3
Everything posted by porcupine73
The ball joints can be a pain if it's corroded into the socket. I remove the two bolts (upper eccentric, lower regular) holding the strut to the wheel bearing housing. That gives me enough room, at least it did on '00obw, to get the axle out. If you pay attention to where the upper bolt is set before removing it and put it back there then you shouldn't mess up your camber. This method does however risk messing up the tie rod end boot; mine squirted a little grease when I did this. Some people also remove a bolt from the sway bar end link to let the transverse link drop down some as well.
Yes that is a nasty acrid smell. When mine ripped, I was at a gas station and I smelled it and I thought a truck tire was on fire or something. Then when I stopped at Home Despot I smelled it again and thought that can't be good, and people walking in front of my car were making sickly faces and wafting their hands in front of their noses.
Hi. It is possible it is an issue of lubrication. If I were having this problem, I would get the front wheels off the ground, remove the wheels, and inspect and probably remove the pads. Clean the ALL mating surfaces where anything touches anything else, make sure the pads are not too loose in the clips and caliper mounts, and recoat everything with antisqueal grease, or I have been using Neo HP800 wheel bearing grease all summer and my breaks are dead silent...no squealing at all even when creeping forward slowly. Even if you had the brakes serviced recently, an inferior lube may have been used, or the pads may be too loose in the clips and caliper mount, etc.
Hello Jacko and to the board! It being a 2.2L is a bonus because of the potential HG issue of the 2.5L. Of the issues posted with '99's, there seem to be some with a slow to engage into drive issue on the autos. Also some of the speedo heads went wacky. Definitely check it for torque bind and that the FWD (front wheel drive) fuse is not installed. edit: oh yes, it is also due for a timing belt, and I believe this an interference engine, so if the timing belt has not been done yet that should be done immediately if you get it, and there are several other maintenance items that are prudent to do at the same time.
I don't know of any shops, but I can tell you who does: Nile Jenkins. His Web site is http://www.thecarconnectionbusinessnetwork.com/ He deals with automotive questions and issues in the Buffalo and Ontario areas. He has some good shops listed on his site. He knows of others that might not necessarily be listed as well. You can search for shops in your area on his site, or you can e-mail him, or you can call him during his radio show. It's saturday mornings from 7-9am on 99.5FM (not sure if you can pick that up where you are; it's a 100,000 watt station in Buffalo I can pick it up even in Ohio).
Sounds like what the inspection guy told you was correct. It can take several trips to get all the emissions inspection readiness I/M monitors set to 'ready'. Especially the 'evap' as it only does the fuel system integrity test on the enhanced evap vehicles under specific conditions, one of which is something like less than 9.6 gallons of fuel in the tank another is fuel temp. It took me a couple of days driving to get that one to go ready on my '00obw.
You can tee in at the oil pressure switch under the alternator. It can be a little tight under there to work. You probably also need adapters. The thread on the block for the pressure switch is 1/8" bspt (british standard pipe taper thread). 1/8" npt will start to thread in there but it is not the right fitting and could leak. You can get adapters from mcmaster.com or other places. That said, I know I saw on endwrench.com something about that kind of ticking and it said it could be a partially blocked oil passage which lets the HLA's then bleed down and takes a while for them to rebuild pressure.
RTV is not required on the gasket; I guess you could use it but it is not needed. I use edelbrock gasginch on stuff like that to mount the water pump gasket to the water pump before install. Makes it a lot easier than trying to keep the gasket in place while installing. gasginch is basically just rubber cement with a nastier faster drying solvent I think. There's lots of types of it at the auto parts stores. Note that when torquing the water pump bolts, you start with the bolt at apprx the 2 o'clock position, then go tightening them, move to the next bolt clockwise, then go around again to reach the final torque which I think was like 7.2 ft*lb. Resealing the oil pump isn't too hard if you get the crank pulley off. Sometimes the crank spocket can be tough to pull off if it got corrosion underneath it. There's two types of o-rings, one for EJ22s I think which just looks like a normal o-ring, and one for EJ25's which is more like a discus looking thing.
Hi. That'd be the ABS 5.3i setup. Look for a white connector under the dash on the driver's side. On my '00obw, this white connector was sort of above the brake pedal. It was a 7 or 8 position connector, though only 2 or 3 had wires in them. It was sort of taped up (if it hasn't been used before). There are two blackish 'test wires' taped with the connector. I put one of those wires into position '8' I think it was, which was the lower right pin when looking at the connector. Then when you put the key to run it flashes out the trouble codes.
Well if you can pull the front and rear struts assemblies (struts, springs, mounts, etc) from a 96 to say 98 (maybe 99) Outback, those should be 'bolt&play'.
What year and model Subaru? Not sure if this is your issue, but some of these had screws, some had rivets holding the little tabs that latch into the body to hold it taught, and some of them tended to back out or break off. This happened to me, and the screw got caught up in the roller mechanism and was making it not completely retract. I was wondering where that screw came from, then the right tab came off. That was the screw. There is an article on endwrench.com about it.
