Leaderboard
Popular Content
Showing content with the highest reputation on 02/02/19 in all areas
  1. Maybe check the timing tensioner? A failing one would make valve knocking sounds.
  2. did you lose the washer that goes between the strut top and the mount? it's about 30mm in diameter, maybe 4mm thick with a taper to one side (taper side goes up) This washer is what ride on the bearing inner hub and allows pivot for turning.
  3. To keep costs down I carefully purchased my engine from a parts yard. It had 127k km on the clock. Turned out the clutch was completely toast. Then I “bench” test as I wanted to make sure my wiring worked properly - and to assess the head gasket situation as I really didn’t want to do that job already, mainly due to cost. Here’s the first start up, exhaust mid section poked out under the rear door of our shed: Worked a treat! These head gaskets survived a 5min run at 4K rpm in soft sand on a beach with the temp gauge at 120*C (mechanical temp gauge plumber into the coolant out pipe in the heater circuit). I also froze the block in the first week of moving up to the snowfields - the replacement coolant didn’t have any antifreeze properties in it! Head gaskets survived after some very careful engine start, runs free seconds, sit a few seconds, start, run a bit long etc and repeated this until the radiator hoses were liquified. Then drove it to the season staff carpark where it was a much more sheltered. Left it to thaw out then swapped the coolant out. Four years later they let go! Anyway, bit of a long story there! I guess I’m saying enjoy the exeperience. Make some informed decisions and that’ll help with a successful conversion Cheers Bennie
