Everything posted by SoobGoob
just got a t leg *UPDATE* PICS 56k GO MAKE A SAMMICH
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat about a ej20t? im looking and i cant afford a ej257...
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi was thinking of buying a JDM ej20tt and dropping it in. would be the cheapest way to go. will it fit?
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat injectors would work well that arent too pricey?
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit was in walla walla you probably saw it on cl?
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis is going to be wild i have never owned a turbo car before so im in for one hell of a time
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsay i got rebuilt heads, new turbo, reground cams, 3in turboback ex. what would be a safe psi?
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat year wrx?
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso should i run the stock turbo unless i get stronger internals or will the turbo you recommended be alright with stock internals. what exactly is a stand alone ecu?
was lucky enough to find a pearl white 91 t leg that is mint inside and out! needs head gaskets and a new turbo i paid 800! so questions i have for you fellows since i have only worked on ea82's is. im excited to start this project. i will get pictures up soon for everyone to see :banana: :banana:
towing a legacy question
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi do belive the fuse only engages the rearwheels when the fronts slip making it awd but even with the fuse out just the rear wheels spinning it can still tear the vc up. comon guys i know your not all at the show!
can i tow a awd legacy on a tow dolly if i dissconnect the rear axel from the diff? or can i still damage the VC? its a awd 5spd 91 SS
wcss9 HELP
i have no idea where it is and i cant find directions. i am sorry o tpost such a stupid question but that orv park is difficult to find plus a little so i need directions to it. HELP i wanna go tomorrow
thinking of getting a legacy
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXive done it with a loyale and it was like clockwork. hopefull the swap will be as easy with a legacy...
what should i look for when shopping for a legacy? im coming from ea82 land. possiably buying one with blown auto tranny and swapping for 5spd, is that as easy as it is on a ea82? any advice is appriciated
over heating.
this is what i thought all along. so the symptioms i have point to a bad rad? i had the radiator removed 2 days ago and it all looked healthy?
largest tires *UPDATE*
correction i went to take pictures they are 14s. sorry for the typo. but i decided im just going with the sjr lift. WHOOHOO
over heating.
when im stuck in city traffic in the heat. or when im tring to get it up a big hill. when is struggles
they are some wildcats GD traded me last summer. i dont know where he got them
i heard something about honda springs?
with the new tires on my car kind of shakes? i dont know the best way to put it. bouces slilghtly? could this be off balance tires. also it pulls more to the left then before i knew the alingment was off already but is it just more noticeable with larger tires? basically what im asking is if these are problems that can be taken care of with alingment and balancing? and is there anyway to make my suspension stiffer/longer? my rears run close to the well and i know one big bump would make them rub with my worn out suspension...
Roll over, 'ru! [56k beware page 3!]
no better time to change anything underneath your car but i am sorry you were so unfortunate i would be furious at those punks
suspension opinions?
looksing for some stiffer suspension on my loyale. does anyone know anything thats cheap and effective. and maybe something that will give me an inch or two more clearence? ive been looking on jcwhitney...
over heating.
both my fans ar ein proper working order. i dont use my ac so i dont think that it has to do anything with it. the tstat i have in it now is a subaru tstat i got last sept
les schwab wouldnt alinge my tires!?! because "they were too big" so now i have to swap the stock ones on to get an alingment. what a joke:dead:
over heating.
is it possiable for my waterpump to go and not leak anything at all? weep hole is also dry. i took the radiator out yesterday and it looked fine. so i flushed it and put in back in with 50-50 mix..... ill try the tstat and the circulation test. thanks gloyale
