239
Everything posted by Loyale 2.7 Turbo
led dome light 1980 brat
Loyale 2.7 Turbo replied to disom93's topic in Old Gen.: 80's GL/DL/XT/Loyales...
To let the Pictures display here, first you must upload them to a web server that host pictures, such like Flikr, Photobucket, Facebook, etc... then do a Right click on the Picture and copy its URL address, then come here and start a Post, you'll find a green square down under the A and the Icons on the upper tools, hit that square and paste that URL address in the Dialog Box, and Voilá! ... The Picture must display here. Kind Regards. -
You're welcome! Now I understand ... ... You'll need the front crossmember from a manual trans EJ. It must be Modified by Drilling or Notching, to accept the D/R mounts. Kind Regards.
There are Smaller LED panel alternatives, which are Cheaper. These supposed to have resistor that protect 'em from current fluctuations / overload (in example when the Alternator's regulator goes bad and sends 18V) Sometimes cheap isn't right for the application. Kind Regards. -
This is your Answer: You need an Adaptor Plate, or buy an EJ Dual Range Transmission from Latin America, Asia, Australia or New Zealand... unless you be Lucky to find one of the very Few Dual Range EJ Transmissions for sale in USA, like this one: ~► http://www.ultimatesubaru.org/forum/topic/144426-ej-dual-range-trans-for-sale/ Kind Regards.
It is quite simple, no writeup needed, just remove the old standard bulb, and place this in its place: ~► http://www.amazon.com/Putco-980116-Universal-Dome-Light/dp/B0016KBQ0G I did it years ago... ► Edit: I forgot to say that the Panel comes with different plugs, shaped as the different bulbs used in dome lights... Kind Regards -
car has carb/timing problems
Loyale 2.7 Turbo replied to Stretch111967's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Welcome! The Backfires and High Speed idle sounds to me like vacuum leaks, plus the Hitachi Carb might need a Rebuilt; The idle speed screw is next to the accelerator cable's plate at the Carb, but if it was working fine and nobody has touched that screw, the problem could be the Carb itself, and / or vacuum leaks. The timing on the Early carburated EA82 should be adjusted at 8º +/- 2º, but I run mine, which also is 1985, at 20º and I removed the Crappy Hitachi carb, and swapped in a Weber Carb = Better low end torque, better response and cleaner engine bay, without the Spaghetti of hoses around... Good Luck, Kind Regards. -
Rebuild Engine vs Junk Yard Swap
Loyale 2.7 Turbo replied to spicypeanut's topic in Historic Subaru Forum: 50's thru 70's
Why not to make one engine from the Two? I mean, to disassemble the Junk Yard one to take its heads and do the Valve job; then decide which block you'll use by seeing its internals. Kind Regards. -
In order to see if your subie has the Nippon Denso or the Hitachi distribuitor, you must provide us with Photos; but however if your subie is Carburated EA82, then the 2WD (FWD) models came with the Nippon Denso, and the 4WD (AWD) models came with the Hitachi. These EA82 engines doesn't like expensive Sparkplugs, they work the same with the Stock ones, and there is a version with grooved electrode; part number: NGK BPR6EY11. About Oil Filter, there are three sizes that fits the EA82, the "official" one is Medium sized Purolator L-24457, then comes a larger one which is the Purolator L-20064, and the Shorter one, which is the Purolator L-10028; I've been using the last two ones without issues since many, many years ago, but I do preffer the smaller one for faster pumping on cold starts, plus a li'l gain in oil pressure... these engines doesn't need expensive oil filters, just good quality ones. See: ~► http://www.ultimatesubaru.org/forum/topic/136206-motor-oils-and-brands/?p=1145764 Kind Regards. ► Edited to add the web link.
Sorry for the Thread Hijack... The LADM (Latin American Domestic Market) had the 1.5L EJ15 engined impreza in the very basic model: Manual transmission, no 4wd nor power windows nor power locks... while the 1.6L EJ16 engine came with the same basic impreza, but with Automatic transmission. Seems like the 2000 impreza from the original poster is 2WD automatic EJ16, like the LADM Specs imprezas, see: End of thread Hijack... Kind Regards.
Welcome! Post photos of it, especially from the valves' covers; so we could help you in a Better way. The EA81 could came factory with Solid Lifters, or Hydraulic Lifters; with a Carter Carburator or with a Hitachi Carburetor, also Twin Hitachi Carburetors... Kind Regards.
Well, after fourteen years and 221K kilometers ... ... that timing belt could be about to snap in no time, maybe already has jumped a couple of teeth! ... it happened to my Subie some years ago, the Timing belt was so old that had some missing teeth. I Kindly suggest you to check that Timing Belt / Replace Timing kit as soon as possible. Kind Regards.
Another Noob to the Subaru
Loyale 2.7 Turbo replied to Whelton89's topic in Meet n' Greet. Your USMB Welcome Center
Welcome! Nice Legacy. -
EA82 w/ new Weber popping back through carb
Loyale 2.7 Turbo replied to Trident's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This is great advise: But if everything is alright (Timing, Plugs, Wires, no vacuum leaks) let me tell you that once I saw an EA82 doing the same: Popping thru the Carburator, and after checking timing & Wires, the culprit was the Carburetor itself... Somehow, I'm starting to think that your Weber might be inadequately assembled ... Kind Regards. -
This is my Vote: Because beside I like Yellow, the Dark Mustard Yellow without shine of the Old-School Landcruisers were very well fitted for an awesome & Serious offroading machine, like yours. Kind Regards.
EA81 Window Adjustment.
Loyale 2.7 Turbo replied to TheYeti's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Somehow it is an "Trial and Error" exercise... The setup is pretty similar to the Third Gen Leone (EA82) In my case, what I did was to close the door without the door's card and lift the glass 'till it was in the proper position; Then retighten the screws at the two stops, and try to open - close the door with the glass full up. Repeat if necessary... Kind Regards.
