bratman18
    14
Posts posted by bratman18
  1. On 2/1/2020 at 10:52 PM, Sundancekidd said:
    Hello subie community! I’m new to this and need some help. I have a 09 wrx and saw a guy on nasioc post his lifted 09 wrx up for sale. In the description he said he used 2012 forester struts. I tried contacting him about the lift but no reply. So I just decided to just dive in and see if it would work. Haha not the brightest decision. I got the front passenger strut in But had to pry the control arm down a ways for it to line up. Also unbolted my sway bar to allow for more drop but my concern is the cv has a bit of an angle to it. Did the same on the driver side and with all my night I couldn’t get the bolt holes to line up.  Worried that it’s not correct or I need to do something else for it to be right. Has anyone else lifted an 09+ this way? Just need a bit of input. Thank you for any help on the subject.
    It's really too much lift to be reliable on the newer models. To lift that, it would be best to get an actual lift kit. I recommend andersondesignfab.com
  2. Havent been on here much, but I'm trying to find out what's needed to run the nissan rear calipers on an ea82 car. The ones with the mechanical e brake hook up. I have a set, and planned on using them on my gl-10 since I converted to 5 lug, but it doesnt seem like the cables are long enough. Or there very well could be something I'm missing. I figured someone would know on here. Thanks ahead of time.
  3. On 3/2/2019 at 10:17 AM, czny said:
    Suzuki Samurai, 1984-88 Nissan720 PU King Cab, etc 4x4.
    On 720 Nissan PUs VIN plate is on passenger side of engine compartment. Lower RH corner has diff info. RB39 or RB41 is what you're looking for
    Nissan used RC for R200 diffs & RB for R180 diffs in most '80s-'90s vehicles.
    https://row52.com/home
    Unfortunately, anything that old is long gone around here, even in junk yards. Which makes it more difficult, because of getting a transfer case with the shifter and driveshafts.
  4. On 2/28/2019 at 11:23 AM, czny said:
    https://www.ultimatesubaru.org/forum/topic/20721-solid-axle-lifted-subaru/
    https://www.ultimatesubaru.org/forum/topic/135063-2nd-transfercase-rigs/
    There's other on here looking to do the same thing bratman18, like alexbuoy.
    And myself later after EJ conversion is finally done. Already have a Nissan Xfer case & driveshafts.
    There's a thread somewhere here in past that talks about moving lower x-member forward 2 inches.
    I appreciate you finding those posts! I havent been able to find anything, and I've searched. It looks as though that front diff mount is mounted solid, is that correct? Looks like I need to find a transfer case with shifter and driveshafts attached, so I have a starting point.
  5. 4 hours ago, Rallyru said:
    I built my own crossmember to hold the engine. It won’t fit with a 4 inch lift. 6 is minimum but 8 is better. I have a samurai transfercase but Nissan 720 is the most common to swap in.
    Ok, no biggie about needing a 6". How did you mount the front diff? Thanks for the info!
  6. Yeah, I have a 6 inch lift, but only have 4 inch subframe spacers etc. Was hoping to not go bigger on those. How does your engine sit in the cradle? Did you still have the engine crossmember spaced down, or is that in it's normal spot, and the diff mounted under that? Thank you!
