Everything posted by Olnick
Oil Leak
Olnick replied to tomson1355's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is, Oh, and congratulations on your success!
Help: Resistor vs. Non-resistor spark plugs?
Olnick replied to calazo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice summation, grossgary. There's a lot of wisdom in your statement. Thanks.
Cold idle problem with a 1991 subaru legacy turbo
Olnick replied to Tanispyre's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can search right here on USMB too. Type in Idle Air Control IACV. Good luck.
Front axle procedure for early EJ series
Olnick replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThankyouthankyouthankyou, Ed!
95 Legacy clutch / transmission problem
Olnick replied to ronnie johhhnnn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 95 Legacy clutch / transmission problem
Olnick replied to ronnie johhhnnn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAmen to that, nip. Finsol, I'd bet that is exactly where your problem lies. I've never messed with mine but I'm pretty sure it has been discussed here before. Try a search for hill holder and see what you can turn up. If that doesn't help then I'm sure someone will chime in with help. Good luck.- SVX stalling
Olnick replied to SakoTGrimes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're a lucky guy, Sako. Fits right in with my theory that Subaru owners are the most caring, considerate people on the road. USMB offers ample proof of that! And +1 on the engine coolant temperature sensor as Emily said. Skip's suggestion of checking/cleaning the IACV is a good idea too. Aloha!- '98 Outback overheating
Olnick replied to MrDundee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck to see if Alabama has a Consumer Protector's office. Talk to your local BBB office. Call the DMV and see if they can help you or point you in the right direction. It all depends on the laws of your state. Since they just sold you a car that apparently is not serviceable you may have some rights. But do it asap. Good luck.- 4EAT duty c solenoid & Clutch pack replacement.
Olnick replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice pix, Andyjo!- Alloy wheels for 97 Legacy
Olnick replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot quite. I believe Legacy L models have discs all around. My '95 does.- T-Belt time, idlers question
Olnick replied to 86BRATMAN's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck prices at some of the online Subaru parts houses, then call Jason at Mike Scarff Subaru in Auburn, WA, 866-528-5282. Nice guy, very knowledgable and always, in my experience, has the best prices you can find. Mention USMB (don't know if we get special pricing but hey, it never hurts!)- No start, crank or click - back to the drawing board
Olnick replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWay to go, Steve, and thanks for the update. I'd strongly suggest you take the old starter out and check the contacts anyway. (It's not that difficult--if I can do it I'm sure you can!) Those starters are pretty rugged and it's a waste to replace the whole thing for the sake of a couple of dollars worth of small parts. Anyway--more good luck to you. And keep us posted on your progress. Aloha.- No start, crank or click - back to the drawing board
Olnick replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat Cougar said for sure. But personally I'd be most suspicious of the contacts in the starter solenoid. Disconnect the wires to the starter then remove the entire unit (one bolt and one nut on a stud, both different sizes--bottom one is probably easiest to reach from underneath.) Then remove the cover plate from the back of the solenoid (phillips screws?) and pull the plunger out. Carry some light sandpaper along--you might be able to clean the L-shaped copper contacts and the circular ring on the plunger enough to keep it working for awhile. Good luck, Steve. Hope it's as simple as that.- Rumbling rear on 97 Legacy
Olnick replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's also a good idea to change your oil filter midway through that longer interval. Synthetic has a lot of "cleaning" power and will probably loosen up a lot of crud. Congrats on your "new" '97!- Timing Belt Question
Olnick replied to Sonicfrog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAw shoot, avk. You just took all the mystery and romance out of it. You should have told everyone you are a super genius mathematician! Anyway, thanks. You made my morning!- Timing Belt Question
Olnick replied to Sonicfrog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNow that's funny. When I first read this thread I was sure someone knew the number or would calculate it. Thanks, avk!- Engine misfires going from high rpm to idle
Olnick replied to halyva's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, and wax the car too. (Shiny cars always run better!)- CV axle job - breaker bar or impact wrench
Olnick replied to teppichkopf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAn excellent suggestion. I did that to loosen an extremely tight rear diff plug once. Just make sure the angle of attack between the jack and the breaker bar is as close to 90 degrees as possible.- Somebody Boot Me!
Will soon be pulling the shifter in my '95 Legacy to replace the bushings and am in need of a new boot--the black leather "sack" type. Those long, bushingless shifts have worn big holes in the original! New OEM one is about $40, not an unreasonable price I suppose. That's from Jason at Mike Scarff Subaru in Auburn, WA. But got to thinking, has anyone tried any aftermarket boots (if they exist)? Any recommendations? Or anyone found decent boots in a pull-and-pay or salvage yard? Would appreciate any thoughts or suggestions, gang. Mahalo & Aloha.- What begins with "H" and we all dread?
Olnick replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup, really. What prompted it? Probably marketing--"new body styling, increased horsepower!" As far as how they did it, you'd have to get inside the inscrutable minds of FHI executives and engineers to find out. J/k! I'm sure someone here knows what they did.- lightbulb :)
Olnick replied to MtnBikerChk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmm. Leads to the inevitable question, how many MtnBikerChks does it take to , , , !- Intermittent Stumble at Idle Speed
Olnick replied to Phillip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, it can be cleaned. On my '95 Legacy 2.2 I found it best to remove it from the engine for cleaning. Not too difficult a job. Try a search for IACV--lots of info here about it. Good luck.- What begins with "H" and we all dread?
Olnick replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually '95 and '96 models have 135hp.- Help Please, Idle Air Control solenoid coolant lines
Olnick replied to Tsuriman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo shame, Tsuriman. You solved the problem and were thoughtful enough to post the solution. Thanks!- what do you think of the new stuff
Olnick replied to tailgatewagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks good! Nice work, Erik. - 95 Legacy clutch / transmission problem
