tunered
Everything posted by tunered
gary,i do this everyday.you can get a air hammer[a discount one will workabout 29 dollars] and you will have to get a panel cutter chisel for it.not familar with your car but,you will need to cut 2" back from where you want to replace,if its bad inside the door then cut it out there.the welding should be done with a tig but a mig with argon will be fine.it dosent take a rocket scientist to do this but it does take some time.i can walk and talk you thru this.this is for a faster job.if you want to really do it right you need to cut every spot weld[they make a spot cutter[looks like a 1/8 bit on the end of a 3/8 bit]and it cuts out the spot welds,this method is used on newer cars and insurance jobs.
new member
tunered replied to dynobob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
WELCOME
