All Activity
- Today
I also tried my hand at printing two different versions of the center cap retaining rings. Did one in PLA that was way too long and the other in the same ABS but it snapped on me as a I tried seating it today.
Update. Had to remove the water pump and replace and reseal with a different RTV. The water pump flavor of Permatex was garbage and never sealed up. Used "The Right Stuff" this time and replaced the leaking 90* crossover hose. Tedious as hell, but no biggie. De-pinned and replaced the alternator plug that had a broken clip on it. Finally snagged a blue steering column shroud. Didn't take a pic unfortunately. Boss got a 3D printer for Christmas and brought it to the office so I been wearing it out. Made me an ABS cupholder. Next issue: My son had noticed it a few months ago but I was finally able to see it myself last night but I had electrical smoke coming out of the ignition switch where the key goes. Honestly, didn't know that was possible. I know the PO had replaced it at one point because he said the OE was worn out. I know it had quite a bit of grease down in it. For the time being I'm leaving the battery unhooked in my shop and douched the hell out of the keyhole with electronic contact cleaner and compressed air.
Returning after years...
moosens replied to msteel's topic in Meet n' Greet. Your USMB Welcome Center
Great to see you back. Enjoy your time. Lost count of how many times I’ve typed “save the dual range fivespeed” In exclamation. Good luck. I think you’ll score. Those cars mentioned, kind of parallels our own at one time. We just sold our 2006 OBW seems either you get a good one or one that’s constantly having issues. These days my daily addiction is the 2000-04 Legacy/OBW but yet to own the 2004 with the fly by wire. Having that in the 06 scared this old dinosaur. The vehicles that are fly by wire these days are many and I’m just taking a while to accept that. - Yesterday
egowing, I'll pull the wiper arms tomorrow - I'm assuming you want the fronts and back?
I haven't posted here for years, partly due to login issues. @Turbone fixed those for me recently (thank you!). All the Subarus I had before have moved along, but I have more than ever before - 2006 Outback Wagon, 2004 Legacy Wagon, and the newest arrival is a 1994 Loyale AT my son just bought. The engine is suspect from a large oil leak that resulted in the engine's being run low on oil. We'll see about the leak and then if the noises clear up. His goal is to put a dual range MT in is but we'll see how easy that is to find...
- 1 reply
- 1
GL/Loyale Broken Power Locks
SuspiciousPizza replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It was a terminal connection issue coming from the driver's door to the dash harness. The hatch still only works as manual. That's less annoying than manually locking and unlocking doors from the inside so I'll leave it for now. That breaking noise I heard I believe was a locking rod disconnecting from its socket. One on the driver side was only semi-connected. -
el_freddo started following Name That Noise - 1998 Subaru Forester 5-speed
That’s an interesting one! A chipped tooth will make a rotational clicking noise that’s speed related and only when in the chipped gear. That noise sounds like something is grinding - and interesting that it’s only in one gear. Other thought is that it’s multiple teeth that are damaged - unlikely though as the gear would most likely strip as a result, but anything is possible. Hopefully it’s something simple.
- Last week
TMFS joined the community
Oddly I didn't get one tiny particle to come out by doing that. Interesting suggestion, doesn't seem like enough power but I'll be taking it apart again - ordered a $80 ebay exhaust manifold (if you've seen the 05+ manifold pretzels that's a crazy cheap price) to have some options. I'm wondering if the clog is in the header (i think it houses the catalysts), the mid pipe, or the mufflers or more than one. Hesitates around 5,000+ RPM's/flooring it (which is sometimes helpful on a steep mountain grade but others unecessary - but makes me thinking something is still clogged. Otherwise it drives totally normal. I wore ear protection but should call and apologize to the neighbor - her horses went tearing off towards her house.
Chrishgr6 joined the community
Justyntime joined the community
wrenchlife89 joined the community
Zezyzer joined the community
wtdash started following Name That Noise - 1998 Subaru Forester 5-speed
I had to unjam the cassette ejection mechanism last night. After I plugged the cassette player back in, the rear wiper switch illuminated for the first time in my ownership. There's some weird electrical gremlins going on here. So maybe the door lock issue is some sort of electrical issue. I'll break out the FSM and multimeter this weekend and check out what's going on. Oh I wish it's actually a mechanical issue, those make so much more sense than those invisible electrons. -
I want the wiper arms! Front struts any good?? Ed egowing@tds.net
I think you’d also need the sundials to run the correct oil seal on the shaft. Male CV shafts require a larger seal, the male stub axles need a smaller diametre seal. Bit of a stuff around but worth the effort to work with what you have. I’m unsure if the auto box’s sundials will fit the manual, I’ve not tried that. The early phase 2 gearbox with stub axles and all phase 1 gearboxes’ sundials will fit your later phase 2 gearbox that takes the male CV shaft setup.
A 2-headlight GL? That's a new one for me! It's a tilt wheel difference... The correct switch is on the left side of the column, and has a maybe 9" long wire pigtail with a pink 6-pin connector on the end. The one with no pigtail, from non-tilt columns, or with a black connector, from other vehicles, won't fit. Ask me how I know. lol Thanks again!
bushytails, mine is a GL as well, so I don't think compatibility should be an issue.
