Caboobaroo
Everything posted by Caboobaroo
  1. Hondasuck's turbowagon had a stock rear swaybar but yes, it was wimpy. Now the 5-lug and those bigger swaybars made it handle on rails:headbang:
  2. this project started like over a year ago, right before I bought my RX. Now my RX has taken all of my thought away from the Brat and seeing it sit there as literally a bare shell, I had a tear come to my eye. I missed harassing all the stoopid little kids with it. Hopefully I can get a website going called www.fattybrattyburnouts.com
  3. Yeah thats why I was getting a little confused because I know that most of the EJ series cars have 4 struts so I musta been getting myself all confused while looking at different parts. Hmmm, LGT coilovers..... I hear the bank breaking already:rolleyes:
  4. Nope, I'm gonna leave it slammed like I had it. Also going to leave it RWD as well but I plan on dropping a Weber onto it, doing my custom EA81 front suspension/brake swap with the custom control arms I made years ago, plus a rear disc brake conversion. Most of the mods are going to be done on the body itself, like shaved doorhandles, locks, mirrors, the EA82 style popping gastank latch, my gen 1 airdam I have, plus a few other things. I'm rollin it back into the shop here in a couple weeks once I get a bit more work done on the RX.
  5. So today, I have declared to work on my '78 Brat. I'm going to get the fornt suspension put back underneath it today and hopefully back on 4 wheels. Then I'll be putting a hydro lifter EA81 into it with a dual range 4-speed that will be locked into 4 hi. I'll only have a few things missing which won't matter too much to get it back on the road, I just miss my little lowered Brat:headbang:
  6. The dash from an EA81 vehicle will fit into your car if I'm not mistaken
  7. yes but you seem to forget that injectors have a limit themselves and unfortunalty, our injectors are already up into their 80% range. Bumping up the fuel pressure too much will max them out which isn't much for our injectors.
  8. well I was wondering about using Impreza suspension in the rear for an upgrade. I know I can put coilovers on the stock shocks, just looking for more of an upgrade;)
  9. sweet! well since we have the extra parts laying around, might as well just do that then trying to stick a 5-speed in there for right now. Eventually, it'll hopefully get a NA d/r 5-speed;)
  10. any pics of the work done to it besides the ones of the car done?
  11. sweet, I also forgot to mention that he said it wasn't reading on the stick so he added like a quart and a half to it before he could read it on the stick. Fluid seemed to be all right in color but I'll drive it again and see if there is a fluid swappage between the front diff and the tranny. Anymore thoughts?
  12. So LUVMYRBAT's daughter has this '84 t-coupe. Yesterday, while driving around town, the tranny started making a whirring noise on decelleration. I took it for a quick test drive (and BTW, it hauls butt compared to the turbo Brat) and heard the same sound. Whenever you're on the decelleration, it has this loud whirring sound coming from the transmission. Acelleration and cruising it seems fine, no slippage, just the sound when you're off the gas. I have yet to crawl underneath it to see if there's a chance of something rubbing on it somewhere but its weird. Also, on decelleration, with the tranny in neutral, it makes the same noise but not as loud and the speed of it goes with the speed of the car. Any thoughts? Oh, tranny has been replaced before in this car. This is the replacement tranny LUVMYBRAT got from TurboXT a few months ago. No problems until this.
  13. I can't wai to get a set and instlal them. Maybe then I won't have any leaning out issues at stock boost due to the TD04 flowing more air.
  14. thats what I have been thinking I was going to have to do. Good thing I got tons of spare intake gaskets. Thanks Tex!
  15. yup, that would be the thingy that I have sitting on a shelf in my garage cause I don't know what to do with it:grin:
  16. I had this sort of problem before as well. Check inside the car where the clucth cable comes through the firewall. I know on my RX now, and a few other EA82s that I've worked on, there's a spring down there and if its not setup right, it'll go to the floor and not return. Also, did you check the clutch for as well? I know that where it pivots will sometimes break and it will do the same thing. If the clutch fork didn't break, make sure the pivot is lubed up really good to prevent it from wearing and breaking.
  17. I'd go with a BOV... awesome whooshing sounds and my RX seems to be ok with it:D
  18. you can use a donor car that is any EA82 except the XT6. Doesn't matter the year, just make sure it doesn't have the air ride as well, plus check to see if the struts are still possibly good. Any signs of oil residue on the cylinder behind the spring and I would just move onto the next car...
  19. so I'm guessing you used the TPS for the spyder intake cause I believe you used a NA intake like I did. From what you're saying is just to leave it as is and it should be fine? Just mess with the timing and get her goin huh? I'll just have to do that... Also, since you decided to respond to this post as well, how did you make the AAV fit? Mine is hitting the outlet on my TD04. If anything, I can put it on the firewall and run a couple new lines to it with the wiring as well...
  20. for the front strut assemblies, this is what it will consist of when removing them from a donor vehicle. Unbolt the 3 nuts on the strut tower, unbolt the bottom of the strut from the knuckle. Pull the brake line off the side of the strut and voila, strut assembly. For the rear, there are two bolts that hold the top of the coilover to the body and one that bolts the bottom to the trailing arm. Remove those 3 bolts and you're set!
  21. So discussing this matter with kingbobdole, having my own FSM for a spyder intake, and a cut apart 3-pin harness, I'm still having issues on figuring this all out. Now the 3-pin harness only has 2 wires going into the TPS, whereas according to my FSM for the spyder intake, there's 4 wires going into the TPS. I have specs for the spyder TPS as far as voltages and whatnot, but she still has this hesitation I mentioned in another post. So, experts, how do I retrofit a 3-pin TPS onto my spyder intake? I can cut apart my 4-pin harness on the spyder if need be, thats not a problem but having a basic wiring diagram would help greatly! If its a matter of cutting and splicing a couple wires together and mounting the TPS, I can do that but without the FSM for the 3-pin TPS, I'm totally lost. Also, on the 4-pin harness, it shows the wires going into different spots on the ECM, or is it because the ECM from an XT is totally different from a regular EA82 MPFI ECM? Thanks for all the help since I gotta get my RX on the road ASAP!
  22. the turbo that came on the Eclipse/Talon is a TD05 which is very similar but yet different in its own ways. The TD04 is a stock turbo that comes on the WRX's.
  23. wow! looks good. Have you gotten a chance to wire it in yet and see how it works with the modifications made to the body and grille? Keep up the nice work man!
  24. all you need are the struts assemblies and rear coilover assemblies from a parts car or junkyard. Its pretty easy to swap the stuff in, just go pull it and swap! Should run you pretty cheap.
  25. Who here is running an aftermarket ignition setup like an MSD 6AL or 6A? I'm going to upgrade to this here soon, along with bigger injectors, FPR, and a few other odds-n-ends. So what are you running and how is it working for you?
