Rooster2
11
Everything posted by Rooster2
I would trust the Walker name for a cat. They have been in the exhaust biz for a long time with a good reputation, and NAPA has a reputation of selling good quality parts. Just for giggles, how much is the part from a dealer? Expensive I am sure, and I am sure the quality is excellent, but hard to justify a super high price for your 98 with 200K on the odo. You might also want to see if you have a cut, bent, weld muffler shop in your area. Most are family owned. This type of muffler shop does work on the cheap, but for a cat they may be okay. Think about it.....they wouldn't be selling cats for long, if customers kept coming back with a CEL light problem from their cats. So, it is worth checking out. I had one of these shops replace my resonator on my 98 OBW. They simply eliminated the resonator, and replaced with a straight pipe. This is perfectly legal, as the cat still works on my exhaust. Cost was like $45 out the door. Car is very quiet.
Dave...........My 99 OBW trany is still running well with Trans-X. Sometimes, it may hesitate a second or two before shifting from R to D, but usually the gear transition is rather quick. I am still singing the praises of Trans-X. I can't remember when I wrote the original thread on this subject, prolly going on 3 years ago. I'm still sold on Trans-X.
I agree with you using Barr's, when a car is on its last legs. The cheap fix was the way to go. If you are like me, when a car reaches a certain point of age, high miles, and close to being worn out, it is not financially justifiable to drop much money into it. At that point, I consider the car a "town car," meaning drive only around town, staying close to home. No out of town trips, that a break down would leave you really stranded.
My 99 OBW has a slight steering wheel shake at freeway speed. It feels like it might be at the passenger front wheel. It is not a bad shake, just feels like the steering wheel has Parkinson's disease. Some history.........I recently had the half shaft replaced on the right front. The original shaft had actually broken into two pieces where the large nut threads onto the half shaft. The wheel bearing was not replaced, since my mechanic said the bearing appeared undamaged. I was thinking I had bad tires, (like a broken tire belt) so replaced them, but still have the shake. Ball joints and tie rods seem tight. I considered getting a front end alignment, but doubt that will solve this problem. I am thinking the rebuilt half shaft from Autozone may be the culprit. I know AZ half shafts aren't the best at $59.95. Any thoughts on how to proceed??
Same thought as above. The passage ways in the heater core are smaller then in the radiator, so they are prone to plug up. You may get lucky, and find the heater still puts out heat. If your radiator leaks again, don't recommend adding more Barr's. Barr's is an old product that has been around forever. I have used it successfully to stop a heater core leak that was misting up the inside car windows, and making the interior smell of antifreeze. On an old car, that was a lot easier fix then replacing the heater core. Back years ago, I had a 91 Subie Legacy that developed head gasket trouble. It over heated and caused the radiator to leak. I had a radiator shop install an after market unit. It had the square headed plug like you described. It worked just fine. It lacked the OEM cap or cover that the original had, that covered the top length of the radiator.
I finally pulled the trigger, and today bought 4 each 215/70 r 15 tires for my 99 OBW. Specifically, I bought the Yokohama Avid TRZ tires. I just wanted to report back to the forum that they fit just great, no rubs anywhere, and drive great. Car appears to be lifted bout an inch higher, compared to stock tires that were 205/70 r 15. I would recommend this upgrade to anyone buying tires. The additional cost of a few bucks more seems worth it to me.
I suggest you attach a flat of plywood or composite board, or whatever flat piece you have lying around on top of the existing roof rack. Affix the flat board with bungy straps. I have been amazed of the holding strength of multiple bungy straps to hold things in place. Then lay your lumber on the flat board, and bungy that load in place. The whole thing will look red neck, but transporting wood on top of your Outback would never be a pretty sight no matter what.
I think part of your hesitation is due to the bad knock sensor. When mine went bad, I experienced a noticeable loss of power and acceleration, though I don't remember hearing any popping or back fire noise. Install a new knock sensor, and see how it runs. How long has it been since new spark plugs have been installed in your ride? Could also be spark plug wire problem too. Does reading your CEL code(s) reveal bad knock sensor only? Any chance other code(s) are there too?
I just recently had the same trouble on my 99 OBW. I simply pulled off the road wheels, and using a large flat blade screwdriver, I pried back the dust or dirt shield away from the rotor. The shield metal is easily bendable, so that is why it gets bent in the first place. Mine got bent when I installed new rotors, and then later, when I had a shop install a new half shaft.
Since my wife asked the service guy when we were there and he told her it should probably be done, it'll get done sooner rather than later. She's certainly not going to listen to me Your wife must be related to mine. Like yours.....my wife would want the oil changed sooner rather than later, and be on my back to get it done.
I am not familiar with the product, but gotta think trying just a dab the size of a postage stamp on pass side will tell you what gloss level the product will produce. I agree with you, I don't like products that produce a bright shine when applied to the dash board. Just produces too much glare, and doesn't look good.
