tcspeer
Everything posted by tcspeer
Noise on turns
tcspeer replied to ascus4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you have hub caps, take them off and try driving it. Some time one will get a little loose and cause noise. -
NY dealers
tcspeer replied to jedimaster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you backed out wouldnt they keep your money? Make them stick to the deal they made. You letting them have that deposit money is a good faith contract, or should be. -
I dont have anyway to run anything on carfax, but I was listening to an automotive show on the radio yesterday and the host was not real impressed with the accuracy of these services, his suggestion was if you are real sure you want to purchase that car was to take it to one of the shops that does the full automotive analysis. He thinks it is money better spent.
You need to go back Monday with a witness and talk to them, make sure you keep the receipt for the work that was done. If they make no effort to fix the problem and be responsible for any other damage they may have caused then you can send them a certified letter (return receipt) and explain in detail what they failed to do and let them know that you are going to hold them liable for the damage they may have caused, tell them if they dont take responsibility you will seek to get the damages in small claims court. You can start that action for around 50.00 dollars see the county clerk and they can get you going in the right place. This really works well when they get the notice from the court they are being sued they will probaly take care of it. If not then follow through with the court action it is a great tool when you learn to use it. If you need more help you can probaly find a book for small claims court for your State at Amazon.
Is it both front wheels or just one? If it is both you may have some bad pads, I have a 97 Legacy L. wagon also (right hand drive) for use on rural mail route I have found the semi metallic pads that Auto Zone sells for around $20.00 dollars work well. You may also got a bad rotor, I put some new ones on mine one time and one of them was warped from the start. Find the one that is squealing the worst and put the old rotor back on if it still does it then it is pads, if it stops then it is rotor.
A/c ?
tcspeer replied to superclock's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The compresser may be getting weak and not building enough pressure. Have some place that just does A.C. check it. -
The rod is to far to center of door to get with a slim jim. You will need a slide lock tool. Hommer tools on the net sells a cheap set of car opening tools and I think this tool is in their set. It is around ten dollars for the set. However if you want to try and make one get a stiff rod about 1/8 in. thick, a bit bigger than clothes hanger and about thirty four inches long. about four inches from bottom bend at a ninety go two and 1/8 in. over and bend back up in another 90. then measure one inch of the part that you bent up, and bend remaining part of this back down making a shape that will look like a upside down U then bend the other end some so that it will not fall down in door if you drop it. Opening Inst: 1 Insert wedge into middle of Passenger Door. 2 Insert the slide lock tool into door. Push the tool down into the door until the tip of the tool is below the window glass. 3 Turn the tool 90 degress, so that the tip is pointing in towards the interior of the car. Push the tool DOWN INTO THE DOOR 7"-8" and rest the base of the tool on the horizontal rod. turn the tool untill the top rod falls into the tip of the slide lock tool. then bind the rod by twisting the tool, while maintaining the binding pressure, push the rod forward to unlock the door. If this dont unlock it try pushing backard.
I agree with Setright that you will most likely need new brakes to fix your problem. However if you have drums on rear their is one little trick I have found that will work sometimes, that is to switch sides with the drums. The wear patterns of shoes to drum will be different and it will sometime remove the high or uneven wear. Just be sure to brake easy the first few times like you do after putting new brakes on.
I know you said you wanted one that would fit in the compartment, but my Subaru jack stripped out also, so why would you want another one. Let me suggest the little jack that Wal Mart sells it looks like it is part bottle jack and part scissor jack it comes in a small black case so it does not rattle. It works great and it does not take up much room in the back. However if you want one that will fit I bought one from Northern tools before I bought the Wal Mart jack it works well and fit in the compartment it looks almost like the Subaru Jack, I dont know if they still carry it but you could check their web site. On the Wal Mart jack I am not taking about the small floor jack in the black case, its the small hyd. scissor jack in the black case.
Maybe the idle air control valve ( if the 1990 model has one) my 97 2.2 does the same idles rough at stop lights. The I.A.C. valve is expensive so I have not Chg. mine however I did spray some carbarator cleaner in the big hose that goes to it and it seemed to help some. I dont know if spraying cleaner in that hose is the right thing to do so you might want to see what other people think, however it did not harm mine.
