Everything posted by The Beast I Drive
New Rims on Older Rig
SJR sells an adapter plate that will let you bolt the old-school 5-on-huge bolt pattern VW wheels. I say a set on a older wagon and they looked pretty cool. -Bill
Christmas 2009 SALE
How much is an EA71/EA81 cam grind when it's not on special? Looks like Im gonna be pulling some cams -Bill
RX Tranny Teardown (and rebuild?) WITH PICS
Thats a 3.545 setup, but if I can find a 4.444 setup for that cheap, I'll bid on it. -Bill
Ok, so I've been lazy and haven't looked up a shop to do the custom cut/weld/machine work on my pinion shafts just yet. HOWEVER, Im also looking into another option. In the USA there was 1 model of Subaru that came with 4.444 gears in a 5 speed manual, and it was available for 2 years. That would be the 04-05 Forester Turbo. The Ring and pinion set is available from the dealership, at a mere $317 plus tax . Not cheap, but its brand new, OEM. SO, my question, is the pinion shaft in the Turbo Forester 5 speed transmission the same length, shape, and dimensions as the Early Legacy (90-94) 5 speed pinion shafts? Because if it is, then I will save up and pay up for the new pinion and ring gear from Subaru. If not, its back to the original plan. -Bill
This has to be a member's video
That brown 3 door belongs to a member from Oregon, I dont remember his name or boardname, but I met him at WCSS10. -Bill
what goes here?
Oh, also, a REALLY rare option on the GL's of that body style, there was an optional passing lamp in the grille, similar to the Gen 2 passing lamp/third eye, but a different housing and cover, to fit the Gen 1 grill. The DL would not have had that, but thats where the switch would be. -Bill
what goes here?
That hole is usually just plugged, unless someone installed an aftermarket switch there or if the car had dealer installed Subaru Foglights. -Bill
Today's safety tip of the day, today, OR: The Quality Workboot Thread
Yeah, I'll have to look into some good boots like those. The problem I had with my old Steel Toes was the synthetic upper materials liked to burn through when slag and sparks would land on them and the laces were a joke. They were quite comfy though, and at $20 a pair, lasted me about 6 months till they split at the seams... But I want something better this time. -Bill
Installing an lsd in the front diff
You have to use a front LSD, no rear LSD units will fit. There are a lot of aftermarket units made for the WRX front diffs, which are the sane as the regular Legacy and even the EA82 front diffs. There was a huge thread about this not long ago, I forget what it was called exactly but it went something like: Front Diff interchangeability: The true answer. Searche it -Bill
Well, the kicker is I did get steel toe boots. I must have been dead on my feet tired when I bought them, cuz when I put them on the next morning, they were like 3 sizes too big, and had absolutely zero flex in the sole. They were THE most uncomfortable thing I have ever put on my feet, aside from a rear diff and a ripper shank . SO I was not able to wear them that day..... Im going to make a run to Big R and invest in some GOOD steel toe boots ASAP though. -Bill
Annual Hatch Patrol Xmas Tree run
Nice Shots! I just got home, Snoqualmie pass was nice and clean coming back No major breakdowns, had a pretty good time at the meet, although a good portion of mine and a couple of others' time was spent at the local Fire station, we ran into a call for help on my CB from the other side of the mountains (gotta love my 10' whip ) and we were obligated to help. Turned out a couple of 'wheelers got stranded up in the mountains on the 5th, and had been stuck out there with no food. We got a call back about 7 pm and they had been found, thanks to our help so that was rewarding. Overall it was a good day, the Beast didnt give me any problems, I got to see Briggs do an awesome spin-out on the way off the mountain, and I got to meet some cool people and had a good time. -Bill
I planned on about 4 hours from here to Enumclaw over Snoqualmie. Also have chains for all 4 wheels, sounds like I might need them :-\ -Bill
Dude, for real? F'ing Lame. That sucks dude, hopefully I'll see ya some other time. -Bill
Thanks for the pics guys Pretty gross stuff. Well, no infection, I removed the nail myself (mostly, about 1/4 of it was still FIRMLY attached, so I let it be) that was fun. I then proceeded to drop a ripper shank from a 7- shank John Deere Ripper on the same toe just a week after the initial inceident. It hurt like no other, even worse than before, but all it did this time was bleed a little, no more damage done. It was only dropped from about 8" this time, instead of 3 feet -Bill
The: Go Anywhere Soob
I have the perfect car for you Wanna make a deal? Stripped down '86 Hatchback, in decent shape. PM me if you are interested, I think this would be a rockin' Snow-wheeler. -Bill
Prices/rareness? 91 turbo leg 5 speed in the junkyard
EJ22T is a closed-deck block and quite desirable, that block alone could fetch a pretty penny. Sell the engine, trans, and rear LSD if it has one as a whole and you could probably get 1000+ for it from the right buyer. -Bill
Looking for a good lift
What kind of Subaru do you have? I do lifts for Gen 2's and Gen 3's, and soon to have Gen 1 lifts as well -Bill
Well, looks like I'm Still In I'll be there, unless the Beast leaves me stranded on the pass (which I hope doesnt happen) -Bill
wondering about jacks....
I carry a Hi-Lift jack on my Off-road car, and it has made my life easier many many times. Its perfectly safe if you know what you are doing and have good bumpers. Ive found the stock rear bumper is strong enough to jack from on the EA82 wagons, but its best to have a steel bumper on the front. What I want to get is a full-size quick lift Aluminum racing floor jack from Harbor Frieght, I have a flyer here to get one for less than $60, but they are never in stock Whatever jack you use, some good chunks of wood are a must-have. Not only do they work under/on the jack, but you can use them to block he wheels as well. -Bill
EA-81: Pipe on Thermostat Housing
EA81 Hitachi wont bolt onto a EA82 manifold unless you swap the baseplate, if thats even possible. And if you did that you would still need a EA82 Hitachi baseplate. Easier just to use the entire EA82 carb and manifold setup than try to mix and match. -Bill
Distributor Bushing replaced!! New Question
Just set it so its the same on both sides. Thats all you can do -Bill
Supercharger?
Thats the VW Blower I was refering to -Bill
Heads question.
No. The space between the cylinder bores is wider on the EA81 than the EA71. The heads will not work, they dont bolt on, I have pics of all this. However, you can modify EA63 Dual Port heads to fit the EA71, which will raise your compression ratio and flow better with a nice port and polish. -Bill
Front sway bar clunk (EA82, 4" lift, taller springs)
Im sure he meant the crossmember is wider as in the width of the car, so the XT6 arms are farther apart on an XT6 than they are on your GL-10. SOOO, why dont you try an RX front swaybar? If you dont have one, I do, and I dont need it..... It would be the easiest way to solve the problem. -Bill
Supercharger?
A few people have tried them on the later EJ motors, and Ive seen pictures of a custom-built EA71 that had a blower built for a VW on it, with a custom intake manifold. The engine was far from stock though, and it appeared to have been running lean and melted itself at some point... I know a guy who is mounting a BDS Blower on a 2.2, hoping to have it done by next year's WCSS too... Thats pretty much all I know about superchargers on Subarus for certain. -Bill
