All Activity
This stream auto-updates
  1. Today
  2. Yes. 4th gens were available with the 2UZ 4.7l. Mine is a 1st gen, though. I have a 4.0 1UZ in it. Install is far from complete, but it runs and drives (no cooling system, so very briefly).
  3. Cool, thanks. Yeah Boyd’s I’ve dealt with when using a friend’s place in Norwich. But that’s a haul. Not sure what Johnny’s in Thomaston is up to lately. I think they have a new owner for a few years. Used to be ok, he’d let you walk and pick. Milford Auto Recyclers is messy but those guys can be fair too and let you walk through. I’ve picked there years ago but I’m not sure if they’re letting you pick. But they’re cool guys there.
  4. You guys got a v8 4Runner as standard, or is that an engine conversion? We got the v6 or the diesel option, definitely no v8!
  5. Yesterday
  6. Rallycross is a good time, and depending on the surface and track layout can be a real strain on the cooling system. The last time I raced one was in a fully rally-prepped STi, and I had to drive it down the road 1/4 mile and back to let it cool off after every run.
  7. I know you've already done it. But when I scrap cars, I cut out the radiator support. Then the engine and transmission come out easy. I even made the upper radiator support bolt-in on my 4Runner during the engine swap. I had the V8, 4-speed auto and transfer case in and out of it several times, but left it all as an assembly.
  8. Last week
  9. I have discovered that much of my gradual performance degradation is due to excessive slop in my Hitachi distributor's upper shaft. Getting adventurous and hoping to save my little funds, I have three Hitachis. The faulty one in the car, the one that it replaced that needs cleaning and taken apart, and a third, a used one that I want to clean. How does one remove the "breaker plate" to get to the centrifugal weights? I've pulled the screw from the upper shaft, the two "breaker plate" screws, and the vacuum module, but stuck there as "breaker plate" is immovable.
  10. I have replaced the belt not the pulleys or tensioner. Sounds like a stupid thought process, but my belt literally broke some of the teeth off as it was running. Idk how I didn't have a blown engine since it’s the revision of the Ej22 (Piston design change in 97 and brought up compression). Didn’t have the money to replace tensioner or pulleys, but they were not shot yet. I’m going to go back to them because my cam seals are leaking pretty bad so the timing belt has to come off again. One thing I’m a bit concerned about is the tensioner bolt stripping out being it goes into aluminum.
  11. Clean the outside of the engine before you start. Take lots of photos before disassembling, and as you proceed: especially hoses, wiring, elec-connectors, sensors etc.. While you're at it., consider changing the timing belt and pulleys, especially if the engine is coming out.
  12. 1+ Engine work, pull the engine. No Lift, drop the trans. PB Blaster on all mounts/bolts. Reseal the rear Breather plate for sure. Metal plate better than plastic. Rear Main, I've never seen one fail. Most of the time it's the breather plate. I've had good luck with Grip Force clutch kits off ebay.
  13. I'm doing some spring cleaning and have a bunch of extra parts that I'm trying to sell cheap. Mostly 3rd Gen parts, but I do have 2nd Gen parts too. If you need something, send me a P.M. I have some of the more desirable/nicer condition parts already up on my eBay (only way I'm willing to sell is through eBay or in person). My eBay seller name is suspiciouspizza. I'll be getting everything I have up on my eBay within the coming month. These parts may be a bit dusty and crusty, or they may be in very good condition. Better condition parts will sell for more but otherwise I'm selling cheap. I bought all these parts in lots at scrap price. I'll be acquiring another lot soon. :]
  14. You should mention what the exact vehicle is, since there were some changes to the clutch release mechanism over the years. Your list sounds pretty good. You could get a new flywheel, have yours resurfaced, or just run it, depending on what it looks like. Your clutch kit should come with a new pressure plate, unless you're being extremely cheap. Always replace the pilot bearing (assuming it even still looks like a bearing - many have long since failed on older vehicles) and throwout bearing; both should be included with your kit. You should be able to get torque specs from https://charm.li/ , or look for a pdf manual for your vehicle. For better than stock, I've been extremely happy with my Spec Stage 1 clutch. Stage 1 is just a higher clamp pressure plate and a slightly grippier disc, nothing aggressive like the higher numbered stages. South Bend Clutch is a bunch of incompetent crooks, so avoid them when shopping for upgraded parts. (See, companies, you rip people off, and then they make sure to point out you suck in every single relevant discussion) A time estimate depends on your skill level and tools. If you have a lift, tranny jack, and a decade of experience, it's a 1-2 hour job. If you have a pair of ramps, a driveway, and a harbor freight starter tool set, plan on a weekend project. Pulling the transmission is easier than pulling the engine, especially if you don't have a fully equipped shop. For tricks, for a beginner, I'd say to make sure your disc is extremely perfectly centered, both by using the alignment tool provided with the clutch kit and by visually double-checking after torquing the pressure plate, and then be very careful mating the transmission back to the engine, making sure to exactly match the tilt angle of engine and transmission, then spinning either the engine or transmission until the splines engage and the pilot slips in.
