Everything posted by ivantruckman
newly purchased 1986 GL Sedan-many questions
3at rocks:headbang:
foamy oil in the air filter, Yikes
my 86 gl wagon, carbed engine has got a very oily air filter now, could this be from a sticky pcv valve, all the vac hoses have oil in them too. the engine runs good , no reduction in power, kinda weird
so my wife calls me "LO"
try driving it to a dirt road if you can. my 86 gl dual range had a hard time shifting out of 4x4 before i got all the same new tires, it would only shift out on dirt or snow. just not dry pavement
A Few Pic's Of My Soob...
thats a beautiful thing, we have to get our sons interested in nature and cars, so we will have another generation of subie lovers
A funny thing happened.
ditto on the firearms subies , and bow hunting:headbang:
first pic of new lifted 83 wagon
no subaru is ugly, their like kids , love is blind
Going to be stripping the parts car...what do you think I should grab?
Agreed .....wagons rock.. im taking off everything but the shell on my parts car. .. but its in a pole barn ,, so no hurry for me
Going to Kalifornia...
i love northern california, its beautiful, i use to live in mt shasta Ca, but they have stupid gun laws, emissions laws, and everything in the state of california is known to cause cancer, i dont want cancer so i wont live there..
which is better? d/r or push button
dr rocks if your running 29's, im sold for sure on it
Slow starter?
cool.. hook two batteries in series and see what happens, lol. i have the same problem with my 98 forrester. everything is new still cranks slow3, but always starts
Free 87 wagon - toasted engine? - hurry if ya want it!
if i leave tonite ill get there in 4 days.. dang it. too far away
Positive battery terminal turns black
i use a silicone grease, its more expensive than vaselene, but it stays on longer in the heat, vaselene is good too, it keeps the corrosion off
Can't have my Subaru!?!?
in michigan we have a lot of dual range ea82's with rusted bodies, with no chassis to put them in to:-\
Idles to high/ radiater question
the dash guage sensor only has one spade terminal on it , and the cts has a two prong plastic plug., check the ohms between the two sensors, my manual says 3000 ohms cold and 800 hot,
Old Gen Meet... W/Pics!!
I heard you guys got a whole lot of rain, ill have to make a trip out there and bring a 4 place car trailer whith me , and snag some of thoes 250 dollar beauties and bring them home to the rust belt, its a little closer than the west
Electrical Switch for Heater Fan
the speed control is done by a series of three resistor coils under the passenger side dash near the fan motor, their is a thread here someware that has pictures, anyhow their easly replaced, less than 5 minits, you can get a known good one from a junk yard , or you can make new coils with nichrome wire and solder them in, either way its very easy
axle
i used a cutoff tool, (a small 3 inch thin air grinder) and sliced the doj just enough to crack it , taking care not to grind to deep so you ruin the splines. and used a good sharp chisle and a v bfh
Cheapest way to get the AC working again?
for diagnostics most shops around hereuse co2 to pressure test a system, liquid co2 to blow any debris out, like burnt compressor parts. yikes
for those who pull lthe front axles
awsome right hand ea81:headbang:
coolant temp sensor ???
would a coolant temp sensor malfunction cause the engine to idle fine then drop off and for a half second then idle fine and repeat this randomly, i have been having this problem for a week, have checked all the simple things to no avail..thanks
as nipper says, the system has to be evacuated, and a vacuum has to be pulled on the system. this does a few things, one it removes all the moisture, it removes all the incompatable r12 oil, and it also checks for any remaining leaks, once the system its on a state of vacuum, (i give it at least 45 minuts), you can fill the system, first the oil charge , then the remaining r134a. look for the ac specs on the hood to see how much in ounces to fill the system, or a F S manual, i have seen some air compressor powerd vacuum pumps online for 25 or 30 bucks. chiltons has a manual that covers automotive ac systems, its a good read, and comes with flowcharts, and explains the tools of the trade ie vacuum pumps manifold guages etc.
EA82 Oil Leak - Where's it coming from?
cool. maby i can hook up a resevor and a washer pump, sweet smoke screen any time i want. i gotta do that
rear control arm rusted clean thru
sweet ...thanks all. off to the junkyard in a blizzard. we get lake effect snow here real bad. fun fun fun
sorry ... the broken car is a 86 gl 4x4 the parts car is a 1990 loyale 4x4
walked out this morning and noticed that my right rear wheel was bent in about 5 inches at the top, my control arm (right rear) rusted thru . its just hanging on by a little bit of metal at the top, yikes. does any one know if i can use a control arm from a 1990 loyale 4x4, their is one at the local u pull jy, i could get the whole thing from driveshaft to drum heck even the shock, it looks new, they look the same to me, thanks in advance
