Everything posted by EVOthis
Nasty Vibration!
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok but the question still remains as to how to get the fluid back into the tailshaft houseing after you replace the visc. coupler? and how to identify which exactly is the tailshaft houseing?
Nasty Vibration!
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have a 5spd........so are you saying that the clutches are indeed bathed in gear oil.....i did do a trans fluid exchange about 7000 miles ago........what do you know about the Visc. Couplers in the 5 Speeds?.......thanks in advance....
Nasty Vibration!
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey WA....i was just looking over this post again and i saw were you said the viscous coupler was a sealed unit.....isnt the coupler surrounded by a think fluid?......if i were to replace the coupler how would i get the fluid back in there?....also you are refering to removing the tailshaft houseing NOT the transfer case houseing?....how do you tell which is which?....is one behind the other?......you seem like one of the right people to ask these questions too....you do answer the majority of my threads with knowledge.... again thanks for your help.
Rough idle
EVOthis replied to e4620's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXas a subaru tech im sure he did both of these.....but it doesnt hurt to double check..........make sure all lines, especially vacuum lines are hooked up and properly.....if you have a vacuum gauge i would run a quick vacuum test and see what youve got...did he set the valve clearances to spec?
brake problem 97 legacy
EVOthis replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you can, get it in the air and check for any leaks if none are visable i would bleed the brakes and see how it feels........by the way how does the brake fluid look?
Check This Out....
EVOthis replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdear lord whats the top speed like 50.....
91 AWD weird feeling when making a tight turn...
EVOthis replied to Rev's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXill triple that....im just starting to run into that kind of problem with my 96' AWD legacy.....i hear its not to hard to fix....
Regreasing Wheel Bearings--worth it?
EVOthis replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXas far as i know i still have the origional wheel bearings.... i have 187,000 on my 96 legacy and i havent had to do them yet....
Reaplacing Driver side Rocker Cover Gasket
EVOthis replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you have any gearwrenches they worked out excellant for me.....
Help needed: Window problems
EVOthis replied to eagleb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have a 96 legacy and the only time my drivers side front window seals properly is when i close the door.....ex: if i were to put the window down while driving than put it back up you can def. hear the air and a small bit of seepage coming through ( i think its because our doors dont have a frame around the window)....i have a couple of buddies with subarus and they all have the same problem......i also have the window rattle when i close the door with the window partially down......it doesnt really seem to bother me at all but my guess is something is loose.........just my experience.....
torque settings
EVOthis replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlook up this kind of question on endwrench.com.....they may have something....or i believe online....ALLDATA has a reference and spec section you can use for free.....
torque settings
EVOthis replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat model? engine size? year?
Timing DOHC vs SOHC
EVOthis replied to SuBrat84's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi just read those endwrench articles the other day......very easy to understand....prob. just as easy to mess up....
legacy from the fields...fuel problem
EVOthis replied to scrapdaddytatum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX...the easiest way i found to get to those relays is to remove the screws which hold the fuse block and the whole thing is one piece your can just slide it down and it comes out....its a b&*%$ trying to identify them correctly with the fuse box still up there....
Has Anyone!!!!
EVOthis replied to chadwick35/04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah just saw that ej26?......
Soft drinks on heater/air controls.
EVOthis replied to Gene J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi personally found some q-tips with brakekleen on them work excellant...i also had a ton of sticky stuff in my heater control buttons.or even if you have like a long pick and wrap like a shop towel around it. just my experience.......
A New 2000 Engine Questions And Dealer Issues
EVOthis replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just did the Valve Cover Gaskets on my 96 yesterday.....it is an ej22 but it wasnt nearly as hard as poeple have made it sound....i did take out the battery though.......good luck!
91 Legacy Turbo erratic excelleration
EVOthis replied to BoostedBalls's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXboost controller? just a thought....
What Kind of Engine Heater For Cold Weather?
EVOthis replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjust to jump on board here.....I had no idea that block heaters were that easy to install.....def. no need for one here in PA...but wow i always thought they were pretty complicated....
First Post, saying hey...
EVOthis replied to 8788dyno's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome!.....I also just joined a few months ago........there are sooo many smart people on here its a huge library of information...
rear washer squirts during acceleration... ('98 Imp)
EVOthis replied to Spiffy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthats pretty funny skip!
Dude, I just got snaked by a Subaru
EVOthis replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwould that be an experience or what?
Brake Fluid flushing method ... discuss....
EVOthis replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXman.....i still gravity bleed all my brakes....works well...why change?
Tachometer?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks skip...ill have to see becuase for a while i have been wanting to put like a gauge pod in my legacy so this may be the excuse to do that....
Tachometer?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks skip.....i will do some testing over the weekend and see what i come up with....my idle is perfect when im out of gear but when im in gear idling it seems low......again ill see what i find when i go over some things with a fine tooth comb....