  15. I’m looking for a write up on how to replace the clutch and if there is anything else I need to do. I have replaced other clutch’s before, but not sure of the full process on these cars. The car currently has 226k so I was wondering what else I should replace while I’m there. I’m kinda thinking rear main, oil separator plate reseal, pilot, throw out, flywheel, obviously the clutch. What parts would you recommend for slightly better than stock? Is there anything else I should replace while I’m there? I see around where some people pull the engine, and some pull the transmission. What are torque specs and where could I find them? What is the estimated time in the full process. Also would like to know what tricks can be useful. Thanks again.
  16. www.car-part.com If you have a you pull it yard close by, just go in with your drill and drill out the bolts and get the complete assembly.
  17. Oof, the hits keep on coming. Between life happening and that stint where the forums were down - I hadn't had much time to update this, but today I took the time to get things moving a bit again. Long story short - I decided the simplest thing to do to solve the rubbing problem as it currently exists was to cut the tack welds and shift the whole subframe back about an inch, rather than doing a whole bunch of complex bodywork. My bodywork skills are definitely not my stronger suit, so I figured I'd better make things fit to what's already there as best I can. While this job was harder than I thought it was going to be (I had to cut out a larger section of the bed to get my cutting tools in there), the wheels now sit squarely (loosely) in the middle of the arches. To continue the spirit of solving a problem by creating new problems to solve, now I have to modify the original rear diff crossmember to make up for the distance the entire assembly has moved. Probably going to knock that out in the next couple days. Basically for that I'm going to cut some chunks out of the existing crossmember , then offset them with lengths of rectangular or square tubing of similar cross section. It shouldn't be too difficult because the stock part is basically a piece of straight U-channel with bushings mounted through it. No weird bends or offsets to be had so as long as I modify it so the threaded holes move directly rearword, it should be a pretty quick fix. Once that's all done it'll be a temporary modification of the stock lateral links to bring everything a little tighter in towards the frame, then I'll get started on fabricating the strut mounts in the bed, and probably remeasuring everything to see about finding an off-the-shelf set of adjustable lateral links and trailing arms that fit, and then another semi-permanent modification of the rear CV axles to get those back on. I'll likely need to revisit the wheel arches in some form or fashion, but I'm hoping I can get away with just some good ol' fender rolling. Time will tell.
  18. Earlier
  19. So I have a 98 Impreza and I’m trying to find a new ignition lock cylinder to replace mine. The previous owner left just the tumbler and not the entire assembly. I cannot find the replacement for a 98. I find 97 but not 98. Find every year after as well. I can find the ignition switch just not the full assembly. Any help would be very appreciated. Thank you.
  20. PhoenixPhire joined the community
  21. ButtrockRockwight joined the community
  22. Watson_Derthehood joined the community
  23. subaruwillisco1940 joined the community
  24. StaticFoz joined the community
  25. winstonr1 joined the community
  26. 3 hours start to finish engine trans diff driveshaft axles mirrors ecu tcu fuel pump radiator and condensor out. nothing els worth keeping. and thats including driving it out of the woods and cleanup time.
  27. well i started i opted to just unbolt the trans and pull em seperatly. stripping a car is so much quicker when you dont care about the car the parts are coming out of.
  28. My bad, I think I got one of the pics backwards in my head, and thought the cam was totally ruined on both ends... the rear journal doesn't look totally ruined. There's still definitely some scoring visible on the cam in both the center and rear, though. But if it has a knock, it's time for an engine anyway.
  29. So the rear journal isn't good either. I would describe the front journal as trash where the cam had a definite wobble and the aluminum is creeping up the shaft. The AVLS ports look ok, other than a bit of sediment in the filter screen. The engine was run low on oil at one point and had developed a slight knock at idle so I was leaning toward a JDM replacement anyway, but this clinches it. The oil pump was resealed at the previous head rebuild.
  30. It looks like the cam ran without oil until it seized, from how trashed the rear journal is... If I were you, I'd probably be looking for an engine, not just a head. Would be a shame to put a new head on and then find the bottom end looks the same.
  31. i do not have a lift im honestly not opposed to cutting the subframe and radiator support ither. as far as junk yards not many left. chuck and eddies is prety much the last pick and pull i know of. boyds in norwich will still give a good price on a stripped out car. there wont be much left in this one thats still good. the driveline was the only good part of the car.
  32. Cam is broken The far end of the cam (non sprocket side) isn't seized, or at least it isn't now. Spins free, supported by the end and center journals. Probably seized at some point. Sprocket side journals are 'remodeled.' Will take apart the AVLS assembly and look at the oil ports. top view passenger side head broken cam cam wear cam fractured non sprocket side cam journal cam journal sprocket side center cam journal cam cap sprocket side cam slot
  33. Sometimes if it’s possible I’ll cut away the radiator support. Part car going to tue yard would be a candidate. Hey you’re in CT too, right ? Which yard(s) are you dealing with these days?
  34. I've pulled them attached. Yes the angle is significant. The other way to do it is to drop it out the bottom. The cross member and trans mount will unbolt. Raise the car or lower the cross member/engine-trans.
