J A Blazer
Everything posted by J A Blazer
I thought I would share my story. Second owner, 2000 4-cyl OBW, 112K. Previous owner had at some point installed an Interstate battery. I had no problems whatsoever until a week ago. While idling all the warning lights (ABS and AT) came on. Car died and would not restart. Could jump start, but car would still die. Couldn't remove key from ignition (even with the instructions in the manual for manual over-ride). Security alarm would come on when I opened the door. Replaced battery and all is now OK; Sears confirmed that the old battery was 'bad.' I have never had a battery die as precipitously as did that one.
Axle Sale
J A Blazer replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Its definitely MWE -
While replacing the front axles on my 2000 OBW I noticed that the driver's side top strut mount moves quite stiffly (when compared to the passenger side), which would explain the audible groan when turning at low speeds. How hard is it to replace the bearing, or must the entire top mount be replaced? TIA.
Now that my 2000 OBW w/ 110K is back on the road with new MWE front axles, I still have a pronounced shudder on braking, easily felt through the steering wheel, and is at its worst when descending a grade while braking. Most likely causes? Tie rod ends? Inner or outer? Ball joints? Pads and rotors are fairly new.
