archemitis
Everything posted by archemitis
  1. everything i have seen says 2200 for my 87, 2wd 5speed, no power anything. compared to my 4x gl wagon, its a world of difference
  2. thats what im thinking. they make turbo motors 8:1 so even if you did run crappy gas you'll prolly be ok if you keep your foot out of it. it should be fun, maybe i'll relieve the combustion chamber a bit when i have the heads off.
  3. whatever it is napa has it and its easy to find.
  4. npt=national pipe thread
  5. its not that hard to eyeball. its either a 1or2 npt if i remember. go to napa, and one of the old guys(not the young guys, they never know) which one it is. napa has alot of brass fittings, even get a t so you can use the mech guage and sending unit. i think ea81 and 82 are the same
  6. by af controll? you mean something like a super afc? and timing controll, like a retard when boost hits? it'll be stock boost, for a while, with the legacy turbo, and an intercooler and bov of some sort.
  7. not 40 lbs more, more like about 15, a piece. i have bottom of the line hatch seats.
  8. thanks legacy777 thats what i wanted to hear! i want to use the na computer, cuz thats all that is in the junkyard. can i just plug a turbo computer in? will i then need turbo injectors and fuel pump? hmmm. i want to use stock subaru stuff, without getting into rising rate rugulators, and piggy backs. im thinking even if i cant tweek it at all i will be happy with a turbo 2.2:headbang:
  9. I HAVE HAD A 10:1 COMPRESSION TURBO CAR WORK GREAT! and there are a couple 9.5:1 compression ea82s running around with great results, on stock computer and internals. im just wondering about the fuel injectors and computer. does the maf sensor just measure the air coming, even if its boosted? trust me the high comp will be fine:banana:
  10. can you just stick a turbo on a 2.2 from 90-95, if its na? will the stock computer be fine with stock, or higher boost levels?
  11. wow. that might just be worth 20 bucks. i am starting next month as well. race ya! hehe just kidding, hoping to finish by spring.
  12. i gotta have dual port heads, cuz thats the turbo manifold i already have:brow: will obd1 work good with a turbo at stock boost levels?
  13. hehehe if they mention putting hub caps on your car, in the same ad you prolly can be sure it sucks... or blows...
  14. untill i stumbled onto the byb forum:banana: ej swap conversation all over the place
  15. but if everything is in tune, and you are intercooled, the most hp is right at stoic. i'de rather run stoic than rich and melt my manifold and turbo
  16. OKOK. guess i knew that was coming. 2.2 it is! then its seeya mustangs:burnout: seems like im gonna have to just stumble through it, cuz i am not finding much ifno. everybody wants to make money off it, isntead of giving it away
  17. was it a new radiator or just a junkyard one? you could have a sticky thermostas, even though its new. does your auxillary electric fan work? are you using ac?
  18. SEE... you said stock EA81T. im gonna use a na lower end, and push about 15lbs with a t3, and use mpfi, or spfi. that should double my 75 horsepower, and i will save alot of weight. i figure i can either focus on building manifolds, or swaping the motor, and tranny.
  19. how bout using the ea82mpfi system on an ea81? custom intake, but it would handle a turbo alot better, with more boost:banana:
  20. what are you doing with the old motor? i could use the heads cant you use the efi pump and just put a regulator on it, ant the carb? 2-3 lbs is stock for carb, right?
  21. i am torn here. i have a ea81 hatch, with carb. i am trying to figure out if i should graft mpfi from an ea82, and build custom manifolds and turbo/intercooler, with a t3. or put a 2.2 na in there. a stock 2.2 would have as much hp, if i turbo the ea81 right , argh. what do you guys think? its for street use, and i think i'll stick with 2wd 5speed. hondabeater:clap:
  22. are all ea81ts multiport injection? do they have a spider intake? do the ea82 mpfi intakes fit on these heads? anybody have good pics?
