Everything posted by subiemech85
New headlight problem
wiggle the connectors and clean with electrical contact cleaner, assuming they are electrically operated
what if.....
how bout making a complete assembly? that way I can replace the back and front sides, they are broke where they shouldn't be
Even MORE coolant system troubles ::UPDATE::
lines are not related at all, but good time to get rid of emissons contorls, which you already started to break. do you have heat, do you have jiggler, if not, drill small hole what's a Pee Ho?
oil filter
I use the Walmart Super Tech oil filters ST3682 Subaru and ST3675 Cadillac - GM They are the best filters I can afford. I have torn them apart and compared with other brands. ps. fram is the worst
Oil consumption is high
access with the right tools 10 mm gear wrench 10 mm socket 6 in extension wratchet use gear wrench on oil pump and rocker covers, socket on oil pan
ea81 ued to add 1 qt oil every tank of gas, 250 miles fixed by tightening oil pan, oil pump, oil filter, drain plug, and rocker covers
thick oil noise
the oil is full of little bubbles on the stick after it has ran, why?
carb emission lines fuel
:ghost: can I remove all lines from the carb? which ones are supply and return fuel
oops!!!
whoops?! in our shop class the two "bad" words we could use were "H"am and "D"ell
thick oil noise
bad tick after started
thick oil noise
changed oil and filter 15w40 pressure up around 60, temp around 30 sounds like lifter knock, is it due to thick oil, will this hurt anything, what oil should I run?
Rear defrost grid no-go, but fuses/switch fine-what's up?
use a test light clip to ground point to grid test each line until no light, that's where the break is, light should be dimmer as you go from side to side multimeter doesn't work
now with wings
these are SILICONE wipers, that FILM is supposed to be there due to the material
Aussie Hatch Questions
push in and turn to turn on parking lights with key off.
colorado emissions
What's required to pass colorado emissions? Is DADC any good, especially diesel?
Power Steering Pump Fluid Question
Will John deere HY-GARD regular viscosity work? I have used it as ATF with good results in my cadillac.
Loyale vs. dog
ran over old hunt'n dog at work with a skidloader didn't see her laying behind when I walked around, backed over her SLOWLY, got tractor and lifted skidloader off dog. dog suffered broken hip, burned 2 sqft area skin on side in july. Not related she will be put to sleep before Thanksgiving sad, but it's time:dead:
will they work - pugs
found 14" pugs on a 78 504 diesel they are the 8 oval with 2 alignment pins looks like standard seat comes with 9 lugnuts, looks similar to pic
? driving fast/looks
Finally someone asked/noticed! My college instructor's relative ran it into a powerpole last winter. no major damage broke left pas. window, right headlight, emissions charcoal canister, plastic air intake, washer fluid tank, big egr hose, grill, bumper cover, brakes worn out, heat only on defrost, origional brakes and plug wires, stuck in 4wd hi changed brake cylinders, pads , shoes, hardware, window, air intake pipe, oil, filters, plugs, cap rotor, accel super coil, fixed d/r 4wd, delete emissions controls, When I went to drive it home, added gas, battery, oil, brake fluid only E-brake worked $50 runs great! That's what's up, more to come later.
ea82 no heat
can of worms spilt with all the issues
What's ricer ricing? what's top speed of ea82 5spd?
Ah that smell - gotta hate it
I used to run purple ice $10, GM supplement $4, and brass eagle? sealant, the $2 stuff, no problms
ea82 no heat
turns out it was ngr rgd -- trying to fix the problem How can I tell if the controller is bad? Am I supposed to hear a constant sucking? :cornfuzz: :cornfuzz: What's line 4 for? Where does the supply main line "properly" connect to the engine? How can I tell if the controller is bad? Where can I get a diagram? All lines are numbered on the soft rubber, the controller, and the connectors. :confused:
Alternator question
:eh: Check for blown or missing bulbs, or disconnected wires. I thought they were just reflectors in front!
ea82 no heat
Where does the main supply line connect to the other lines? Does the main line connect to the carb or the intake? American ea82 gl sw:cornfuzz: :cornfuzz:
