29" wheels without lift?
11 replies to this topic
#1 spinsirs
spinsirs
    New User
  • PipPip
  • 27 posts
  • olympia
Posted 14 November 2004 - 06:03 PM
if i cut away the fenders so that 29" tires fit would that compromise the unibody to a degree that would be bad? would it still have enough room to turn the tires? are their any other issues?
#2 maximumBRAT
maximumBRAT
    Eat, Live, Breath Subaru
  • 272 posts
  • Berthoud
Posted 14 November 2004 - 06:04 PM
i'll save ya'll asking.. on what?
#3 spinsirs
spinsirs
    New User
  • PipPip
  • 27 posts
  • olympia
Posted 14 November 2004 - 06:23 PM
79 brat
#4 MSSLGECKO
MSSLGECKO
    Certified Subaru Nut
  • 755 posts
  • Missoula
Posted 14 November 2004 - 06:35 PM
This is something that you would get a search result for for about every week since 1999. So, I'll say search. But to answer, w/out a lift, they will fit (I think) but will rub horribly. To mount 27's or 28's on a 3" Lifted car, people usually have to trim their fender.
This is not gospel, I haven't tried it myself, but this is what I have gathered reading the big wheel w/out lift posts.
#5 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,102 posts
  • NH
Posted 14 November 2004 - 08:01 PM
Quick semi-hyjack:
What about 30"s on a 3" lifted EA82 wagon?
#6 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 14 November 2004 - 08:09 PM
Check the offroad forum for answers to all your questions.
-Brian
#7 ezapar
ezapar
    [OTD]
  • Moderator
  • 27,377 posts
  • Seattle
Posted 15 November 2004 - 12:28 AM
The answer is yes. But, your turning radius will suffer bigtime! Lots of cutting and trimming is involved, plus you need a lot of offset in the rear to clear the rear swing/sway? arm. Look at it, you'll see what I'm talking about. Your 13s barely fit.
Barely. Same as above with the turning radius. Ask Bushbasher?, I think he has about that set-up
#8 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 15 November 2004 - 12:12 PM
Quick semi-hyjack:
Yes. I had 30"x9.5" Baja Widetrack Radials on my '88 GL wagon. I used them to judge where I had to trim and bash. They were pretty rotten so I had to throw them away :( Now running 29"x8.5" and wishing I had bought 30"s again!
A big factor not mentioned in this thread is gearing. Good by 5th gear :) I only use mine going down hill. Getting rolling in 2WD is tougher. Just have to give her more gas and GO! Once youre in 4WD lo it's all good though ;)
#9 Snowman
Snowman
    Midnight Passenger
  • 3,538 posts
  • Haines
Posted 15 November 2004 - 07:48 PM
I know of a loyale with a 3" lift that had 31" tires on it. He had to cut fenders quite a bit, but it worked.
My 27's required a bit of front fender bashing with the 3" lift installed.
#10 MSSLGECKO
MSSLGECKO
  • 755 posts
  • Missoula
Posted 15 November 2004 - 07:53 PM
Okay, I'm gonna hi-jack this post:
What do you guys think of 29"s on a 3" lifted subaru? What trimming is necessary for no rubbing on- and off-road? Does anyone have pic.s of thier lifted and trimmed wagon w/ 29"s?
Thanks
#11 Flowmastered87GL
Flowmastered87GL
    WCSS Drunk
  • 6,273 posts
  • Portland, Oregon
Posted 15 November 2004 - 09:53 PM
I have pictures of 28/29 inch tires ona 3 inch lifted brat... they barely fit. cutting and banging of the fenders and wheel wells has to happen.
e-mail me if you want to see them
the_great_mikeholio AT yahoo DOT com
#12 HillbillyLes
HillbillyLes
    User Awaiting Email Confirmation
  • 272 posts
  • North Central Missouri
Posted 20 November 2004 - 09:20 PM
GOTO the photo gallery and you can see my (HillbillyLes) 86 GL wagon with 3" lift. I have 15" wheels and 27.5" diameter tires. I had to remove the front mud flaps and fold about 1-1.5 inches of the aft corner of the front fenders (the corner under where the mud flaps were. All fit with slight rubbing of the rear tires on the plastic/rubber trim strip around the fender lip when loaded pretty heavy and hit hard dips in the road. By measurements, the 27.5" tires were as tall as I could go without doing some serious fender work.
