Everything posted by tcspeer
DIY Caliper rebuild?
tcspeer replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would go to Auto zone and exchange them for rebuild, make sure they have them in stock before taking yours off. I rebuilt the calipers on our Saturn and they are very easy. Not so with the Subaru the boots are really tough to get back in. Exchange price is not very much I dont remember the cost but it is better than messing with those boots.
Need Help. Rough idle again!!
tcspeer replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLawsonmh15, why do you ask about slack in throtter cable? Mine has slack in the outer sheild of the cable and it runs rough at idle while in gear. I dont think the inner wire has any slack in it.
Vibration/Shaking in new Forester
tcspeer replied to rosana's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe idle air control valve is expenise, that is why i have not changed mine. Make sure they dont change it just as a shot in the dark. If they find the problem be sure and post back, this seems to be a common problem. I looked on the search feature of this sight and found that we are not the only ones with this problem. Also found out that no one seems to know the reason they do this. After looking back at your post I see you should still be in warranty so maybe the cost of an idle air control valve wont matter.
Front brake rotors : a question about quality
tcspeer replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI use the ones at Auto Zone for around 30.00 dollars and have only had one that gave problem. It was a little out of round but they replaced it. I am going to try the ones that are even cheaper next time. If I remember right the ones for my wifes Saturn are around 28.00 with life time warranty and around 18.00 dollars for 90 day warranty. I dont remember the price difference on the Subaru.
Hydraulic arm
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI hope their is a weld nut on the back, I dont do well with trim.
Hydraulic arm
The left arm on the back hatch of my wagon came loose at the top, I put it back on and it stayed a few days and then came off again. I have ordered a new one and the top part looks simple. I am a little concerned about the bottom has any one ever changed one? Do the inside panels have to come off to get the little bolt at bottom off, or is it just a stud that screws in from the back of hatch.
tcspeer replied to rosana's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 97 Legacy wagon started shaking when stoped at lights or stop signs when it is in drive, if i put it in N. it stops. I was not able to find the problem and latter the engine got trashed because an idle pully came apart. I had the motor replaced with a low mileage engine and it also shakes. So it must have something to do with the parts that were taken from the old engine and put on the replacement engine. My thoughts right now is leaning towards the idle air control valve. But that is only a wild guess.
conflict resolution wth subaru
tcspeer replied to mikem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXContact SOA they will help you, I feel sure of this. Their should be a number in the back of your owners manuel where to turn for help. It is best to contact these people with certified mail return receipt, after you get their address. This will help you if you need to prove time intervials.
non interferance
tcspeer replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNon interferance means the valves and piston will not hit if timing belt breaks or something else goes wrong. Interferance means they might, so it is much more important to keep your belts changed at the right time on them.
subaru parts
tcspeer replied to subaru424's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCall Litha Subaru their # is 1-866-717-2512 or 1 800 299 3610 I think the first number is correct. They provide parts for Rural mail carriers Subarus. They will ship Express or any other way you want it. They have great prices and fast service, and plenty of help where you dont have to wait when you call. they are on the West coast so you will need to call around 10:00 your time.
non interferance
tcspeer replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know from experence 1997 2.2 are interferance. My idle pully came apart at 288,000 miles and it bent the valves in three of the four cyclinders. The reason they are inteferance in 1997 is because the piston was coned up to get more compression or horsepower. I seen an article about this on this board or the other Subaru board.
tcspeer replied to mikem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have been thru this and the whole process was very easy. If they fail to fix it in three attemps ask at the dealer to see the Reg. manager. They will set you an appt. with them and they will meet you at your dealer place of buss. The one that helped me was from Col. His name was Stuart Garrett. He came down to Waco Tx. took my car and fixed it on the spot and gave me and my family a loan car and money for dinner. It was a very good experince. He came down in a suit but changed to work clothes and he really knew his job. Mine had a rattle up under the head liner and they took the liner down and fixed it. The top of the car had seperated from the cross members. As for as the lemon law we never got that for but as I understood it that was next.
Help on wheel stud replacement!
tcspeer replied to bl_easy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes you will need to take the brake caliper off, and you may have to take the rotor off also. There is two bolts holding the bracket on that holds the caliper, I think they are 17mm. be sure to use a box end wrench on them so you wont round them off, after you take these off the rotor will then come right off. Subyluvr2212 may be right about the wheelbearing, but I did not have to hit mine hard it came out easy. You can try it if it dont come out easy you can leave it. As for as pulling the new one in I dont see any reason this would hurt the bearing. You dont need a lot of room on the back you will knock it from the front side towards the back.
tcspeer replied to bl_easy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKnock it out with a punch and a large hammer, before you put the new one in put some oil on it so it will not be so hard to get in. After you get it started you can pull it on in to place with the lug nut. They may be a better way to do this but this worked for me and I have seen other people do it this way.
Crank shaft bolt
tcspeer replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI take the belt that is on the crank pully and cut it to fit around pully then tape with duct tape to hold it. Then I use the large chain wrench that is sold at harbor freight to hold it, not the one that is on the end of vise grips but the one that has a metal handle around two foot long with the chain on the end. Then I break the bolt loose with a very large breaker bar, that large breaker bar that is also sold at the place where I got the chain wrench.
how to reset the computer CEL
tcspeer replied to dDigitalPimp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI take both battery cables off of my Legacy and the C.E.L. will clear. I dont think mine has ever cleared by taking off just the neg.
Portable Jump Start Unit
tcspeer replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am also looking to get one, Harbor Freight has the 400 - 900 amp on sale in the retail stores for 39.00 dollars until 7-11-05. They are very handy for jumping not only cars but the riding lawnmower that wont start at the next mowing season. Wal Mart also have them back by the batterys. I dont know which one is the best but I plan on trying the 39.00 dollar one from Harbor Freight.
New Brake rotors?
tcspeer replied to 97subaruGT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you can feel the vibration in the steering I think the problem is the front rotors. I would suggest you get the ones at Auto Zone for around 30.00 dollars each. They hold up fine on my car and it is right hand drive used for mail del. This means it is loaded with weight and over 500 hundred stops a day. Including crossing a river at the time they are most hot. I have not had any luck having them turned they warp really quick, maybe for regular use it would be fine.
Brake Caliper seizing up?
tcspeer replied to syphon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt dont hurt to replace just one caliper, You should only have to bleed the one you break loose. If you replace the master cyclinder you would have to bleed all four. But as Setright says it dont hurt to bleed all four.
Rough idle - sometimes it stalls...
tcspeer replied to Stormy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHas anyone checked the throttle position sensor?
98 impreza front calipers
tcspeer replied to littlefish's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe rubber boots are tough to get back in right on a rebuild, its much better to exchange for a rebuilt one. They dont cost much as long as you have yours off where you dont have to pay the core charge. Make sure you find someone with one in stock first.
Harbor Freight Code Reader
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes it was the 40.00 dollar one.
For the ones here that have bought them only to find out that they wont read the Subaru codes, I just wanted to let you know they work well on some other cars so dont throw them away. It read the codes on our Saturn great.
Brake stud replacement question???
tcspeer replied to teppichkopf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOr you taking about the wheel studs, or caliper bolts? Neither should cost much the wheel stud is easy to knock out with a hammer and then put a new one in. you can pull it in with the lug wrench when you get it started. The caliper bolt is not a problem if the threads are O.K. in the bracket.
So its time to buy a code reader
tcspeer replied to cookie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDont give up on the harbor freight scanner it won't work on my Subaru, but it works great on our Saturn. Someone else here bought one and said it would not work on their Subaru but it worked good on their other car also.
