SoobGoob
Everything posted by SoobGoob
  1. cam someone please tell me the process of opening my headlights. i know you put them in the oven but i dont know for how long or what temp thanks! SG
  2. and the lifted purple truck in the backround
  3. they may be inexpensive cars but thats not why we drive them
  4. sometimes when HG's go, coolant and oil mix. maybe there in some oil in your coolant running through your heater core. but as far as i know that is contained, just an idea. maybe check heater core hoses?
  5. problem solved! it was missing a DR LO switch, turns out before they put the LO light switch in the consloe there was one on the transmission itself. must be an 85 thing. there wasnt even casting for the single range lever. so now its holding fluid and shifting smoothly.
  6. thanks for the advice everyone, i am replacing the shift rod seals today and praying thats my problem. im spending more on trans fluid than gas to get around
  7. wasnt the output seal. does anyone have any other ideas? its loosing QUARTS at a time but about 1 1/2 quarts do not leak out. all fluid but that leaks out almost instantly. i cant see where its coming from but i know its near the rear somewhere around the output of the transmission and only really leaks when i drive
  8. checked around all i saw was other people on sites like these caliming it is kerosene. look around its out there
  9. cant remember. vwvortex fourms i belive, ill look into it further and let you know
  10. seafoam is kerosene, just a lower qualtiy not as strong
  11. could it possiably be the rear output? is there a seal in there?
  12. is there any place in partictular that a 5spd dual range transmission leaks? common? not common? has anyone else had this problem? its leaking pretty bad. just installed it too
  13. doubt it will fit i had a 90 civic and they didnt work on my wagon.
  14. that to me sounds like the distributer might be going. ticking at idle but going away at a higer rpm. but depends on the ticking
  15. is it the D/r trans? i need one because im going to attempt the 4.11 but just need a rx D/R trans. i have all the othert parts
  16. i like how that soob is on the left side of the road
  17. heres a couple more. not very good but very fun to watch ah and look what these turds did to a touring wagon
  18. you can also just disconnect the - terminal of the battery and it wont die while being stored as well. IMO a cheap trashwagon ru would be awesome for those winters!
  19. will they work on my loyale?
  20. i think everyone should get some subarus in action in the snow. i know ill be getting some this season
  21. i have all the indicatiors hooked up right but 1 its a black wire with white stripes i have no idea what it goes to
