Everything posted by joostvdw
HID lights on the GL wagon
you could've put some candles up to improve your headlights anyways, the result is amazing nonetheless! do you have a bigger picture of the new bulbs? do they just fit in like normal H4's? (or whatever was in there)
just when i thought i was finished
they're heat shields, and, they shield heat inside there is some sort of fiberglass yeah, I removed the shields from the cat on my XT and found dozens of rust pinholes, out of these pinholes watery substance sprayed on the cat and burned off, causing smoke.
some questions on an engine rebuild (for a noob)
built up a killer compressor setup, that would be awesome, and something (fairly) new edit: wtf, something completely different from what I said is in my post ? edit2: oh, it's back to normal now nevermind
Its 1986 Again!
I know the automatics in europe did this, I have the original dealer brochure of the '88+ XT and it states that the 4wd comes on (or partially, since it's a clutch type center diff) when you turn on the windscreen wipers I would scan it for you, but since it's in dutch, I doubt anybody can read it
Built a High Compression MPFI but somethings wrong.
could the smoke just be some watervapor? I say drive it around town a bit and check if the coolant level changes, and like GD and other have said, check the intake gaskets, they're known to fail.
EA82t power differences in different countries
you know, this might be the first post that I actually understand what you are saying just for the record, what does the "gvwr number" state as the weight of the car? my XT weighs in at around 1250kgs. And is making 140'ish chp (mostly stock).
The last exhaust you ever need
when I was shopping for a exhaust, aluminized piping and actually everything NOT rvs was not recommended, the pipe it self will not rust as easy as normal steel, but the welds are open and not galvanised/aluminized or anything, so they will rust as normal steel. I have 2,5 inch from the turbo back and 2 mufflers (centre and end) for 650 euro's.
FSM XT section 6-3 page 139 needed
AWESOME!! I'm going to fiddle with it tomorrow. you guys keep amazing me with all the help and support I get here
As the title says, I need this page, I already have it as a .pdf file on my comp, but I can't read it (it has been scanned incorrectly) It has to be a XT FSM, years don't matter much I guess, it's for the blower motor. When I have it, and everything works out, I will do a writeup on how to permanently fix the stupid heater motor resistor thingy, the proper way. thanks in advance.
EDM XT's don't have a O2 sensor, that's true, but they don't have a EGT sensor either. I don't know about the cams, disty or ECU, if someone is interested, I can post the part number of my 88 XT turbo later on.
Differences in pre 1987 EA82T and post 1987 EA82T
you said the pre87 models had a direct waste gate control and 87+ had a boost solinoid? well, I have a '88 XT with spider and hotwire, but without a boost solinoid? how can this be? perhaps because it a euro? (yet another difference to add to the list)
best lube for getting a coolant line onto a rusty pipe?
yeah but brake/throttle body cleaner is very agressive and may eat away at your hoses
I need some measurements
well now, I believe thanksgiving is over? could someone please measure their struts for me I hate to keep asking, but I really need to know thanks
XT turbo injectors not firing? SOLVED!!
well, of course, the problem came back and the car didn't run for a while, but I didn't want to bore you with that , I do have good news now! read on... I have been having water problems since I've got this car, I had entire indoor swimming pools at the passenger feet. Of course, this wasn't very good for the car or the wiring, and it has come back to bite me. I was trying to dry it today and cut up some foam tape holding the wires flat under the passenger seat, and this is what I found: as you can see, those four wires, were the wires for the injectors , but now comes the strange bit, the wiring loom was all original, all tape original, no-one has tampered with it, so this bodge-job of solder and tape, was from the factory the only thing I could think of was that they ran out of wire and soldered it together, 18 years ago.... the swimming pool combined with this semi open connection made a nice electrochemical reaction, as can be seen here: the greenish stuff is copperoxide and the white stuff is tinoxide, it was some sort of paste, the water acting as a bonding agent and conductor, so actually, my car ran on water for a while anyway, after replacing that piece of wire, making new solder joints, taping them in properly, the car started up, ran perfectly and has been so since. happy ending don't you think?
making a vibrationless 4x4 wagon
is the noise rpm related? I ask because on my XT at about 3500rpm I have a resonance interior which makes a wa wa noise but this "may" have something to do with my 2,5 inch open exhaust...
headlights are acting up
in stock configuration the headlights are not switched through relay's (and if they were, the light would go out, not dim) most likely a ground issue, check all the major grounds and the mounting points of the headlamp casing (it grounds through the shell)
oh, sorry, that's right, you guys have thanksgiving well enjoy your dinner/holiday then, and I will check later. and thanks for checking your parts pile
one of you guys is bound to have the stuff lying around :-\, would you please measure the strut so I can search for look-a-likes...
hi, Could someone please give me the following dimensions? I need them to find suspension parts for the XT, so I can cross reference the original struts with other cars. The diameter and length of the part of the shock that slides into the front hub (I am talking about 4 stud 4x4). The diameter and length of the shock "arm" which bolts into the stut top. And finally the dimensions of the 3 bolts that hold the strut top to the body. (these are not entirely necessary, I can measure them myself, but if someone has them laying around, that would be way easier) I need to know this, because XT shocks are very hard/expensive to get here and this way I hope to find some nissan/honda/whatever that has the same shocks up front. (legacy +05 can be used in the rear) thanks in advance
finaly some real suspension for my wagon!!!
well?!
Has anyone ever had an EA82 transmission rebuilt?
don't know how much this would help you, but I got a quote of around 700 euro's, and that included complete new internals (except center diff)
right, just as mysterious as this problem developed, it dissapeared I replaced the wires from the ECU to the injectors, still ran like crap yesterday, fired it up today and everything was fine, drove around the block for a bit, not a single problem, I do hope it doesn't happen again, but who knows anyway, thanks a lot everybody who has helped me! you guys are my only (to be perfectly honest, together with xt6.net) source of information and help and haven't let me down!
mm, well, I could always try I guess... it sparks good though, how should/can I check the CAS? I have a 88 NA XT FSM in .pdf but I can't really find a exploded view of it or some sort of way to test them.
Ram Engines Did it again!
but that's the whole point of owning a 20 year old subaru or did I just step on someone heart :-p
yeah, I'm totally bummed right now, been working on this for 4 days straight and I can't think of anything that could be wrong, I measured everything a dozen times and it still looks like a problem in the body harnass (which I replaced with 2 straight wires) I will have a look at the part number, but after dinner, so check back later
