welding my rear end?
21 replies to this topic
#1 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 13 January 2004 - 03:03 AM
I'm thinking about welding the gears on the rear end..
How is this gonna affect driving on icy paved roads in 4wd?
and does anyone have a good pic of where I need to weld on a 3.9 diff?
#2 75skunkaroo
75skunkaroo
    Gimmie Shock Treatment
  • 587 posts
  • Central Point Or.
Posted 13 January 2004 - 03:10 AM
pm threeeyedbandit, hes welded up two diffs and there hasnt been any probs yet. i think he was saying that he liked the way that an un-welded diff drives in the snow, but as for plain ol' wheelin it just kicks @$$
-mike
#3 Do It Sidewayz
Do It Sidewayz
    Subaru Fanatic!
  • 464 posts
  • Toronto, Ontario
Posted 13 January 2004 - 09:02 AM
on snow and ice, it's going to understeer fairly bad.
In a straight line, it'll hook up and go.
To get it turned you're really going to have to pitch the car into the the corner and drive it sideways.
#4 ThreeEyedBandit
ThreeEyedBandit
    Eat, Live, Breath Subaru
  • 263 posts
  • Central Point Or
Posted 13 January 2004 - 11:47 AM
I just PM'd you and if you need pictures I should be able to get some by wensday.
Matt
#5 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 13 January 2004 - 11:54 AM
It is a bit of a fight to drive it on ice after welding the rear, the car will push real bad. On mine I just shift it back into 2WD when cornering, that helps ALOT. Or if U know that U are gona be driving on ice ahead of time just pull 1 axle in the rear 1st and then U can leave it in 4WD and have NO PROBLEMS!;)
WELD IT! WELD IT! WELD IT! WELD IT!
#6 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 13 January 2004 - 12:07 PM
yeah..
I'm kinda thinkin about LSD now cuz of the ice track we have up here..
Right now with my 3.9 rear, I gotta really throw my car into corners or it understeers and does that sideplow ****..
LSD is gonna make it a 2 wheel spinnin wonder in 4wd aint it?
#7 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 13 January 2004 - 12:42 PM
Yeah, if this is gona be your driver I would go with an LSD. That will help on ice, snow, and every thing. It will not be an off-road hero with it, but it will be better than the open dif. It (LSD) will keep 2 tires turnig in the back untill 1 comes off the ground, and not both @ the same speed all the time like a welded dif. ;)
#8 one eye
one eye
    I'm A Subaholic
  • 2,593 posts
  • Mt.Vernon Washington
Posted 13 January 2004 - 05:02 PM
I welded the rear end in my '79 brat and with a 1600 or ea71 it doesn't kick the power. So mine tracked pretty straight. I'm sure your gonna do it with an ea82. But I figured I put my 2cent worth in.
Jeff
#9 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 13 January 2004 - 05:38 PM
Thanks for the responses guys...
88 GL-10s autos have 3.7 LSD's right?
hehe
think I found my parts for the conversion
#10 Subafreak
Subafreak
    User Awaiting Email Confirmation
  • 907 posts
  • Central Village Ct.
Posted 13 January 2004 - 09:35 PM
I think if your ever gona run it on dry pavment that a welded diff is a bad idea. I welded the diff on my Loyal a wile back it it tore the rear axles up, it also did not like to take off in a turn. It would spin the front tire for a long time if you really took of fast in 2WD turning. It is however the shizznicky for off-road.
#11 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,704 posts
  • Portland
Posted 13 January 2004 - 09:49 PM
No 88 GL-10 auto's do not have LSD's - at least not stock.
You want to look for a GL-10 Full Time 4WD Turbo 5 speed. These and the RX have the LSD.
#12 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 13 January 2004 - 09:50 PM
yeah thats a great point.. thanks
I'm gonna go LSD for now
#13 incognito
incognito
    Banned
  • Banned
  • 441 posts
  • Eagle River
Posted 13 January 2004 - 10:05 PM
I wouldn't.
Welds are just fine. Hooks up AWESOME in snow. Understeers bad on ice because unlike a locker that has give, a weld has no give.. the end result is "slide-ways"
Basically in corners, the outside tire spins a bit more than the inside. Lockers are designed to accept the change. Welds aren't, The inside tires will generally break loose by the difference in tire rotation speed on the outside tire. It sorta helps it go sideways.
For snow only.. definately the way to go..
Ice.. Well.. I definately have yet to get an LSD.. I'll definately be getting one.
My opinion is... get both.
#14 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 13 January 2004 - 10:07 PM
battle mech.. I thought you were gone
#15 incognito
incognito
    Banned
  • Banned
  • 441 posts
  • Eagle River
Posted 13 January 2004 - 11:41 PM
Eh.. I took another time-out and did a bit of cheifin..
#16 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 13 January 2004 - 11:45 PM
yeah
#17 incognito
incognito
    Banned
  • Banned
  • 441 posts
  • Eagle River
Posted 14 January 2004 - 12:00 AM
yeh umm.. ok.. pm me for that or something.
#18 nkx
nkx
    Rallycross Junkie
  • 891 posts
  • Carlisle, PA
Posted 14 January 2004 - 02:08 AM
i have an 89 GL-10 wagon turbo, fulltime 4wd, 5 speed, and a center diff locker. im fairly new to this subaru stuff, so i dont know how hard it would be to locate an OEM locker in case you wanted to go that route.
my bad, the switch locks the center diff, not the rear... :banghead:
#19 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 14 January 2004 - 03:39 AM
OEM lockers? I didnt know soobs made those
#20 northguy
northguy
    O.C.A.L. Life Member
  • 4,352 posts
  • Chugiak, AK
Posted 14 January 2004 - 09:02 AM
They're a thing of legend.
#21 Subafreak
Subafreak
  • 907 posts
Posted 14 January 2004 - 09:01 PM
Hmm? I think there a thing of people thinking that switch in the center console that say "diff lock" is for the rear.:rolleyes:
#22 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 14 January 2004 - 09:21 PM
Lol... thats what I used to think it was..
