Everything posted by zukiru
Swapping body parts!
if I could get a sedan with that bumper I'd rock it hard. your widebody looks pimpalicious!
look what followed me home....
is that a factory color? I love it!
rear tortion bar on EA81...how strong is it?
My original post should have read "the beam acts as a sway bar?" I see where I goofed... I stated as fact when I meant to ask a question my bad!
flapper maf tuning
just that an engine makes more power slightly leaned out. as opposed to pig rich.. it's just another way to trick an ECU. (I agree with you... being alittle leaner or richer shouldn't be enough to rip engine mounts) 88-ish camry owners report nice gains from a few clicks but it's all rump roast-dyno gains
then it isn't a torsion beam suspension. it's an independant rear suspension. if you have your terms wrong to start with how can you expect a good answer. (see I can be an rump roast too. and I went out on a limb for that I really thought when you all said torsion beam it was an actual torsion beam suspension) does it have springs, too? or dio the bars act as the springs?
yes one just like that one!
New To Me '91 XT6
It's Bruick... get it right, dawg.
Wiring diagram for passing light (3rd eye) how is it done?
when you get it working I want pics of it in various states as I have never seen one working,, (I think my uncle's Junkyard has one but I haven;t really checked)
flapper maf tuning
I know it works for old toyotas. and the flapper maf is very similar inside... I know all you would be doing would be changing the spring tension increasing tension would make the door harder to open leading to reading it as less air. leaning things out. and the opposite should also be true taking tension away would richen the mixture. but does it work enough to be worth doing?? I am going to search more but flapper maf mostly leads to posts about not worth it to drive that far for a flapper maf turbo car, lol
the torsion beam does the job of a sway bar... what you want is to strengthen the beam between the arms.. does it unbolt? so you can bolt in something heavier?
flapper maf tuning
anybody played with the clock spring ring??
New To Me '91 XT6
cool.... those rims look great for 200 plus ship!
(Fixed)Need HELP! Fuel Pump not kicking in
check all the fuses and the fusible links.
sloppy ea82 shifter
god, found this on search..... and had to add If you can't Duck it, you know the rest!
Need some help... one cylinder low compression
broken timing belts make a whirring sound also. FYI when you turn the key have someone check if the cranks turns and pull the disty cap and see if the disty turns this should help with your answer.
Debate: mpfi vs carbi in ej'ed older vehicles
I need help with that part, lol if you can help me figure what to trim I'd like to do an EJ swap ,,, but I am going to be so lost...... mechanical I handle
It's a brat but not a Subaru Motor
ha anybody got a third light video? you know the center one? can't seem to find any.
EA82T Fan Modifications....?
you have the ea81 fan run all the time? or is it set for a certain temperature?
RX convertable
don't do it to your only one like this works too
XT / XT6 site is...back up again
I had lunch and it was back!
I like this idea of running an EJ on the existing fuel setup...
http://xt6.proboards50.com/ we are also kind of meeting up here again. thanks for the update Gary!
My Coupes Journey!! Is Over..He is in CT!!
I feel alone here too. time will pass and LB will be there!
jWheels
Where do I get these? like last week, lol
pull and save primerblack xt
sad.......
