Everything posted by subiemech85
New headlight problem
subiemech85 replied to FlyScooby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
wiggle the connectors and clean with electrical contact cleaner, assuming they are electrically operated -
how bout making a complete assembly? that way I can replace the back and front sides, they are broke where they shouldn't be
I use the Walmart Super Tech oil filters ST3682 Subaru and ST3675 Cadillac - GM They are the best filters I can afford. I have torn them apart and compared with other brands. ps. fram is the worst
Oil consumption is high
subiemech85 replied to viceversa's topic in Old Gen.: 80's GL/DL/XT/Loyales...
access with the right tools 10 mm gear wrench 10 mm socket 6 in extension wratchet use gear wrench on oil pump and rocker covers, socket on oil pan -
ea81 ued to add 1 qt oil every tank of gas, 250 miles fixed by tightening oil pan, oil pump, oil filter, drain plug, and rocker covers -
the oil is full of little bubbles on the stick after it has ran, why?
:ghost: can I remove all lines from the carb? which ones are supply and return fuel
whoops?! in our shop class the two "bad" words we could use were "H"am and "D"ell
bad tick after started
changed oil and filter 15w40 pressure up around 60, temp around 30 sounds like lifter knock, is it due to thick oil, will this hurt anything, what oil should I run?
these are SILICONE wipers, that FILM is supposed to be there due to the material
Aussie Hatch Questions
subiemech85 replied to SuBaRiNo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
push in and turn to turn on parking lights with key off. -
What's required to pass colorado emissions? Is DADC any good, especially diesel?
Power Steering Pump Fluid Question
subiemech85 replied to Goatboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Will John deere HY-GARD regular viscosity work? I have used it as ATF with good results in my cadillac. -
ran over old hunt'n dog at work with a skidloader didn't see her laying behind when I walked around, backed over her SLOWLY, got tractor and lifted skidloader off dog. dog suffered broken hip, burned 2 sqft area skin on side in july. Not related she will be put to sleep before Thanksgiving sad, but it's time:dead:
found 14" pugs on a 78 504 diesel they are the 8 oval with 2 alignment pins looks like standard seat comes with 9 lugnuts, looks similar to pic
? driving fast/looks
subiemech85 replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Finally someone asked/noticed! My college instructor's relative ran it into a powerpole last winter. no major damage broke left pas. window, right headlight, emissions charcoal canister, plastic air intake, washer fluid tank, big egr hose, grill, bumper cover, brakes worn out, heat only on defrost, origional brakes and plug wires, stuck in 4wd hi changed brake cylinders, pads , shoes, hardware, window, air intake pipe, oil, filters, plugs, cap rotor, accel super coil, fixed d/r 4wd, delete emissions controls, When I went to drive it home, added gas, battery, oil, brake fluid only E-brake worked $50 runs great! That's what's up, more to come later. -
can of worms spilt with all the issues
What's ricer ricing? what's top speed of ea82 5spd?
Ah that smell - gotta hate it
subiemech85 replied to Skip's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I used to run purple ice $10, GM supplement $4, and brass eagle? sealant, the $2 stuff, no problms -
turns out it was ngr rgd -- trying to fix the problem How can I tell if the controller is bad? Am I supposed to hear a constant sucking? :cornfuzz: :cornfuzz: What's line 4 for? Where does the supply main line "properly" connect to the engine? How can I tell if the controller is bad? Where can I get a diagram? All lines are numbered on the soft rubber, the controller, and the connectors. :confused:
:eh: Check for blown or missing bulbs, or disconnected wires. I thought they were just reflectors in front!
Where does the main supply line connect to the other lines? Does the main line connect to the carb or the intake? American ea82 gl sw:cornfuzz: :cornfuzz:
