Everything posted by eagleb
So no bites on a leaky window... how about this one, My drivers side (and passenger side to a lesser extent) from window rattles pretty loudly when not all the way up or all the way down when going over bumps or rough roads. It's not the felt pads, those are snug against the window. Anyone else have this problem? If so, where is it coming from? I can't seem to track it down very easily. Thanks for the help, if it's out there...
Tried searching but didn't have much luck... When I look at the tonneau cover in the back of my 96 OBW, more often than not there is a water pool on the passenger side, directly beneath the top of the rear window (where the bottom of the trim meets the top of the window). I guess I should thank the Oregon rain for making me notice this, but it's definitely become worse over the past few months. I had the trim off, but there wasn't anything noticeable at the window seal. I would run a hose over the area, but it's damn cold outside, and there isn't easy access to a hose in my complex. So, question is, do I use a quick fix (silicone sealant? other?), or reseal the entire window (something that intimidates me)? It seems as though water is only drawn in by pressure changes (opening or closing a door), but I'm not positive. Sorry for the unknowns, if I get a chance to run a hose on the window I'll update the thread. Thanks for the help.
Nipper's solution makes the most sense, really the only reason people need insurance is because us americans are terrible at budgeting (just ask Mexico, somehow we owe them over $30 billion) put that monthly warranty payment aside for repairs, hope you don't need it, then take a trip when the original warranty expires.
the broken clips were in the middle on both front sill plates. no problem. I've never set up an amp and sub, so I had to do some searching to figure out how to properly use it with my alpine head unit. Sounds great, just that little extra thump that the door speakers lack. I listen to mostly rock, but also some indie hip-hop. Eventually I'm going to make a fiberglass sub enclosure that fits behind the drivers side rear wheel well, but until then I'm going to fab up a couple of removable brackets for the amp and sub so they don't move around in the rear of the wagon. I also installed the ipod interface unit that works on Alpine decks, and routed the ipod plug into the console. Now the only wire I see is for my cell charger. the bloobaru is quite happy.
Head Gasket?
eagleb replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
do a search on how to burp the coolant system, could just be trapped air in the system... Others will chime in shortly -
http://www.ultimatesubaru.org/forum/showthread.php?t=2498&page=1&pp=10&highlight=climate+control+backlight Depending on your comfort level, changing the climate bulbs should be very easy. Hardest part is taking off the dash panels, and even that is simple. Be sure to disconnect the control cable at the floor, and not at the climate unit.
Check engine light went out on its own, checked the code and it was indeed a misfire, on cylinder 4. I had a problem with the same misfire before I had the headgaskets done at the beginning of the year, but this is the first time the CEL has come on since the HG job. Probably an isolated incident, but I'm gonna have the mechanic check it out when I take it in for an oil change (there's a slight oil drip coming from the drivers side of the tbelt cover).
Fuel was at >50%. The smoke did smell like a bit of burning oil. Probably was a bit of oil getting combusted, definitely seems like a fluke. The question is, does something need to be replaced (oil seal somewhere), or would this happen to any 11 year old boxer parked in a similar manner? The car runs great now, I'll get the code checked at lunch and update the situation.
After leaving the 96 obw AT at my parent's house for the weekend (I was using the old man's pickup to help with my residential move), I decided to bring it home. My parents driveway is very steep, and the car was parked pointing downhill. When I started the car, it began shaking, sputtering a bit, and was belching smoke from the tail pipe. CEL started blinking. I pulled out of the driveway onto flat land, and shut the thing off before I suffocated. After calming down, I went back outside, started the car, and it ran fine. Made it the 25 miles home no problem. CEL is still on, I'll have it checked tomorrow. I'm guessing it'll say P030x. Any guesses as to why this happened? Should I avoid parking on declines for extended periods of time? Hopefully it was an isolated event. I'll get the code checked asap, since I hate seeing the CEL illuminated. eag
