Everything posted by subiemech85
brighter lights?
M2 combine we use 5 of them to lite up the field, we also run 2 alternators, 200 amps? total we buy them from Carquest
window sticker
During my JY run, I saw this sticker it said air conditoned by subaru what's the meaning of these stickers? PS. I also picked up a right front t-belt cover, cap, and Factory tool kit - $5
brighter lights?
Madrid, centennial book said we are in the middle of Iowa.
Good Additive for PS?
search shutup for my post about trans-x good stuff http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=6433&highlight=transx
brighter lights?
The OSRAM SILVERSTAR is the best possible choice at present for halogen headlights because it offers the highest light output. osram.com
this will make you laugh
I have a custom exhaust removal system. It's better to remove than leak.
Hard to go over 55
Keep your brakes released, and shift @ 3,000 rpm
Tried my hand at Body Work, for the 1st time.
Just remove and beat the hood like I did.
weber power source
what cars have webers for ea82? are adapters needed?
local JY run
Carney's 515-232-5874 or 1-800-262-3808 Ames off of Hwy 69 by B-BOPS You may pull-it-yourself if you ask. ask them where the subarus are on the aerial photograph, makes hunting easier, also ask for a current list of the cars in their "public" yard They are super-nice to work with.
local JY run
:banana: Went to the local JY Carney's Ames, IA $80 for right front headlight assembly, and corner lamp, heat-air controller, fuses, trim panel for around fuse box, 4WD red shift knob, owner's manual supplement and other info, dowel rod Trecel tilt-o-meter, shft knob, and 4wd knob Left 5 minutes before closing time! They are really nice.! :banana: ?How do i set up the Trecel tilt-o-meter?
Recommended battery ?
$20 interstate blem they remove the lable for you go and read consumer reports about batteries post 30,000
Favorite tools and other "must haves"
I have used month old root beer left in plastic cup, worked great have also used cold, fresh beer, hot old beer, and fresh cola, all have worked it's a matter of what's available and convenient the ea81 car was washed once a week
a couple of brake related Q
read the manual! p.68 part one ea82 http://finleyweb.net/default.asp?id=142
bungee cords torque wrench, beam type socket adapters pry bars self drilling sheat metal screws gear wrenches extensions spark plugs, socket repair manual something to dissolve sticky green or white battery growth -- beer or cola, quality doesn't matter crc 5-56 best lube-penetrant found-- spra-loos at $1 stores tow strap duck tape sealing foam in the can spray silicone lube jumper cables fuses wire multi-meter air hammer impact wrench spotlight flashlight trouble light power inverter air tank adjustable wrenches chop saw cutting torch welder portapower rivet gun drillpress clamps spraypaint angle grinder press pullers battery charger battery booster you can also read the VW survival list @ http://www.cyberus.ca/~markus/vw/checklist.txt also http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=8160&highlight=list Jack and other on-board tool/part recommendations
check this ea81 out
this guy asked about his carb icing over about a month ago.:santa:
GM alternator conversion
need pics and write-up bought correct plug for gm alt will run 200 wats of accessory lights
Help no spark
search for ea81 no spark mine in sig no spark, not coil, or control module
Power steering pump whining -bad?
Trans-X works amazingly well in power steering systems. Metal Blue round can, big X
How do the wires connect to change subaru alt. wiring to GM alt. wiring wanting to run 100+ amp GM 82 Cadillac alt
dead dash clock
85 wagon mech. dash clock has no time display. Lights on HMS buttons work, what's wrong?
Ausie? pics
found the site reading a google cache archive http://home.brisnet.org.au/~cameronn/
70s Subaru Shirt
I want at least one Large I would like black, white, or gray preferred one of each if not too expensive
heat control
?how to test the functionality of the heat controller -- vac. operated. mine seems to not work, but every thing else does:confused:
If this has been posted sorry...EBAY ITEM!!!
i want one black or grey-preferred medium:clap:
