one eye
Everything posted by one eye
  1. I have a little portable DVD player I can bring............................ Jeff
  2. Wow. Jeff
  3. No one is coming with me ................ other than the guys that are wheeling Jeff
  4. Bill it would be a good Idea but there has been no problems so far, none of them have spun off to the side............ one guy has been able to blow the strut off the bottom side and all the blocks stayed in there place....... Jeff
  5. T-roy has made it back to my place as he has blown his motor.............. he is getting bolts right now at the local Lowes....... but we have another motor here at least, it has been a long assed day so far.............:-\ Jeff
  6. T-Roy made his way up to my place this weekend and we made his car a little taller....................... Before.................................................... Now The front is up.................................... This is just a 2" lift like all the others....................:grin::banana: Jeff
  7. STI WOLF is at my house right now, Will Woody and I made a lift for him yesterday so its going on tomorrow first thing along with a welded rearend........... My cars are all in good shape to go, Pat is going to change out the open diff with a welded diff............ other than that, John bring yours over and we can weld the diff up............. bring some gear oil too. Jeff
  8. Where are you located? Island Co????? Jeff
  9. T-Roy bring some tools and I'll sell you some parts you might need off that 83 wagon Jeff
  10. Bob it sould be near or right under your drivers side rear door in front of the tire.................... Jeff
  11. You will have a welded rear end!!!!! Jeff
  12. A 32 hour Drive and you can get one here in Mount Vernon Washington, its and 86 GL D/R for 250 bucks................. I just had put that out there, but really there are a billion and one Subaru's here, I could find you one and meet you half way..................... I would drive to Salt Lake City UT............................ http://seattle.craigslist.org/sno/ctd/1319458456.html Jeff
  13. You only got one picture? Jeff
  14. I'd fix er up and keep it as a DD, I regret lifting and wheelin my red Brat, I wish someone would have told me to just leave it stock and nice........... Jeff
  15. No you are wrong, I have 2 cars with this lift, and this is how it is.................. For the most part you are going to have tire ware no matter what, if you do drop the front crossmember you are going to loose all the ground clearance. So do not drop it. I've put a ton of these lifts on and John (Marcus56) is the only one with trouble, he even has the 15* blocks in, I have straight blocks in mine and have very little camber issue. I just took this picture this morning this is how it sits.......... Here are a few more to just drive the point home That should give you an Idea............. Jeff
  16. looks nice, you got more pics????? Jeff
  17. You can speak for me anytime Will!!! I'm in on this deal, wouldn't take long at all...................3 hours max.....................As long as all the parts are there it goes on quick. There is about 10 bucks in bolts and 20 bucks in steel at the most. Jeff
  18. I'll probably have a spare seat from time to time............ your welcome to ride with me if you want. Jeff
  19. I got two rearends just waiting to be welded, two rear EA82 axles, one extra radius arm, and all I need is one more front axle, I got all my extra oils and towles needed to do a big change over if needed, I hope not but I'm going to be ready, Also I have a gas can That will be full of gas just in case........................... Jeff
  20. Got Car two ready now too.............. Car one is still awaiting its change.............its just waiting:grin: Jeff
  21. If it is from a 4 wheel drive chevy your ok, if it is 2wd your going to have a hell of a time, the center hub is smaller than the rear hub rib and you will have to grind the wheels or the rib on the drum. As for the front you will also have to grind the centering nubs on the front hub, its a lot of work but if its all you got to work with you can make it happen. Jeff
  22. Ohhhhh man John, I wouldn't want to mess up the headliner on that gray wagon..........................:lol: Jeff
  23. Not for about a week or so....................... Jeff
  24. That Gray wagon is now sitting on the ground right, you might want to check it out....................... Jeff
