Everything posted by bushbasher
Justy Rear End Alignment
yeah, I think you are right, its for toe in. Mine are frozen, so I cant adjust it (its really toed in alot, I think all justys are stock.
Justy
The rear of the justy would not be hard to lift, but the front has the steering arms coming through holes in the unibody, you wouldnt be able to lift it more than a few inches. The engine mounts would have to be worked on too to drop the motor with the front subframe. More of a challenge than lifting an ea81 or 82. Then theres gearing issues, no low range and pitiful hp. My suggestion? cut out the wheelwells, and put some 23-25" ATV tires on 12" rims. Cut off the rear behind the doors to make it like a little truck
My car is squatting
The car certainly could have come better prepared from the factory. The design of the tubular crossmember tends to get crap settling in it, holding in moisture and causing the rust. Im surprised its not seen more often. I broke mine in half when I crashed my lifted wagon into a big stump. The area where it broke was as thin as paper, all rusted from the inside. From the outside it still looked great, in fact it still had the original black paint on it.
Why dont you guys take I.S. to the next level?
It will happen eventually, but so far I havent seen anybody put the money and time into making a crazy subaru that those guys put into those trackers. If I make custom I.S. I wont be spending money to stick the axles in subaru hubs with undersized brakes, struts and short trailing arms, nor would I be doing it without putting a tcase in and trashing the tiny stock diffs. Spend money just on axles, and you are still restricted by gearing and diff strength, and the geometry limits of the stock suspension. Strut suspension will only go so far before the geometry gets all whack, same with the trailing arms in the back. The further the trailing arm droops, the more anti-squat you have. At over 6" of droop rear anti-squat is ridiculously high. Basically, to get the subaru to the next level, it requires a complete redesign of the whole package, not just bigger axles.
Bent Radius rod
I made a-arms for my subaru, with ea82 control arms reversed (swapped sides) to make the radius rods stick forward. I then heated and bent the radius rod to form an A, and plated the center to make it rigid. Mounts were welded onto the front xmember for the new bushing location. It worked well, but I didnt make my xmember mounts strong enough, and the whole design reduced approach angle. I scrapped the design, but the concept was solid and could be improved. Heres an in progress pic, the a-arm is not finished, and the xmember mount is not fully welded but in the final shape.
big lift questions
Ive never understood how the laws for vehicles got so nazi-ish in Aus. How many accidents are caused by afermarket steering wheels or modified engines? It seems like a whole pile of bulls#$% and tax money wasted for no real reason other than to give people a false sense of safety. Unless they collect tax money because of it Australia has so much rural area, one would think it would be more like Canada and rural US where there arent really any concrete restrictions, and often not even emissions testing. Do the majority of people support this, or is it something that slipped by and the general population doesnt care, or what? Dont get me wrong, Im not bashin Aus, my step-brother has dual citizenship and has lived down there since he was 16. I plan on coming down there some time to visit.
Wierd steering since 3" lift kit
Unless something is wrong with the strut tops like bad bearings, I think they an be ruled out. I would guess that the angle on the steering shaft joints is too tight and they are binding. What model car is this and who made the lift?
finaly some real suspension for my wagon!!!
Thats cool then, I guess it makes sense, these old subes run a crazy angle stock. V nice ride
Once your control arms are flat, you are probably at or beyond the point of ideal handling, as the dynamic camber increases towards positive camber in suspension bump/body roll. Going lower might not offer any performance benefits.
The end of my lifted wagon (56k warning)
There are a pile of older construction pics in my gallery. To mount the nissan case I welded square tube above the floorpans between the brace underneath the front seats and the rear wall of the floorpan. This pic is from the lada case mounting, but I just reused the existing structure for the nissan case: Also, 2" square tube was welded to the rockers to serve as rock sliders and to make a place for the crossmember to mount to. The crossmember doubles as a skid plate and as a way to mount the bottom brackets for the tcase. I dont have any pictures of the crossmember, but it was slapped together with scrap metal just to last 1 trip, so its not exactly a good model to copy. In the ea82, the front control arms dont sweep back like an ea81, so its much more difficult to mount the front diff. You would probably need 10" or so of lift to mount the front diff high enough so the axles fit over the control arm mounts. My solution was to cut and angle the ea82 control arms back 2", mount the whole front crossmember forward 3", giving me 1" extended wheelbase to clear 31s against the firewall. The radius rod lift blocks end up being made with a 1" forward offset. Doing all this allowed me to fit the diff up nice and high with a 6" lift. the rear was fairly simple, 4" lift blocks with some bracing welded in, +2 inch suspension lift. On the ea82, in order to maintain full downtravel with 2" suspension lift you need double DOJ rear axles. These come in some earlier ea82s. The kind with an outer CV and inner DOJ wont have enough travel. I welded up the front and rear diffs, it handled like rump roast on the pavement and I would venture to call it completely unsafe for the road. I would never consider it for a street driven rig, but on the trail its incredible. I would say that just having a welded front diff would have a greater impact off-road than just having the rear welded up. The rust is there, you just cant see it in those pics because thats the side I welded up to look nice. I never got around to the other side, and then I realized how bad the rust was structurally. My next rig will likely involve completely non-subaru independant suspension, or I may completely transcend the subaru body and go straight o a skinned tube frame in the style of a wagon, with subaru power. Or maybe not subaru power. I dunno.
The gearing was great with the tcase,3.65x1.59x2.0x3.9=45.3:1 reduction versus stock 22:1 Makes all the difference in the world. Here are some specs for those who dont remember/never saw: Nissan 720 tcase (previously lada niva tcase) 31" Grabber MTs on stock yota rims 6" subframe lift front, 4" subframe lift rear +2" suspension front suspension moved 2" forward double DOJ rear axles rock sliders welded front and rear It also had custom front a-arms at one point but didnt make them strong enough and they reduced approach angle so I reverted back to the stock control arm+radius rod setup. oh, and there are damage pics there, its just hard to tell. The radius rod in the front is bent, you can see some deformation on the lift blocks as well as a broken weld, and what you cant see is where the radius rod bracket ripped out of the unibody. In the back there was just the broken crossmember.
Well, my lifted sube is no more. It died fairly unspectacularly when I hit a good sized stump at about 40-50kph while offroad. It stuffed the front tire into the fenderwell, launched the car onto 2 wheels, nearly landed on its side, then came down and broke the rear crossmember. The car was saveable but rusty and I needed to clear some cars off my property so.. I scrapped it. Heres my last pics of it. I still have all the good parts and I intend to build a new one at some point. I have new ideas and need to start from scratch with a good non rusty car for my next project. Just another little tidbit: I swapped a Nissan 720 tcase into it, and was able to get it high enough by cutting the tranny tunnel that the output sat level with the rear diff at 4" lift. So, moral of the story is, yes a tcase lift is feasible and practical with 6" lift, you just have to cut your tranny tunnel a bit
son's 89 justy
the carb is most important for good mileage, get a new 02 sensor (its a computer controlled carb) and make sure the carb is clean. Check that all the vacuum lines are in order IE no leaks or plugged lines. The ignition system is electronic and works great, just set the advance as far as you can go before it pings under load. Use standard NGK plugs. My justy seemed to get around 35-37mpg with the stock carb but its a 4wd and I don't exactly drive like an old lady. The problem is that even with the foot to the floor minivans pull away from me at the lights.
Sand Rail - time to go from VW to Subaru
how much power does a 2276 vw motor make, cause one could hardly call an ea81 powerful. IMO you should go straight for an ej18 or ej22. The only difference would that you would have to do electrical work for the fuel injection on the ejxx motor. The ea81 motor would be carbbed which is simple to hook up, and the motors are really cheap, but you are only looking at <100hp With the ejxx motor you will get >100hp, fuel injection, and near the same reliability.
Subaru engined Trike.
I take it that that the motor is bolted to a vw tranny/irs then? I like it, but the stock sube aircleaner needs to go, it doesnt look the part
1988 Justy Problem. Help Please!
Heres my opinion on this: problems like this are almost always caused by a bad electrical connection somewhere, whether it is inside a piece of electronics or a corroded/broken connector or wire. Have a spark plug socket ready in your car, and next time it dies, quickly pull a plug and check for spark. You will need somebody to turn the car over though, though I guess you could leave the ignition on, and jump the starter manually from the engine bay. Just make sure its in neutral I think you can buy those little remote trigger things that hook up to starter motor. I think this has 100% to do with the ignition system. Its most likely not fuel, because the carb has a float bowl, which would cause the car to stumble before it dies completely if say the fuel pump was intermittant and the float ran out of fuel. Its not the computer because it is still possible to keep the car running without the computer connected, I've tried it. Its not a vacuum problem because even a huge vacuum leak will still allow a carbed car to run, it will just run badly. IF YOU GET NO SPARK WHEN IT DIES: Check the wires going to the hall sensor in the distributor. the wires typically fatigue and break. Wiggle them around/pull on them while its running, it might be the problem. A bad ground wire could be the problem, but its easy to test. When its not running, get someone to turn it over, and hold a piece of wire from the - terminal of the battery to a cleaned and conducting part of the engine block. If it suddenly runs, theres your problem. Ignition module could be the case, obviously the only way to test it is to replace it and see. Theres also a relay I think that puts power to the ignition module. When it dies, use a multi-meter to check that 12v is getting to the ignition module. You say you have the FSM, the pinout should be in there, otherwise you will have to do some detective work. Edit: Since signatures no longer show, I also have an 88 justy, and have gone through similiar hoops in trying to figure out why my car wouldnt work right. Turned out the carb computer had died, and at nearly the same time the screw holding the disty rotor had fallen out and slightly bent the hall sensor.
