SoobGoob
Everything posted by SoobGoob
  1. haha less amp and not a nice. but like i give a s&*t. i have to rewire my whole stereo its so messed up. nothing works right. but i did finally get a FM transmitter from frys like 10 bucks too
  2. hey that amp isnt that bad GD it works better than the piece i have now. i put mine in the area under the cargo area. works great. never gets hot or kicked or anything
  3. i think their cool and would buy them if i knew wtf was goin on. but you can make your own. go two vwvortex.com and look at their DIY secton. they have LOTS of cool things tricks/tips you could use on a soob. including all red taillights
  4. but its still NOT a honda. and for that
  5. i had rats living in my VW for 20 years. took more than a drive back from idaho with the windows down to get that smell out of there. even found a couple skeletons
  6. there are consoles that dont have the spot for the 4wd lever but arent too common. ive seem them out there. thats your best bet
  7. it was missing the 4wd switch and a switch for lo? much have been just that year the LO switch was on the tranny. filled both those guess only the reverse lights are left
  8. i have a front bumper in half decent shape, also passenger side fender in OK shape.
  9. they crack between the valves on the heads, ignore it unless its really bad. i think GD said tourq all of the bolts to 20 then 35 then 50. you dont have to take out the engine to do it but you will by bending over and laying down for a while
  10. if it blows air but it is cold then you have a clogged heatercore. if it doesnt blow on any 1,2,3 or 4 one or any then you have a bad resistor pack. i would have one for you but GD broke it heh i might be able to unclog a clogged heater core for you
  11. mines nice in toasty in portland. even drove to the store at 1 in the morning tonight to get some brew. better than my last soob with the clogged heater core
  12. you can also try just replacing the buttons they pop right off
  13. im planning on an awd ej hatch
  14. if you could store one big sheet of plywood to lay on that would probably be most comefortable. or make a plywood driveway, and use a lenght of rope for a belt
  15. ill look into that on the next dry day
  16. your seriously joking right? its the internet, get a life. this board is for helping people not attacking and when you come in here saying your going to take legal action i do hope you have "had enough" of this. im new to the board but from what i can read im sure im not alone when it looks like we have had enough of you
  17. i changed the seal in my rearoutput thinking it was the cause of my leaky transmission. well turns out it wasnt but became a problem. its leaking and its a new seal. is it not pushed in far enough? or is it just a bad seal. trying to figure out asap any ideas will be appriciated
  18. my loyale has int wipers its not low grade anymore!
  19. mine get stuck too if i go from any speed to intermittent. and when they get stuck i hit the windsheild washerbutton usually takes care of the situation
  20. if its getting wet that can make the headlights dim. check for leaks and if its getting water inside of it and you want a cheap fix. drill a hole at the bottom. worked great for my old fish bowls
  21. try running atf, i did 100% atf in my 5speed d/r tranny and its smoother now and it has 300k on the tranny
