Everything posted by EVOthis
Last Year of The EJ22?
I did a few searches on here and couldnt really find anything concrete about my question...When was the last year the EJ22 was used and in what model?....thank you all in advance for your knowledge and time....
Impreza to Legacy Trailing Arms?
Hey guys....had a quick question....will rear trailing arms from a 95-98 AWD impreza sedan fit on a 96' legacy AWD sedan? Any help would be appreciated, and thank you in advance for your time and knowledge
Please Help!!!!
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthank you all very much.....i have spoken to a few master techs and they have never heard of the phrase "torque bind"..????? nonetheless i appreciate your knowledge and time.....
ECU is dying!
EVOthis replied to Blondie521's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe ECU is on the passanger side, under the carpet, directly below the glove box......just pull back the carpet and you will see like an access shield protecting the ECU....
Please Help!!!!
Hello All.....I was just wondering if torque bind occurs both in automatics and manuals?...Also I have read a little bit in previous threads about it but still dont get exactly what happens.....Is there anyone who could explain it to me in detail?.....thank you in advance for your time and knowledge....
Mountain passes, traction tires, and AWD?
EVOthis replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know from my experience with snow.....if i have my regular tires on my suby....it doesnt give me a sense of security....i have actually gotten stuck with my reg tires....i also have blizzaks and they do wonders for me....i would say if you have any doubts as to weather or not you will have trouble dont try and conquor it...
The new forester
EVOthis replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNOOOOO its starting to look along the lines of a crossover....
CEL after repair
EVOthis replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, if the head gaskets were indeed blown and the vehicle was burning coolant....theres a chance that the coolant contaminated the O2 sensor.
96 Legacy 2.2L Oil Leak PLEASE HELP
EVOthis replied to stonecloser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI also have a 96 2.2 my front cam seals started leaking at around 120,000 so i would look at those...if they are indeed leaking you will see oil at the timing cover....Also I would double check the pan gasket......I know i have had some oil leak out of my seperator plate which is on the rear of the engine ( not exactly sure which models/ years had the plate)...but it USUALLY gets trapped in the bell housing......if you have some time i would clean off the entire underside of the engine REALLY well than drive the car for a few days and take a look again to see where the oil is located.....good luck!
Brake Questions????????
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalright thats what i thought.....thanks for the confirmation buddy...
Hey Guys....I have seen this on a few threads here and was wondering what exactly they are talking about......when someone refers to a part of the brake system as 1 pot, or 2 pot, or 4 pot......what specifically is the "pot" refering too or what does it stand for???????
Nasty vibration under acceleration.
EVOthis replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWheel Bearings?....Ball Joints?
How hard is it to replace a fuel injector?
EVOthis replied to mattejb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi had the same problem.....i searched high and low for the missfire ( in my car is was P0302 =cyl 2 missfire) everything from "dropped valve guides" to plugs and wires, i even hooked up the oscilloscope ......it turned out that the fuel injector connectors were swapped from cyl 2 to cyl 4......now my suby runs perfect.......check that before you go replacing things.....i know on my 96 legacy 2.2 the injector connectors are color coated..... OH, also my miss ONLY occured when i was stopped at idle. i also had a very rough idle.
1996 Outback: Clutch renewal
EVOthis replied to jadburnett's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know when i did my clutch job in my 96' legacy about 5k miles ago everything went great i had the trans out in under 2 hours but getting that thing back in with the car on jackstands in your driveway was hard as hell.....also i dont know if you have a seperator plate in the model/year but i would examine that pretty closely for oil leakage......just my experience....good luck!
EGR Solenoid/ Where to get?
EVOthis replied to Gr8subi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it happens that the EGR is the problem....I have bought tons of parts for my suby off of autopartswarehouse.com....i absolutly love it....terrific service, right parts, and great prices....just my preference though.....
Loose Shifter in 96 OB
EVOthis replied to timpappas's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell im not to sure about the bushings but for that little spring the easiest way is throw a jack under the trans unbolt the crossmember and it right there......Pretty Simple.... ( I tried with the crossmember in but i almost broke my hand:lol:
EVOthis replied to timpappas's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have the same exact problem in my 96' Legacy....I just got finished doing a clutch in it and i noticed that the little spring that connects the shift rod to the stay rod was missing......I didnt bother getting it cause it was a semi-long ride to the dealership, but at first i also thought it was bushings....
Successor to the 84 wagon
EVOthis replied to goatman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi like 2.2 L....I have 185,000 on my 96 legacy and it still runs great...me personally i tend to shy away from the 2.5 because i have had some bad luck when it comes to timing belts.....96 2.2 is non interference...when (and correct me if im wrong) all 2.5 Liters are interference......just my opinion
10" and still snowing
EVOthis replied to Downbound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDamn...You guys are lucky its been nothing but rain all day here in PA.....
Brake Rotor Upgrades...Some Questions.
EVOthis replied to Bluestone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPersonally I would get a pair of cross drilled rotors...not only do they help with getting rid of heat they also dissipate any water that happens to get in between the pads and rotor. I have been looking for a while to upgrade my brakes... I have been looking at AP, Wilwood and Hawk Performance...just my two sense.
1998 Legacy GT sedan, Ltd. Common mechanical problems?
EVOthis replied to D Love's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdont forget to Look Closely for any oil leaks!
it's here... '08 STi
EVOthis replied to zstalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont know im kinda likin the old body style.....nonetheless it is in the neighborhood of 300 AWHP!
Brake Light and Battery Light? PLEASE HELP
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell you were right on this one.......i put a system in my car....so the guy said that is what fried it...i have like a 1800 watt kenwood amp goin to a rockford P3.....nonetheless thank you very much..(oh and i got the new one for FREE!)
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXassumingly enough the battery light doesnt come on if the battery is bad does it?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo I dont think i did get the lifetime alternator....i just cant believe that it would take like less than 4 months to toast an alternator......thanks for the insight guys
