Everything posted by bratman18
Nissan rear calipers
Used, but in good shape. Actually bought them from a member on here on the rust free coast haha. Open to offers!
- 2.5rsti
These are now for sale as I'll be going full ej brakes.
The Unofficial "How to Lift your Impreza" Thread
It's really too much lift to be reliable on the newer models. To lift that, it would be best to get an actual lift kit. I recommend andersondesignfab.com
Found this thread after doing a search on google, that answered my questions.
How did you route the cables? Where did you have them exit the car through the floor?
Yep, after talking to a couple other people, I found that to be the case. I actually tried sending you a message before posting this, but it said you cant accept messages.
Havent been on here much, but I'm trying to find out what's needed to run the nissan rear calipers on an ea82 car. The ones with the mechanical e brake hook up. I have a set, and planned on using them on my gl-10 since I converted to 5 lug, but it doesnt seem like the cables are long enough. Or there very well could be something I'm missing. I figured someone would know on here. Thanks ahead of time.
Installing a transfer case into an EA82
Yeah, I wonder if he is still making adapters.
Unfortunately, anything that old is long gone around here, even in junk yards. Which makes it more difficult, because of getting a transfer case with the shifter and driveshafts.
I appreciate you finding those posts! I havent been able to find anything, and I've searched. It looks as though that front diff mount is mounted solid, is that correct? Looks like I need to find a transfer case with shifter and driveshafts attached, so I have a starting point.
Ok, no biggie about needing a 6". How did you mount the front diff? Thanks for the info!
Yeah, I've spent hours searching this topic. Some info here and there, but no pictures.
Also, what transfer case did you use?
Yeah, I have a 6 inch lift, but only have 4 inch subframe spacers etc. Was hoping to not go bigger on those. How does your engine sit in the cradle? Did you still have the engine crossmember spaced down, or is that in it's normal spot, and the diff mounted under that? Thank you!
Who has pics, and info on how to do this. I have a general idea, but would love to see some pics. Even if it's on an ea81 car. Thanks ahead of time.
Automatic with bigger tires?
The 4eat transmission is tough. You won't have any issues running big tires.
One piece solid driveshaft
bratman18 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDifferent model year ranges have different lengths. And different models as well. Legacy is different length than impreza and forester.
bratman18 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnope, as long as they're both auto or both manual, they're the same length.
bratman18 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as they're the same transmission. Like both auto or both manual. That dictates the length of the driveshaft.
Ej22 swap wiring harness
You need from the ecu, through the dash to the steering column, and then out to where it plugs into the engine harness.
Ebay strut spacers, Good, Bad, Opinions?
bratman18 replied to Jabbott126's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey're not camber correct. Better to spend a bit more money and get a good kit from someone like Andersondesign-fab.com
Lifted Impreza sway bar link idea/question
bratman18 replied to comatosellama's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDefinitely not. Sometimes when lifting, the stock plastic endlinks don't hold up to the extra stress. Along with the fact they are at a harder angle do to their length. The adjustable ones just allow you to retain endlinks, and not have to worry about them breaking.
bratman18 replied to comatosellama's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, to be honest,I don't run a rear sway bar on any of my lifted cars and I'm lifted more than forester struts. You won't roll it over. It just has more body roll.
Subaru axle assembly/CV joint
bratman18 replied to alaskanjer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know at least in my area, no one buys factory remain axles, so it's not something we ever see.
