Danbob99
Everything posted by Danbob99
  1. This is not correct for all machinists. I work with several in the local area that have manufactured jigs to hold the PHII heads with cam boxes intact. This is why I recommended trying to find someone that is familiar with machining the Subaru head. Dan
  2. As long as a maching shop is familiar with the Subaru head, they will not need to disassemble the cam box. The only reason they do on many other makes is to ensure all valves are closed. This is not necesary on the Subaru heads. So no, they will most likely not need to remove the cam boxes. Just make sure you clean any residual metal shavings out of the head after machining. Dan
  3. The H6 Valve adjustment is due per subaru at 105K for an inspection. They are shim over bucket lifters and use a different size shim than all the 2.5 motors. They are the same size has WRX valve shims. The valves tend to wear tighter and when adjusted I try to leave them on the loose end of the adjustment spec. (to allow for future wear, and overtight valves cause misfires, where as a loosely adjusted valve does not.) Most times the valve adjustment is still within spec at the 105K mark. In my experience most are still withing spec past the 120K point as well. Dan
  4. The SOHC engine heads can certainly be removed with the cam boxes and cams still installed. I would actually recommend leaving them on. It's a pretty lengthy process to take them apart and clean all the silicone. If you do have them apart though, the manual outlines an incorrect procedure for resealing the cam box to the head. You need to run sealant all the way to the cam journal (the fsm has you stop 1/8" short of the cam journal) Anyways, you can leave them on, and I would recommend doing so. Dan
  5. The o-ring on the compressor are real common leak points. The condensor is another real common leaker (Sounds like that has been replaced though.) If the compressor is cycling still, but you are getting warm air it is likely very low on refrigerant. You could also have a plugged expasion valve if it is not cooling properly with a full charge. Check the charge on it and report back!
  6. The engine is a single cam motor, under the slow rpm of cranking it is pretty unlikely that you would interfere valve to pistion. A new timing belt install will certainly tell the tale. As far as timing marks, there is a mark on each cam, on the right side of the motor (passenger side) Line up the mark to the crack between the cam case and the head. On the passenger side there is a small tick at the top of the inner timing belt cover. I generally use the marks on the new belt and align them with the cam and crank marks exclusively. If those are lined up right, the belt is on. If you need to pull the heads, it is a bit tougher to do in car, but if you don't have the ability to pull the motor, it is certainly do-able. Remove the intake manifold Remove the exhaust manifold. Undo the engine mount bolts so you can jack up the motor on one side and cock it sideways, to make getting to the headbolts easier. You do not have to do this, but it makes work a lot easier. Pull the heads, replace damaged valves. While doing your timing belt, be sure to check your timing belt tensioner to be sure that wasn't the source of your broken belt. Dan
  7. Stick with the factory plulgs and wires. I've had nothing but problems with aftermarkets on these cars and the factory stuff performs very well. The Forester has the same motor as the 2.5RS so there are plenty of aftermarket options available. I.e. Cold air intake, or KN drop in filter, Light weight crank pully, etc.(Not everything cross polinates, so do your research before buying) Exhaust stuff will likely be a bit different, but thats another option. Subaru has tons of optional stuff for those cars that is often still available for interior modification and exterior accesories. (Floor mats, shift knobs, high rise center console, etc) Dan
  8. It could be an O2 sensor. I've seen a few fail on those. And it could cause an intermittent hesitation and lacking gas mileage. On the other hand, there are also many hundreds of different options for the check engine light to come on, many that can cause similar symptoms. The Genuine Subaru Replacment sensor for your model is just shy of $200. Add $150 or so to install and diagnose the failure. This is assuming that is the problem. Dan
  9. Excellent. EA81 Tie Rod end it is. I thank you for your quick response. Dan
  10. Hey guys, I've searched extensively, but not been able to find any affirmitive results on this. I recently swapped over some Impreza knuckles, brakes, hubs etc. onto my 89 GL, wich I had previoulsy done a 5-lug swap on, using XT6 front end stuff. After getting it all assembled my toe is waaay out. So, I cranked it in, but at the limit of adjustment, i've still got another 1/2" to go on either side. Thus, I need to find some shorter outer Tie-Rod ends. Whats in there now i'm pretty sure are XT6 ends wich measure 6" exactly from the outer end of the ball joint to the inner end, not including the stop nut. Any one know which ends might be shorter? Mind making a few quick measurments for me? Thanks! Dan
  11. Sounds like its just a bulb on its way out. Not uncommon to have a bulb with an intermitent filiment connection. It isn't too bad to get to the bulb, it'll either take a few more joints in your fingers or a bit of dissasembaly. Once the center bezel is off i've been able to change the bulb at that point, but it takes some articulation. The bulb is on the drivers side, directly underneath the shift indicator pattern. Its a '194' bulb in a twist in socket. To get to it, remove the center bezel, then the four screws that hold the whole unit to the floor, the two small screws that hold the shifter to the shaft, and pull it up. You'll notice imediately that your still tethered to the car by a red electrical wire, thats the wire to the bulb. Just follow it to the socket, twist left, and out comes the bulb. Make sure the wires are all intact and the socket is undamaged.
