tcspeer
Everything posted by tcspeer
I had one of my timing belt pullys go out and it cost me an engine. You can get them cheaper than the price you mentioned. Try first Subaru parts or Lithia Subaru, you should be able to get them for nearly half the price you quoted. If they are not smooth and quite I would change them. An change them at least every other belt change anyway.
Emurray, I am also a carrier here in Tx. I ran a 97 Legacy for nearly eight years on my Rt. before losing the engine due to Idle pully coming apart and valves getting bent by pistons. I was at 287,000 miles on mine. Have you looked in the national rural carrier magazine their is sometimes a good selection of right hand drive Subarus, Saturns, and Jeeps in there. A lot of the carriers are selling them because they have had the LLV's put on their routes.
Ferret, You are 100 percent right. This started in 1997, and somewhere on this site their is a post explaining how Subaru had coned the pistons top for more horse power causing them to be interference engines. Like I said before I know this from experience. I lost a great 2.2 engine with 278,000 miles on it. I had time to fix my squealing idle pully but did not get in a hurry because I thought it was non interference.
If eveything is tight it should not be a problem, but you cant know that without looking at it. Some times hub caps will make a clicking noise if you have hub caps take them off and try it. Also check and make sure lug nuts are tight while hub caps are off. Brakes are very easy to do if you have a friend with mechanic skill and a Haynes manual see if he will help you.
You should be able to tell if the valves are o.k. with compression gauge. When my Idle pully came apart on my 97 2.2 after getting it back together it would not start. I checked the compression on the cyclinders and only found compression on one cyclinder, I think it had around 150 p.s.i and the rest had none. I dont know if this works every time but it worked in my case. Of course if it starts you wont need to check it, and you cant check it untill it is back together.
