239
Everything posted by Loyale 2.7 Turbo
smoke out exhaust
Loyale 2.7 Turbo replied to Joey Joe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Weird; but White Smoke Also can be due a Bad P.C.V Valve... -
Me Too!
Lubricants & Additives / Myths & Reality
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Shop Talk
Well... me Too! But there are Teflon Based Additives for Gearboxes, Differentials, Power Steerin` pumps, etc... -
HID lights on the GL wagon
Loyale 2.7 Turbo replied to suberdave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Oh my God! ... ... 700Watts output? ... I Really will Love to see a Pic of That Setup!. Could you Put here some Pics? Well... Here in my Country, due to the Lack of Regulations, we can Obtain the 9104 Rally Bulbs, instead of the Standard 9004 ones. The main Difference `bout, is that the 9004 got Wider (Horizontally) Element, so Wider / Diffuser light is done by 9004. Instead, 9104 got Larger (Vertically) Element, so 9104 Bulbs Reach Twice the Distance with Twice Brightness, and more Clear Spot of Light. Look this Image for more Info: Those 9104 are rated 100W High / 80 Watts low (Real Output) are Flösser Brand. Just "Plug and Play" Well... I`ll like to know More `bout the HID Conversion for Subies... What is the Greatest Advantage? More Brightness? More Distance can be Reached to Illuminate? How is the Pattern? Thanx! -
This is me, puttin` 20W-50 Motul oil in my EA82 Weberized White Subie : Well... This is a PTFE (Teflon) Based Coolin` System Treatment... ...What do you Think `bout? -
honeycomb with 3rd eye?
Loyale 2.7 Turbo replied to tsutomu's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I Like how those Subies Look! ... -
what else for the ea to ej swap....
Loyale 2.7 Turbo replied to Urabus-84HBDR's topic in Subaru Retrofitting
You need first to Know Which Engine EJ series will be Used, then, to Find the Adaptor to Install it to the EA Gearbox... ...Then comes a Lot of Things... I Think you should Decide / Obtain the EJ Engine First... Could you Post here Pics of that car? Good Luck! -
And How About for Gasoline Additives? -
FLASHER Problem - DRIVING ME CRAZY!!!
Loyale 2.7 Turbo replied to TheBush's topic in Old Gen.: 80's GL/DL/XT/Loyales...
About Greases... Bgd did Mention something about Synthetic Grease for Axles (Now I Know that`s the Same thing called C. V. Joints ) And with my Experience, I determined that for my Subies is Better the Meistersatz Brand (Made out of Pure Graphite) ... but, How about Synth. Greases? What is your Experience with `em? ... Which Performs Better? Thanx! -
Really Thank you Soo Much!, You are So Kind! -
Thanx for your Kind Replies! I Didn´t Understand this one: * * * Nice to Know! ... but What is exactly Slick 50? Well... About Greases, I Have Tried many Brands for my Constant Velocity Joints (Axles... I Dunno the Right Translation from Spanish) and Bearing of my Subies... and the Only Grease that Works Very Well and Develop Greatest Performance, Durability, etc... (For My Subies) is This: Also, I Use the Large Rubber Boots (those Used in the Gearbox part of the Axles) in the Wheel Parts of ´em. Those Last Longer! -
Say What? As I Said... (Check Post Nº 2 on this Thread...) That´s the Place. Good Luck! -
EA81 Wagon CD Changer
Loyale 2.7 Turbo replied to mikeshoup's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes! I Agree... I Helped last Year a Friend to do That, we Installed the CD Changer in the Glovebox too! -
Suggested Spark Plugs, Oil and filters
Loyale 2.7 Turbo replied to nathan.chase's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I Agree! ... But for Pingin´ I Also wanna Suggest to Check the Ignition Timin´ Good Luck! -
ea82's are expensive
Loyale 2.7 Turbo replied to HATCHY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Holy Cow! In that case, I Suggest to Swap a EJ Series Engine instead... -
Welcome! About the Carburetor, to deal with the Hitachi stock is a Headache; I suggest that if the stock is Bad, Change it with a Weber 32/36 Carb. Its the Simpliest way to Increase Performance and Gain Beautyful Simplicity in a Carbed EA81... but Check Emmissions Regulations in your State First. Also you can Install the EA82 MPFI Intake, here you can do a Search ´bout, there´s a Lot of info. Good Luck!
Ha i Pulled out a Sube!
Loyale 2.7 Turbo replied to Prospeeder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nice! -
Thanx to All replies! , Very Nice info. I didn´t Knew... I was about to Buy a Bottle of PTFE engine Treatment for my Tickin´ EA82, but now I Don´t! Other Question, Between Petrol Based Oils, and Minerally Based Oils, Which one is Better for my Subies? (EA82 and ER27) I Use Motul Minerally Based Oil 20W-50 in Both (Also in my Dad´s 1969 Mercury Comet) ´cos with it, the Tick is Almost Gone, but maybe you know Somethin´ about Mineral Oils that I don´t Know... Thanx!, Best Regards. JesZeK. -
synthetic oil MYTHS
Loyale 2.7 Turbo replied to operose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
synthetic oil MYTHS
Thanx for the Info! ... I didn`t knew that new Formula Synth oil doesn`t Damage seals. -
synthetic oil MYTHS
Well... I just wanna Add that the Oil Doesn`t make any Damage to any Metal, so the Leaks come due to the Seals. Let me Explain: Older engines came with the Seals Not Designed to Resist the Synth Oil, which damages the Seals as Bad Brake Fluid (With much Alcohol content) will Damage brake Seals... When Synth oil first came, Sellers give a Li`l Paper Sheet, with the Warnin` About the Seals. so Older Engine will Leak with Synth Oil due to Seal Fail against Synth Oil. Newer Cars come Prepared for it. -
Oil recomendations for 120k EA82?
Loyale 2.7 Turbo replied to Milemaker13's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes! ... I Use Motul 20W-50 Always (No Snow in Tropics) and my EA82 has over 245K With that Brand of Oil, due to its Mineral Base (No Synth, No Petrol.) my EA82 Performs Smoother, and the "Tick of Death" is Almost Gone... -
Rear wheel brake cylinders?
Loyale 2.7 Turbo replied to riverstream's topic in Old Gen.: 80's GL/DL/XT/Loyales...
2WD or 4WD? ... I think the EA81`s (Subaru Leone) will fit, but better Idea is to Take the Part with You and search (Maybe in Junk Yards or in a Car Parts Store) with it; due to the Fact that Measurements of Parts usually Vary from a Country to Others... Good Luck! -
Usually, some Mechanics use to Recommend / Sugest the Use of "Magical" Additives, some Compleately Refuse to Use `em... ...Some of that Additives claim to Run Engines even Without Oil! Increasin` the Slick Level of Internal Parts; We saw in a T.V. Spot, someone runnin` a Small Block V8 Engine without the Oil Pan, :-\ ... Some Treatments use PTFE (Teflon) some Don`t and say that PTFE can Ruin the Engine ... What do you Think `bout? One of the Top seller Brands on our Market, is QMI ( http://www.qminet.com/ or: http://nooga.com/calar/index.html ) Also Metaloil, etc... What do you Think `bout? ... How was your Experience with those Special Additives?