project porsche madness
someone made a rotary subaru rx, so it can be done, though I think you will have to make your own adapter plate. A fwd EJ transmission could probably handle 200ft-lbs in a light car.
Give me input for a monster 360
a justy isnt awd its 4wd. It would scrub like crazy on the street and handle all wacky. The 5spd fwd justy tranny is a nice compact little unit, it would fit in there no prob. It shifts with a single linkage sticking straight out the back behind the differential.
Rear diff swap?
the big reason independant suspension has gotten such a bad name in the offroad community is because typically IFS/IRS is introduced for handling in consumer vehicles, not for off-road performance. As a result, the systems are typically underbuilt for serious thrashing. This is mistaken as being an inherent weakness in the design. However, there is a reason that militaries all over the world are building off-road transports with IFS/IRS. It does perform better in most conditions. The hummer is a bad example because its so damn big and heavy, but hummer suspension on a lighter chassis would rock hard.
A Subaru Isuzu?? Slight 56K Warning
actually my mg also has fender mirrors, they are nice because you dont have to look away from whats ahead of you to see whats behind. Also, the blind spots are less.
Subaru must have been nuts!!!
I've redlined an ea82 and an ea82t, both seem to float in the 7-7.5k range I don't think I've found the point where the valves float in my justy and I've gone beyond 8k. There isnt really any power at that speed, though that will probably change with the weber I just put on The secondary venturi is quite a bit bigger than the justy carb. Just need to tune it and finish hooking up or throwing away vacuum lines. The justy seems to make most of its power at 4-6.5k
offroad axle braking remedie discusion
if you use the complete front hubs, axles, and diff from a nissan 720 4x4, make a custom subframe and a-arms, you can use the longside axles from the nissan truck on both sides of the diff, and it will end up within an inch of the subarus stock width. Stock subarus are about 61" wms to wms vs the nissans 55". I've done the measurements in the junkyard. You would gain locking hubs, beefier axles with a flange mount, a larger diff with more aftermarket than the r160, and bigger brakes too which is important if you want to go beyond 30" tires. Andyjo, I am currently studying mechanical engineering, and I can definitely say a tube does not take a higher load than a solid shaft for a given diameter, however it does give more strength for a given weight. Over 90% of the load on a shaft is distributed on the outer 1/2 of the cross section.
2.2 in justy
The justy diff is very similiar to the r160, just with a smaller ring gear (probably 130 or 140mm vs. 160mm) and a shorter pinion. The early justys used a weird spline size, whereas the newer ones are identical to the ea81 and ea82 subaru r160. Im pretty sure of that anyways. You could put a later justy inner doj on an early justy axle to get the right splines for a later justy or r160 diff. The diff ratio felt to be around 4:1 so maybe 3.7, 3.9, or 4.11 but my guesses are flawed because I thought 2 diffs had the same ratio when they clearly did not.
2.2 in justy
The justys rear diff is smaller than an r160, but an r160 could be made to fit. Im pretty sure the axle splines on the later model justy are the same as an r160, as is the drive flange. Gear ratios I'm not too sure on, though my 88 4wd 5spd justy definitely had a different rear diff ratio than a 94 ECVT 4wd.
anybody know justy???
The 6 wires for the carb are choke, idle jet control solenoid, Float bowl vent solenoid, and the main jet control solenoid.(I dont know the book names for these) The carb is computer controlled, the ECU is beside the steering column under the dash. I haven't ventured into fuel pump control cause it works on my car. I know the ECU doesnt control it because the fuel pump works with the computer disconnected. My advice is to try and follow the wires from the pump. Subaru is usually pretty good with wire colors, you should be able to keep track of them as they go through the harness.
