Everything posted by tcspeer
Tranny Bucking
tcspeer replied to Pcarter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds a little like the problem we are having with our Saturn, the valve body is bad in our transmission. The transmission does not have to come out in the Saturn to replace it. I dont know about the Subaru. I think the cost to rebuild the whole transmisson would be much more than 1000.00 dollars, more like around 1800.00. Ours is bucking when we excellate mostly when going up a hill.
Help With Auto Trans Problem
tcspeer replied to mrtoyou7747's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCadetman, that is very good advice I wish I would have had it last month. We took our Saturn to a transmission shop for rough shifting they took it apart and rebuild it for 1800.00. The problem was still their when they finished so we took it to Saturn dealer and they found it was the valve body. The cost to fix it was around 500.00 dollars. So we wasted 1300.00. ( we took it back to transmission shop and made them fix it. they said they replaced the valve body but it must have been bad according to them.)
Removing timing belt on Lecacy, what tools needed?
Unless I missed something you dont need to take the crank key out. The crank pulley will wiggle right off once the nut is removed.
Stuck brakes...
tcspeer replied to Greg55_99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould also be a master cylinder problem.
Universal Joint?
tcspeer replied to mr. bliss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn my 1997 legacy wagon you can not change the u-joint you have to replace the drive shaft. The drive shaft is around 500.00 new. and 150.00 used. They are easy to replace. Lower the mud guard, unplug the oxygen sensor, take the two center bearing bolts off and the four little bolts at rear end. The front will then slide right off. I am on my third one. (288,000) miles of rural Rt. mail stop and go driving.
Weird chirpping sound, please help
tcspeer replied to Happyhighguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChirpping sound can also be caused by U-joints getting bad.
Coolent for 1997 2.2???
tcspeer replied to sisu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 1997 Legacy wagon 2.2 came with the green, I don't know if all of them came that way.
Off to J.P. Court
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is Ivan D. Harris Jr. I done a internet check on his name and it brought up around eight or ten different ones with the same name and middle initial around this area. I would think they are probably different ones.
Off to J.P. Court
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell I guess the constable must have served the summons on them yesterday, I had a message on my phone from Imports Specialists to give them a call back.
How long will my car last?
tcspeer replied to Skanky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAways check the idle pullys when you replace the timing belt, that is what got the engine on my 2.2. and it had 288,000 miles. I dont think I would replace head gaskets before they give trouble.
legacy brake problem help!
tcspeer replied to speakermakers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may have damaged one of the seals in one of the calipers when you pushed the piston back in. I would look for brake fluid leaking around the pistons in the calipers. It may take it a while to show up if rubber boots are good. If this problem was not there when you started then it is most likely caused by something you were working on.
Off to J.P. Court
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI also filed a report with the B.B.B. so he now knows I am on to his bad reports he has there. I would think he will bring a lawyer to try to keep me from bringing this up, which is O.K. that will cost him. If I loose I will have ten days to file an appeal in county court. We have a new lawyer here in the small town where I work and this sound like one of the types of law that he practices, so I plan on talking to him if I lose in the J.P. court. Thanks for all of the tips and suggestions everyone has given. I will let everyone know how it turns out.
Off to J.P. Court
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's very different in Tx. If you get a judgement here aganist someone for a wrong it is very hard to collect. Wages here can only be garnashed for Taxes and child support. You can file an abstract of judgment with the deeds record of the county but here again most propery is protected. About all I can hope to win (if I win) will be my car back maybe without having to pay the other 700.00. However I can file the abstract againist him and it will haunt him for ten years. Or maybe I can get one of the cars he stole from someone else. I think if he has over two he can be forced to sell and give up the money. But I have not won yet so he may not have anything to worry about.
