Everything posted by Caboobaroo
ea 82 lift pix
There's been a few lifted EA82 sedans. What color was it?
Guess what the BAJA hauled home?
Caboobaroo replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks like an EJ22T
Is it the power steering pump or alternator?
Caboobaroo replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI bet if you spin the alternator by hand and listen carefully, you'll hear it squeak. Reason why it would be louder while the car is running is because of the tension the belt puts on it.
Cam Carrier Removal Question
If it were me, I'd get it back together with all the new gaskets, put 1/2 a can of Seafoam and 1/2 quart ATF, then some 5w30 oil. Let it run at an idle for about an hour, shut if off and immediatly do an oil change again with a new filter. If its nice and warm plus the additives, it'll help clean everything out of the engine.
There's also a small rubber coated metal ring between the cam case and the head on both sides of the engine. Gary might know a place to get them as well but last time I bought some, I got them from www.thepartsbin.com. They're just a couple bucks and I would highly recommend replacing them while you're in there.
You can do it either way. I usually pull the timing belts after I've loosened the 3 cam pulley bolts and continue dissassembly since I feel its the easiest for me at least. I have seen it done without taking the pulleys off as well without any ill effects
Caboobaroo replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt seems to be common for the alternator to start chirping. Seen it quite a few times on high mileaged EJ Subarus. Bearings are starting to make noise and before too long, the alternator will quit working.
Brakes going out...
Caboobaroo replied to gijoe985's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf for some reason you end up not being able to figure it out, I'm at a Brake and Alignment shop over in Kirkland off of 405. Bring it by and I can take a look as well.
Hatch Patrol annual XMas tree run
I bet! I ended up doing a clutch and rear brakes Sunday at my house on a '02 WRX wagon.... I've been paying for that since then:-\
I wish I could have made it. Carrie came down with a nasty sinus infection and a stomach bug which ended up getting passed on along to me unfortunatly. If not, she could have hung out with Renae and Rob and I woulda gone up lol:lol:
I long for the boost love
She's got more pine needles on her from sitting under the trees in my yard... Maybe even a couple pinecones but no actual progress on the swap:-\ Granted, I think I figured it out. Getting together with another brain tonight after work to discuss!
Why stop at EJ swap?
I used to run around those parts a few years ago. For the Forester 2.5, they are decent engines but they do have headgasket issues so ask if its been done. If not, they're a ticking timebomb sort of thing. The difference between the old GL 4wd and the Forester AWD isn't the axles or drivelines, its the way the inside of the transmission is set up. The 4wd Subarus are like a 4wd truck but instead of being RWD, 4WD, they're FWD, 4WD. The AWD Subarus have a center differential that help distribute the power front and rear but is a differential so it can prevent binding while driving on dry pavement. If I were you, I'd do a 5-lug conversion using the correct XT6 parts and the Forester parts, then swap the drivetrain into the car and you'll be done. Granted, its not that easy but it is very time consuming if you've never done a full swap with wiring harness like this.
EJ Power Steering rack into EA82 car
Gloyale, I have a rebuilt rack that I've been toying with the idea of selling. My RX has the EJ22T PS pump and half the lines. I went to Napa and for $23 they took the ends of the EA PS lines and mated them onto the EJ PS lines using some swivel adapters that tighten down when you tighten the lines down. I'll see if I can get a couple pics tonight if its not too dark out. I also have comparison pics of a WRX rack next to said rebuilt EA rack but I haven't uploaded them yet
EJ22 to EJ22T wiring problems
In theory I think it matter. If the neutral safety switch isn't wired in, then the engine shouldn't even crank over. Now I bypassed the EA82 neutral switch since I was originally a 3AT but the ECU gets a signal from the TCU to tell it that the trans is either in Park or Neutral... Maybe I figured out my issue?!?!?!?!
Almost sounds like the same issue I'm having with my swap. I have a EJ22T harness and everything in my '87 but the ECU isn't grounding my FP relay and my main relay isn't clicking:-\ I'll be watching your thread closely and hopefully someone can be most helpful:grin:
xt6 suspension under ea82
All EA82/XT6s with a rear sway have them mounted to the main trailing arms in the rear. I've also seen people modify the arms to accept a swaybar when it didn't originally come with one. The main upgrade using the XT6 stuff is the fact you'll have better brakes and a little bit better suspension. I like to use only the parts I have to for the XT6 and then use EJ parts the rest of the way for more upgradable parts.
EA82T + Digidash questions
There's a bracket thats supposed to be on the bottom of the tranny about 6" from the tailshaft section. This is what bolts to the downpipe. Sounds like the car is a GL sedan with loaded options.
1986 GL front and rear diff questions
The vacuum diaphram is on the driver side above the front diff, seen in this pic. There's a cable that goes from it to the center diff near located in the tail section of the tranny. If it doesn't have it, then its going to be a '85 '86 RX/GL-10 part time dual range 3.7 tranny.
All hail the Subaru!!! Best snow vehicle EVER!!!
I put on some Blizzak WS60s onto the SO's '09 Hyundai Sonata Limited last night. That car is fantastic in this stupid crap. Enough weight over the front end to keep great traction (3.3 v6) and heavy enough in the rear to prevent it from washing out behind us. I dearly miss my XT6 but it needs too much work before I want to drive it again:rolleyes:
timing belt fixed and now whines
Caboobaroo replied to paulo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck out this thread, it might help http://www.ultimatesubaru.org/forum/showthread.php?t=116220
wiring diagram help
I've built a couple harnesses for '81 Brats. What sort of issue are you having?
Meet Stanley the wonder Van
I love the name you came up for him Jamie!
Headlights not working on 78 Leone
This question was just asked in the last couple days and I answered it. Its a very common issue on the gen 1s to have a failure in the main power wire from the battery to the headlight switch. http://www.ultimatesubaru.org/forum/showthread.php?t=117594
Electronic distributor swap for EA63 and EA71 vehicles
Glad it worked out for you. It had been so long since I had done this conversion, I was kind of rusty on what all I did but glad it helped you out a little!
Power steering whine...Air?
Caboobaroo replied to LocalHero's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThose O-Rings were going to be what I was going to mention but it looks as if you beat me to it. Anyways, the O-rings can be replaced with generic ones from a parts store. I've gotten them before from a generic parts store and from a hardware store (only thing around and I was lucky!) The writer of the article you posted in your original post, is actually a friend of mine that owns an independent Subaru repair shop here in Kirkland. His shop was voted for best independent shop in the area from consumers. If you need anymore help, give either Justin or Ryan (another really good friend of mine) a call at their shop. (425)828-3600. They can even get the O-rings you need and can ship them too IIRC.
