't ON? (Not that it matters nearly as much with Soobs) If it is ON, AutoZone will run the codes for free. Sweet huh?
#9 Gloyale
Gloyale
    It's a sickness
  • 10,928 posts
  • Corvallis, OR PNW
Posted 26 October 2013 - 01:09 PM
Autozone only scans OBD II cars.
Any 94 or OLDER subaru needs codes pulled using D-check or U-check modes (green and black connectors)
#10 stonedmonster
stonedmonster
    Member
  • PipPip
  • 12 posts
  • eugene OR
Posted 26 October 2013 - 01:12 PM
Okay that's were ill start, and no check engine light. it does better after she's good and warm its not as bad as when its cold. when its warm I can hold the pedal down and it will bog down pretty bad but if If I keep holding it it comes back after like 30sec
#11 stonedmonster
stonedmonster
    Member
  • PipPip
  • 12 posts
  • eugene OR
Posted 26 October 2013 - 01:15 PM
I am not familiar with pulling codes on thease old soobs how do I do that?? and if it had a code would the check engine light be on?
#12 Subarocket
Subarocket
    New User
  • PipPipPip
  • 109 posts
  • Golden, BC, Canada
Posted 28 October 2013 - 05:18 AM
My car did this too. Pull off air filter, make sure she's clean, spray sensor with carb cleaner or it looks mucky, let dry, make sure everything goes back together tight. Presto. Could be real simple
#13 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 28 October 2013 - 09:13 AM
Feul pump / preshure / volume problem or mising intake plumbing or inproperly conected intake plumbing
#14 Rust
Rust
    Eat, Live, Breath Subaru
  • 1,079 posts
  • The Sticks
Posted 29 October 2013 - 10:02 AM
Most likely fuel issues, dirty injectors/lines /filters ect. Had very simmilar symptoms w/ my 93 loyale. swapped all the plugs/wires, ect.  even tried swapping fuel filters/checked and re-checked all the vacuum lines.  Nothing fixed it.    Eventually it got better,  whatever was clogging up the lines must have worked its way through.
#15 stonedmonster
stonedmonster
    Member
  • PipPip
  • 12 posts
  • eugene OR
Posted 30 October 2013 - 01:17 AM
haven't had time to do anything yet to find the issue but it DOES have a check engine light on. the previous owner had put black tape over the light :angry:
#16 Subarocket
Subarocket
    New User
  • PipPipPip
  • 109 posts
Posted 30 October 2013 - 01:40 AM
I don't think you can be mad at someone for putting tape over the cel. It's not that sneaky and you could have questioned the tape.
Don't write off the air intake issue I suggested. It can be simple.
#17 Gloyale
Gloyale
    It's a sickness
  • 10,928 posts
  • Corvallis, OR PNW
Posted 30 October 2013 - 11:57 AM
I don't mind the tape.
It's when people take out the bulb or cut the wire to disable it that I get peeved.
#18 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 01 November 2013 - 09:35 AM
water in feul ?
#19 scoobiedubie
scoobiedubie
    USMB is life!
  • 701 posts
  • Aloha, Oregon
Posted 01 November 2013 - 10:11 AM
Check the timing.
#20 stonedmonster
stonedmonster
    Member
  • PipPip
  • 12 posts
  • eugene OR
Posted 02 November 2013 - 03:06 PM
the light wasent a big deal just dident see it at first. Doesn't seem to be anything related to air intake, the filters like brand new and all the plumbing seems to be fine the connection is clean. I'm thinking I'm gonna change the rest of my plug wires next two are new the rest are original. Also does any one know how to cut the power to the electric seat belts they don't work as someone has messed with the ignition but the passenger one still has power and it makes a weird noise and I can't find a fuse for it. I just want to cut power to it till I get a new ignition installed.
#21 ruparts
ruparts
    Subaru Nut
  • 565 posts
  • hooper, co
Posted 02 November 2013 - 03:49 PM
 hi,  pretty sure the drive /motor end of the auto belt track is at the base of the door pillar, between the front and rear doors  you can just unplug it there from the body harness.. otherwise pulling fuses  might get it but probably would turn off other stuff since the belts are not on a circuit all alone.  there is a plug at the top front end of the tracks also under the pillar trim but i think they are for position sensors ,,  the main drive motor is at the base.
#22 l75eya
l75eya
    Almost has it all figured out
  • 2,371 posts
  • Hoboken, NJ
Posted 02 November 2013 - 10:49 PM
Wagon or sedan? I know for the sedan its in the trunk.
#23 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,528 posts
  • Roatán, Honduras.
Posted 02 November 2013 - 10:56 PM
I wonder why Nobody told that a Stuck open PCV Valve could lead to a Boggin' under acceleration too...
Have you Checked out the PCV Valve, yet?
Kind Regards.
#24 stonedmonster
stonedmonster
    Member
  • PipPip
  • 12 posts
  • eugene OR
Posted 03 November 2013 - 02:13 AM
it is a sedan, the motor is at the base of a door I tryed to unplug it bit it dident seem to be the right one ill have to pull it off tomorrow. no I have not checked the pcv valve yet eather.
Edited by stonedmonster, 03 November 2013 - 06:34 PM.
#25 MR_Loyale
MR_Loyale
  • 1,527 posts
  • Seattle
Posted 03 November 2013 - 08:32 PM
What is the code?
http://www.troublecodes.net/subaru/
