Everything posted by Uberoo
Front bearings are driving me insane!
I have had enough of autozone.I just told them to give me my money back all 129.90 of it(core+axle) so I went to schucks and bought a new unit with a lifetime warrenty:banana: for 100.Schuck's computer actually differences between SOHC and OHV 1.8 engines unlike autozone which just gives random numbers for the engines.Autozone kept bringing me an axle with 25 splines on the DOJ and saying that was the correct part(1987 GL wagon,Carbie,with 5 speed DR,I DONT THINK SO) Although axles with a lifetime warrenty ROCK!!!
Trying to find pics of the craziest lifted 95-99 legacys
bugger
Wiring Questions for those in the know
just kinda rambling with a million subaru related stuff in my head.ie why wont spacer on spindle play nice and let the axle pass through like it's supposed to.Or thinking I will install the new fuel pump.Where to get a tubing bender on the cheap(powersteering lines need adjustment to clear ej22). all the way to bumper designs and lift kits...
Buying a 1984 DL on Sunday...what to look for?
you can make it so its 4wd.What do you plan on using it for?
I didnt unbolt the knuckle.Swaybar and tierod end...
I was able to stuff various things against the spindle houseing and nut to pull it through.But then I couldnt get the DOJ to go on.. do I put the DOJ on first or the CV first..
yea its the spacer.There seems to be alot of vertical play in the spacer.If I move the spacer upwards I can see a gap at the bottom of the spacer about 1/8",if I move it downwards I can just see the top of the spacer.I dont happen to have any metal and my socket for that size seems to have dissappeared.that and its sunday and I have no money.can't run to the bank....argh just as I try to actually get something done on my subaru I hit several snags...
Today I decided I would get off my arse and change out the driver's side front axle.Ive had the axle out for like a month,and ive had the new axle sitting in the back for about 2 weeks.Anyway As i go to put the axle it it keeps getting hung up on the inner bearings.I try to put the bearings where they need to be but they just slide down to where the axle's splines get stuck on them.Help.What do i do to get the bearings to stay where they need to be?
What about the beastly of the beastliest-albies EA82 Wagon with 300 hp and 33" boggers.
which wire off the switch itself?I pulled the cover off the steering colum and there are two wires from the switch.Then Iam running the ea starter relay... So for EA starter just tap in between ignition switch and EA relay?If I had everything wired into the ignition switch wouldnt it give power to the whole ej harness?And the ea switch is connected to the EA relay.So one wire right?Or do I just know far less than I think I do?
Dash pinout?
thank you.
which wire do I connect to ignition switch?I decided to go that way instead.I figure it would be nice to turn the key and have the engine start of the existing chassis wiring.
10 second brat(brumby)!!!
what about wrx motor in a hatch...
Contemplating a new weber carb...
try to find the carb in the junkyard.
Dash pinout?
Does anyone have a pinout of the wires going into the instrument cluster on a 1987 GL wagon with analog dash. Or more to the point the wires for tach,and charge light.And where do I run the wire for a external voltmeter gauge.
Power steering lines?
After seeing an old post of how the ea pump would interchange with just a few mods.I tried it.It works just had to enlarge the mounting holes for the pump itself. SUBARU'S = GIANT LEGO SETS
In the ea-ej write up it says that the EA82 power steering lines just bolt up to the EJ power steering pump.My case must be special as they don't.I have two female connections that butt up agaisnt eachother.How do I change the fittings?
ej fuel lines?
what about for the EJ there is like 2-3 lines that are the same diameter...
new rig build.......56k beware
what tire size you planning on?35's?37's? 40's(oh god that would be massive)
so you bought the 84 huh?Sweet.Thanks to you my adapter plate is done.everything motorwise is done.Come to think of it I just need to drop the motor in,wire the harness into the body and sort out fueling...hopefully I will have most of that done tomarrow. So for the 84,lets see Carbed Ej22 Transfer case Presuming lift... Show pics when done!
ej fuel lines?
fuel in is the only line that needs to be fi grade?
- 2wd wheeling
ej fuel lines?
the Ej22 has two fuel rails.so does that mean two fuel lines?If so how do I go from one output on the fuelpump to to lines?Have a Y in the line?
EA82t+Rodknock=EJ swap.
hehe he was asking if he should wait for ej22T(I know wrong name) not build up a Ej22e. As for your answer.look in the classifieds for a rearended/rolled/other wise totaled wrx.Take motor,tranny,and engine wiring harness.Then you will have one killer car.
Whats in YOUR heads?
You don't want to know what's in my head.