Off to J.P. Court
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNothing yet, the court mailed my papers back and said I could not file for 30.00 dollars a day I had to file for a set amount so I filed for 4493.00. He took my work car so I had to buy something to run my Rt. so the next day I bought a 97 Chev. Lumina for 4200.00 dollars and the taxes and fees were 293.00. It should come up for trial before 90 days. Check out his report from the B.B.B. I have it here. He has been sticking it to people for quite a while, I may not win but I am going to stand up to him. Better Business Bureau at Fort Worth 101 Summit Ave., Suite 707 Fort Worth, TX 76102 BBB Reliability Report IMPORT AUTO PARTS/IMPORT SPECIALIST 3248 W SEMINARY DR FORT WORTH, TX 76133 (817) 921-3944 Local Business Start Date:January 1, 1984Principal:IVAN HARRIS JR, OWNERCustomer Service Contact:IVAN D HARRISPhone Number:(817) 921-3944Type-of-Business Classification(s):AUTO PARTS & SUPPLIESFile Open Date:July 1, 1979 The information in this report has either been provided by the company, or has been compiled by the Bureau from other sources. Nature of Business This firm sells auto parts both new and used. Some parts are special order and special order parts are paid for in advance and non-refundable. Customer Experience Complaints brought to the firms attention concern selling practices, service issues and refund practices. Specifically, complainants allege the final invoice is more than the original quote. Others allege the special order parts do not work and the company does not refund money on special order parts. When assessing complaint information, please consider the company's size and volume of transactions. Please understand that the nature of complaints and a firm's responses to them is often more important than the number. The following data concerns complaints processed by the BBB since the firm's file opened in July 1979 or over the last thirty six months, whichever is less. The Bureau received 28 complaints against this company during it's three year reporting period. These complaints concerned: Sales Issues (1) Customer Service Issues (19) Credit or Billing Issues (2) Refund or Exchange Issues (4) Repair or Service Issues (2) They were closed as: Resolved (13) Unresolved (5) The company addressed the disputed issues and exhibited a good faith effort to resolve the complaint (10) Of the total complaints in 36 months, 9 closed in the last year. Additional File Information In September 2002, the company met with the BBB to discuss the basic cause of complaints. The company provided a copy of the invoice which states.... "No refund on special order, used or electrical parts, no labor warranty on used parts." At that time, the company has agreed to work with the BBB to eliminate the basic cause of their complaints. However, as of this date, complaints have increased in number and the cause of complaints remain the same. Additional Information Additional Doing-Business-As Names:IMPORT SPECIALIST OF TEXASAdditional Phone Numbers:817-926-9704 Report as of 07/27/2004 Copyright 2004 Better Business Bureau at Fort Worth As a matter of policy, the Better Business Bureau does not endorse any product, service or company. BBB reports generally cover a three-year reporting period, and are provided solely to assist you in exercising your own best judgment. Information contained herein is believed reliable but not guaranteed as to accuracy. Reports are subject to change at any time. The Better Business Bureau reports on members and non-members. Membership in the BBB is voluntary, and members must meet and maintain BBB standards. If a company is a member of the BBB, it is stated in this report.
Off to J.P. Court
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI then left for the Ft. Worth Court house. After getting through the detectors I asked where the small claims court was. I then went there and found out I had to go down the St. and file in J.P. Court number 5. On the way there I stopped at the office where you get the name of the owner of the busssiness. I found out it was Ivan D. Harris Jr. After getting to court five I had the chance to file on him for 52.00 or his bussiness for 52.00. But I could file on both for 92.00 so I took that. I then came home and checked him out on the B.B.B.(which I should have done first) This you must see. You can check it out by going to Fort Worth B.B.B. and then seaching Import Specialists. He is so bad at running up the price on people that the B.B.B. met with him in 2002 to try to reduce the numbers of complaints, they then went on to say that it has only gotten worse. I dont know how this will turn out, but I am asking for 30.00 dollars for each week day he has my car ( its my right hand drive work car.) I do have the first written estimate and one witness that was with me. I plan to take the B.B.B. report along with pictures of my shop which sets in my back yard and is well equipped and then ask the J.P. if he really thinks I would have given Ivan the go ahead on this for this price when I have done it so many times before. My nephew is a big shot at a large Auto Dealer ship and he told me I dont have a leg to stand on that they can get away with just about anything. If I dont have a leg to stand on then I will just show up in a wheel chair but he is going to see the J.P.
