jon38iowa
Everything posted by jon38iowa
Good News! I replaced the rheostat today and the all the lights are lit up!~ It was indeed located up and behind the right side of glove box,moreover, it hides behind a stalk of two other electrical components that look very simillar to it. Thanks again for everyones help! Now I won't have to guess at night time speed. John
You Might need to consider new struts; I replaced all four of mine('99 S model) last year with KYB brand, and it did stiffen the suspension a bit, however there is still a little more body roll then I prefer.I am told shorter springs (STI) can be installed which supposedly will reduce this tendency. John
Thank You for providing the link to endwrench, however I was unable to access it despite trying both of my browsers. Can I ask what side of " kick plate" is the rheostat on driver side or passenger? Here's the scoop on the illumination: 1) Fog light switch lights fine. 2) The hazard button has never lit up, at least since Iv'e owned this used car. 3) Rear defogger, I will have to get back with you on. 4) Cruise control has also never lit up for me. 5) CD/ Radio works and shines brightly as before ( this is an expensive after market unit). 6)'Same as Above I am going to replace the rheostat regardless because: I have it, is not returnable, and it eliminates yet one more possible problem. Seperate and from the lighting issue, I will be replacing the heater control unit; This, as on mine the buttons are working a little loosely, moreover, I got a great deal (ebay)on a like new unit- $30.00! This price included ashtray, surround bezel, and power port. John
OB99W: Thank You for advice! Here's the story: I atempted to replace the shift lever light bulb with one from Radio Shack, however within a few seconds of installing I smelled smoke! Quickly I removed the offender, but it was too late. I now have no dash lights, shifter light and heater/ Air control light; All the other lights work fine,radio is perfect, and the hazards work. I took the car to my local mechanic, morever he said, "it looks like the instrument Light Rheostat," and " likely it is connected to the turn signal stalk." I would have had this fellow fix this but he said to, " go to Subaru." To be honest I would rather replace half the dash board myself then go to my local dealer. So far I have installed a new turn signal assembly ( the entire unit) and checked the fuses ( inside and under hood). I have now this new $81.00 Rheostat part # 83023 FA000. It is a 1-2' Inch boxed shapped device and has a connection port to one end and steel holding plate on the other. This Satuday I guess I will be once again tackling this project; Thanks again for your response- The kicker in the saga, Subaru gave me a free bulb for the shifter.
I am going to horn in on your thread because it dove tails with my predicament; The instrument lights no longer work on my Forester (Fuses are fine) and the issue was my mistake for installing an improper light bulb. At any rate my Mechanic recomended I replace the instrument light rheostat ( it looks kind a like a 1/4' sqaure Fuse), moreover I got one from a Dealer, but I can't seem to find anything that resembles it and certainly nothing on the steering collumn as I was told by the non Subaru mechanic. I guess I will have to take the lower dash, but if anyone knows the precise location of this instrument light Rheostat I would be very grateful. Note I replaced the turn signal stalk and it made no difference. John
I agree nipper; Moreover, sometimes a particular tire is just not all that good in some areas. I had a set of Goodyears quite a number of years ago, anyhow ( and I like Goodyear) they were like greese on a banana peel in only slightest dusting of snow, and it was rather scarry. I noticed not long after I got rid of them, Goodyear discontinued them. John
