tunered
Everything posted by tunered
just for the record i have a 91 leg sw awd 2.2 with 244,000 miles with no engine work done except,3 waterpumps,2 alternators,and timing belts,trans replaced at 200,000,new axles at 221,000,3sets of spark plugs and still on original wires.car came from state of washington and bought new in idaho,im 3rd owner with all the history,lucky? probally so.but still running fine.forgot to add this is a automatic,and been on a diet of valvoline all its life.
forgot to add that the wheel lock adapter will most likley be in the car somewhere,maybe glove box or ontop of your spare cover.that defroster switch shoild have a light in it unless the bulb is burnt out,unless they have changed them they are not on a timer,which means it will stay on till you turn it off or the car is turned off.
i can answer a few of these,the button marked P is your parking lights with ignition off,subarus wont let you leave your lights on because they go off with the ignition switch.the braking shudder is rotors that are warped,these can be turned and trued up if not too bad[may be cheaper to replace]the button on left side should be for rear defrost. hope this helps.
if the spring in the radiator cap was weak it would let the fluid go into the recovery tank,if it was to stiff it would blow out at the weakest point. there has to be some indication of where it came from,antifreeze is oily,and does not dissapear fast.you will have to locate this leak.i really dought if it is coming out of the rad cap,look for hoses that may be loose,weak,or possibly have a pin hole in it.