  12. If there is movement when you move the tire top and bottom it is likely not the steering rack. Steering racks will show movement when the tire is moved side to side. It is more likely a wheel bearing or hub if you have top to bottom wheel play. I wouldn't go playing with the tension on the steering rack, if it has play in the gear drive, you should replace the rack. I'd be sure it is not play in the inner tie rod ends first though, this is fairly common. I've also seen many issues with strut top nuts making noise after changing struts. They can be challenging to get fully tight when off the car. Easy enough to double check in the car, and a lot easier to get tight once installed. Hope this helps. Let me know what you find! Dan
  13. Check the fluid level. How much you needed to put in can vary on how much got drained out. A normal drain and fill takes about 3.9 quarts. Your 5 liters (about 5.3 quarts) is quite a bit of fluid. Dan
  14. If the coolant level is always full and you are still getting an overheat condition, it pretty well narrows it down to cooling system components. (rules out headgaskets and other leaks) I would check the radiator, see if it's devolping any hot spots accross the surface of it. Feel to see that it blows warm air when the cooling fans are kicked on. Check to see that the cooling fans are indeed kicking on. Let them come on at idle and monitor how long they stay on for. Should be around 30 seconds. (make sure your defrost and ac are off) Lastly, you could have water pump issues. I've seen impellers seperate from the shaft of the water pump, but this is a real rare issue. Report back with your findings! Good Luck, Dan
  15. I've had fuel pumps do that to me. They can still run and prime okay, but may not be building pressure. Worth a pressure check at least. Should see 30-32 psi at idle and 70 psi or so with the return blocked. I'd check for sticking valves as well. its not uncommon to have those motors build up carbon on the exhaust valves and stick the valves open when cold. Just stick a vacuum gauge on the manifold while its running (if you can keep it running) and see if the needle flutters and bounces around. Also see what your ECT is reading. If it's failed suddenly it may not have set a code yet. A fully plugged cat could cause some serious issues, but it should still start up okay. Thats where is would start. Dan
  16. Thats a nice looking Justy! I've never seen one with a sunroof either. Nice light bar on the front too! Welcome to the forums. Dan
  17. They must have enjoyed having a lifted Brat show up to the meet. I find the new school guys still enjoy the oldschool stuff at meets. Looks like fun. Dan
  18. Could be any thing from a wheel bearing, to a tie rod end. Hard to say, but if its got that much shimmy in the wheel, it shouldn't be hard to track down. Does it change with brake application? Does it happen on turns? Or is there any other noise or vibration on turns? Is there play/slop on the wheel if you turn it side to side while stopped? Can you hear a clunk if you turn the wheel side to side while stopped? More questions than answers, but it'd be good information to have Dan
  19. I actually drove one just yesterday. Its a very different experience, but it seems pretty stout and operates very well. Looking over the mechanical design of the trans, it is a much better design than Subaru's old CVTs (i.e. the Justy) and looks like it may be a good option. Its worth a test drive. The gas mileage increase is pretty staggering too, 28mpg iirc. Dan
  20. On the back passenger side of the engine block, near the bottom, there would be a VIN number engraved on a flat spot. If it matches that of the car, its the original! Dan
  21. Check out www.Subarugenuineparts.com. Search their OEM parts catalog. You should be able to find it pretty easily on there. Dan
  22. All is well that ends well. Glad to hear the shop took care of you without much fuss. Dan
  23. It will most likely be that resistor. It would only work on speed four becuase it does not limit the voltage through the resistor on high speed. That's what it sounds like, though I though the resistor was down near the motor. Been a long time since i've done one though. Sounds like you're on the right track though. Dan
  24. I put in an order for 14 medium shirts in the staff saftey green color, pre-paid of course. If I could get those overnighted to me, with three large peporoni pizza's that would be great. mmmhmm.. Dan