Off to J.P. Court
I guess some of you remember back at the first of July the valves crashed in my 2.2. I went to Imports Specialist in Fort Worth and the guy behind the counter told me he would get me a 2.2 for 999.00 install it for around 500.00 and tow it for 100.00 all of this with E.P.A. fees and taxes came to a little more than 1700.00. Which I have the written estimate. He also told me before he installed it he would put my new water pump ,seals and timing belt on. About one week latter the owner called me and said he had the estimate for my car and it was going to be 2400.00. thats 700.00 dollars more than the first estimate. I told him he was nuts I already had the written estimate, he said well the pan came damaged on the engine they had shipped in and he could not let his mechanic do that other work he had promised and he would have to charge me. I then told him to ship the engine back and get one that was not damaged, and to leave the seals, water pump, and belt alone because I would change them when I got it home. About one week latter I went to get it and the bill was a little over 2100.00 he had done the work I told him not to do. I let him know I was not going to pay and he told me that I could not get my car. I said fine are you putting a lien on it and he said yes.
1997 Subaru 2.2 interference or not
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI like chains! I only remember in my life seeing one car being worked on for timing chain, and growing up one of my friends family run a mechanic shop that we hung around. I also must admit most cars did not have the kind of miles we put on them today.
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont know about the pistons, but I am having a engine put in right now. The price I have in writing is around 1800.00 dollars for engine and labor. Today they called and now want closer to 2400.00. I told them to stick to whats in writing or pull it out by the fence and we would let the small court decide for us. The pan came bent on the engine and they want to charge me to take mine off and transfer it, along with some others things they are coming up with. I told them if the pan was damage to send the motor back and get another one. I was not going to pay them for that. Last word I had from them was they were going to stick to the price we agreed on, but they was not going to put my new belt or seals in for me as they had promised.
Squealing Front Brakes
tcspeer replied to ahessler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have never used the silver pads. I use the semi metallic made by Albany from Auto Zone. Did you put some anti squeal (grease or spray) on back of pads?
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru3, yes you are right Subaru of America e-mailed me on 7-12-04. They confirmed what I had already found out the hard way.
T-Belt Tensioner and Idlers
tcspeer replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAfter second belt, change all of them. Mine went out at 288,000 miles cost me an engine.
Message from S.O.A.
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomehow this run together but it says the 1997 2.2 engine are interference engines as I found out the week before the fourth of July. So change those belts and check the idle pullys.
Message from S.O.A.
Dear Mr. Speer:Thank you for taking the time to contact Subaru of America, Inc. via E-mail. Your vehicle does have an interference engine. Also, I would like to inform youthat there is an open recall on your vehicle. To have recall WXI-66 performedon your vehicle at no cost to you, please contact any authorized Subarudealership and set up a service appointment. If you have further questions,please contact me at 1-800-SUBARU3. Thank you. Deneen BakerSubaru of America, Inc.-----------------------------------------------------------YOUR ORIGINAL MAIL:Is the 1997 Subaru 2.2 an interference engine? The valves were bent on mine whenan idle pully came apart.First name: ThurmanLast name: Speernull |||||Inbox © 2004 Microsoft Corporation. All rights reserved. TERMS OF USE Advertise TRUSTe Approved Privacy Statement GetNetWise Anti-Spam Policy
98 OBW water pump lifespan
tcspeer replied to jcibor1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes I think I would have water pump done while they are in their. I would think 133,000 is getting close to life span of pump.
Found at NASIOC
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would have been willing to give up the little more compression, to keep the non interference engine.
