tcspeer
Everything posted by tcspeer
Check with Litha Subaru there in Oregon # is 866-717-2512. Or check with Campbell Nelson used Subaru parts # is 1-888-337-7757 they are in Arlington Wa. Zip is 98223 I dont know if this is D.C. or State, as much as I have bought from them I should know but I don't. both places have been good to me for years.
Did you check the strut? Also check the bushing at the rear of the front control arms they are the one that have the two big bolts in them. I just had one go out and I am getting noise on the slow sharp turns. When they go bad you will see grease coming out of them. they are easy to change and it cost me 75.00 dollars for the bushing. I thought the noise was coming from right front, but it turned out to be the the left front. So your noise may be coming from there also.
Most rural routes are not in neighborhoods, those carriers you see there are city carriers, they use a vechile that is provided by the post office, I dont even know who makes them. Most rural routes are along the hiways and county roads. We are able to get to speed limit many times during the day. As far as the gravel and leaves maybe they do help. That car of yours is really sharp looking, if mine looked that good I would be much more picky about things, then I am on mine.
Again, I am not telling anyone to do what I do, but my car has 304,000 miles of postal del. on it. Its a 1997 Subaru Legacy Wagon, it went to work on the Rt. in 1996 ten years now, and I have never had problems replacing tires as needed. I had lots of miles on it before I found out you or not suppose to run them that way. The money I have saved by buying one tire instead of four would easy pay to fix what ever problem most of you worry about. If this was true and as important as most of you think, I would be the first to leave Subaru and buy me a car I could use. My advice is to keep good tires you may not be as lucky as I have, but if you need to put a tire on that does not have the same tread depth to get home, do it and dont sweat it.
I dont remember having any problems getting the inner joint to line up, but I dont remember it being keyed either, but it may have been. I think it would be more easy to pop the ball joint and the control arm link then undoing the strut. If you will get the Haynes manuel it will show and tell which ones to take loose for axle replacement. I used it and it was easy when I replaced the axle a few years back. Last week I had to take spindle and hub off to replace wheel bearing so I had to undo the strut, and I thought it was more work then the way the Haynes gives directions for removing the axle. But I realize other people may think different. But I would look at the Haynes and then decide.
blinker HELP!
tcspeer replied to Zefy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Looks like you are on the right track with the switch. I dont know which ones will interchange, but a good Subaru junk yard will give you that information they seem to have better information than part houses. -
blinker HELP!
Have some one hold it down while you look at the front and back and see if all of the bulbs are flashing. -
blinker HELP!
Did you check the bulbs and fuse?
