Everything posted by EVOthis
I have a 96' LEgacy L Sedan AWD with a cable clutch.....the lock nut was lost by the previous owner. Now whenever i press on the clutch pedel the adjusting nut comes loose...I was just wondering the thread size of the clutch cable....if anyone knows it would be very helpful (it seems every size i try doesnt fit).
Hey Fellas....got a 1996 legacy L ej22 with a 5 speed...the abs light came on about a year ago....and just had time to pull up the flash codes......both rear sensors are open and it says there is a valve relay problem....does anyone have any information on this or had the same problems.....by the way the car is lowered so could that have anything to do with it......just wondering what i should do first to try and fix?
Well i have been reading some posts on here about how the white connectors are for the front 2 cylinders and the black/gray connectors are for the rear two cylinders....also i was browsing over a wiring diagram and just shot a look at the wire colors......im so thankful that it wasnt an internal engine problem....the car does have 185,000 miles on it....
no i have a ton of oil leaks but thats just a subaru for you....no its not burning oil....i noticed that the cyl 2 and cyl 4 Fuel Injector plugs were swapped...i swapped them back and now it seems as though everything is fine....i let it idle for about 30 minutes and no codes and i didnt hear the miss at all.....all good for now!
very true.....my timing belt slipped a few months back....and i thought my engine was done.....than i saw i had a 2.2...THANK GOD!....yes the 2.2 Liters are non interference and the SOHC 2.5 Liters are (the valves hit the piston) and the DOHC 2.5 Liters are (the valves hit the valves)....
hey guys.....this isnt so much a performance question like every other one of my posts.....but how hard is it to convert a 1995 1.8 Impreza FWD to AWD?
Hello all just a quick question.....what exactly is the difference between phase 1 and phase 2......is it the cylinder head? any insight would be appreciated.....
