subiemech85
Everything posted by subiemech85
  1. you need to first 1. find the oil filter and change the oil and filter 2. that is where the pump is 3. SEARCH
  2. pic is on page 6 with link http://www.cardomain.com/memberpage/471729/6 That babe said a lot of bull to a lot of people
  3. problem fixed $120 later, write-up on page 5
  4. proboably going to cut up a junk tire from a pug wide baler belting would work, convenient sizes
  5. remove the cap ea81 wagon cap used to not seal
  6. went to exhaust pros for piping custom system of pipe going to and from glasspack in stock location, seems quieter or equal to ea81 stock pics of before and after are on page 5
  7. snowman do tell about mod for pwoer while keeping economy if you can
  8. super, did you check size?
  9. DO NOT BUY POWER MIKE WHEELS ALWAYS MAKE SURE DISK IS TIGHT
  10. cool guy repiled put text and pictures on cardomain http://www.cardomain.com/memberpage/471729/4
  11. the BIG boot at either left or right side by hood hinge I bought 25ft of green electrical stranded copper electrical wire, needed enough for ground
  12. going to exhaust shop Saturday, need to know what size pipe to run after glasspack tired of my ears ringing from glasspack dumping behind my seat
  13. sent an email hope for reply
  14. Mods accel coil 8140C, emissions delete, glasspack 22 mpg, and rising
  15. middle of guage, 45 when warm 85+/- when cold, goes down when warmed up 15w40 140,250+miles
  16. Is that whacky tobacky Only the whackiest ej18t is the filename
  17. I see you didn't buy a fifth plug, are you going to remove the EGR valve? Parts are as follows: EGR gasket fel-pro 70978 or 12-3075 air fliter wix 46016 oil filter wal mart/fram ST3682 dist cap MPI C631 add a fuel filter under the air box GKI 33011 slice n' splice GKI 33204 under car by axle Accel coil 8140C
  18. does anyone know the sizes for the inner and outer flaps, nearest 1/4in.? are they available for the front?
  19. I still haul a "luggage" in the front seat I found the problem when I added more "turning signal fluid" I removed the horn wires on the right side up to the point where they run with all of the wires, the one wire melted the insulation off about a foot in length IT'S FIXED ! what is the closest point to the source that I can "disconnect" the horn wires" notice my "D" horn
  20. Iowa boy says "LOOK NO RUST! " It's a beautiful keeper
  21. I hi-centered while drift jumping the snow banks along the fence line in the fields drove the dodge 4x4 to unstick myself by myself
  22. hijack at my hijacking pages
  23. second day of diesel power trains 404 I say check the clutch parts, springs, disk, torque dampening springs, alignment, and the obvious
