Everything posted by subiemech85
batteries and chargers
amp test
I have used this charger many times, never any problems
Can't bust crank pulley bolt (just a whine)
need better explanation of how to position bar top or bottom, left or right for remove
http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=9250 This is what I referred to as "jacking of the SOA battery" It seemed like jacking to me.
I-5 Oregon Wheel Emergency!!! Please Read!!
HOW IS THIS AN EMERGENCY? I bought 4 pugs steel 504 2 tires hold air, 2 don't, 7 lug nuts, $25
I have created this post due to the jacking of the SOA battery. I have a battery charger that is one amp. That's all it puts out, but it charges well. I assume 2 volts for each cell or service port. 6 ports X 2 volts = 12 volts
EA82 Wagon suspension mods?
Tennis balls, stuff them inside the spring center, this wasn't my idea, but car came this way pic to come later
EA-82 Carb recommendations?
weber 32/36 or holley makes similar
I need a locker
Tenino is 13 miles south of olympia
axle nut?
That's why I specified 3/4" drive ratchet, I have a nice Sears I am not afraid of returning! And you wonder why I return Sears and Break China so much :jollylaugh:
t-belt cover what if..... continues
http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=7890&highlight=cover "since I know a lot of people on the board have EA82s, and since we all know that the timing covers SUCK, what if someone (like myself) started to make them out of aluminum? If I did, who would buy them? Just tryin to figure out if it would be worth it " Caboobaroo
slow wipers
14+ volts makes them fly 10- volts makes them slow
I need a locker
I'm going to contact the company about what they can do, and about that Aus locker.
axle nut?
Remove the pin! Rust penetrant, 3/4" drive ratchet, long pipe, jump!
so how old do you think this thing is?.....
at least it's 12v
What ever happened to having them made?
I need a locker
check the options http://www.tractech.com/Products.htm
slow wipers
did you remove the plastic boot, then lube? check voltage, connections
oil pump seals
need to know part# for seal kit What's mickey mouse got pic? ea82
pcv location
once found an O'reilly guy that his dad worked on subaru 20 years ago, well, I had him look for a timing belt for an EA81 :laugh:
Up-dated my site
picture page brat column brown bar blocks words the "FIX" opera, toggle between user and author mode, and F11 otherwise, great
Another Goofy Idea--Storage in Spare Tire Area
used to keep spare oil in the rim with the tire u-way, ea81 removed tire to check timing, and pcv valve
posi-traction
is it possible, what's required? My idea for it is you put it in 4LO for the occasional "Whoops", not driving, that's what 4 HI is for
anyone seen any more wheels like this
opera has been giving me problems 1x not failed yet
or click to go one away, then click to go back, but THIS PROBLEM NEEDS TO BE FIXED
